Programming puzzles: processing lists!
05-14-2017, 02:08 PM
(This post was last modified: 05-14-2017 02:59 PM by pier4r.)
Post: #81
RE: Programming puzzles: processing lists!
So I'm trying to go through the #21 but the RPL syntax, at least with my approach, is not really manageable with such problem.
As usual before one of my programs work I need to debug it and fix those 20+ little mistakes (my average fix rate so far) before it runs. The disadvantage of DOLIST and DOSUBS in this case is the debug mode, one cannot really debug those. At least for what I know. If one uses NSUB, for example, in the debug mode it is not available (since DBUG executes the program, not DOSUBS), therefore one is doomed to have errors. Another problem is that I'm not really sure when DOSUBS accepts that the program does not leave on the stack anything, so it can avoid to build a list, or when I should leave on the stack something, so it does not complain. So I'm a bit stuck and the alternative is to write routines that let me avoid to use DOLIST and DOSUBS for better debug alternatives. I though about iterating lists with FOR and GET or GETI, but they are quite slow. Just iterating though the elements of a list (adding +1 to the positive integer in the list, then dropping it). DOSUBS with 1000 elements takes 4 seconds, FOR with GET 35 seconds, START with GETI 56 seconds. I can (of course I'm not thinking about sysRPL or other ways) explode the list and managing it on the stack with a list operation routine but this will lower the tradeoffs of remaining in the (user)RPL realm. Any ideas? Maybe I should just use another language due to the debug limits, or accept the execution time needed with a FOR loop, but in this case the time will likely explode with a input list of 100 elements for the #21 . I also did some searches, here on this site google did not help. On the comp.sys.hp48 newsgroup (are there other relevant newsgroups/forums ? Aside from the official but chaotic official HP forum) the search returned slightly related topics, one quite interesting about DOLIST (that I linked on wiki4hp). Surely comp.sys.hp48 is another goldmine that I should read one day, also because it should be more focused on the 48,49,50 series as far as I understood, rather than other great but different HP calculators. The code, not working so far (DOSUBS complain "BAD argument error") is the following Code:
05-24-2017, 12:44 AM
Post: #82
After having attempted a handful of these challenges, I realized that I tended to use a couple of recurring methods for several of them. I thought it might be useful for future explorations in list-land if I simply created a few list functions of my own as a challenge to myself. Here's some of the functions I came up with, and samples of how they could be used in the context of these challenges:
LSHF (List Shuffle) Input 1: { list of 0 or more objects } Output 1: { same objects as input, in random order } Shuffles a list of 1000 reals in about 7.3 seconds. This one is more useful for generating test data than any of the actual challenges themselves. LDDUP (List DeDup) Input 1: { list of 0 or more objects } Output 1: { same list with duplicates removed } This is simply a UserRPL wrapper around the internal COMPRIMext command. Makes short work of #21: Code: \<< LDDUP \>> LREPL (List Replace) Input 3: { list of 0 or more objects } 2: { list of target objects } 1: { list of replacement objects } Output 1: { list from SL3 with objects matched in SL2 list replaced by objects in SL1 list } The following examples would be solutions to challenges 2 & 12: Code: Ch2 LROT (List Rotate) Input 2: { list of 0 or more objects } 1: rotation value [integer] (neg. for left rotation, pos. for right) Rotation value of 0 leaves the list unchanged. Rotation wraps accordingly if the rotation value is greater than the size of the list. Sample use for challenge #3: Code: \<< LMRPT (List Multiple Repeat) Input 2: { list of 0 or more objects } 1: repeat factor [integer] Output 1: { list with same objects from SL2 input repeated as directed by repeat factor } A repeat factor of 1 returns the same list. A repeat factor of 0 returns an empty list. Otherwise, the list contents are repeated in the same order as the original list. This one wouldn't be hard to do in UserRPL, but this version's advantage is that it is quite speedy -- creating a list containing 20 repeats of 50 real numbers (for 1000 final list elements) completes in about 0.09 seconds. Examples: Code: { 1 2 3 } 0 LMRPT => { } LSUM (List Sum) Input 1: { list of 0 or more objects } Output 1: <the result of the list elements added together> This command is essentially the same as \GSLIST, but it also accepts an empty list or a list with only 1 element as input. I chose to give a result of 0 for any empty list, simply because it fit my needs. The sum of a single element is simply that same element. In the same fashion as \GSLIST, object types must be compatible or an error will result. LEQ (List Equal) Input 1: { list of 0 or more objects } Output 1: 0 (FALSE) or 1 (TRUE) This checks to see if there are any non-matching elements in the list. For purposes of this function, an empty list assumes a result of TRUE as there are no non-matching elements. Likewise, a list of 1 element is also assumed to be TRUE for the same reason. LRPCT (List Repeat Count) Input 1: { list of 0 or more objects } Output 1: { { elements in the order encountered } { number of repetitions of each element in the prev. list } } Example: { 1 1 1 2 3 1 } => { { 1 2 3 1 } { 3 1 1 1 } } An empty list will result in a list of two empty lists { } => { { } { } } for consistency. This one proved to be useful for several of the challenges, especially when combined with LEQ: Code: Ch6 I did this mostly as a personal exercise for myself, but I'm happy to share the library containing these commands if anyone's interested. |
05-24-2017, 01:33 PM
Post: #83
RE: Programming puzzles: processing lists! | |||
05-24-2017, 03:29 PM
Post: #84
(05-24-2017 01:33 PM)John Keith Wrote:(05-24-2017 12:44 AM)DavidM Wrote: ... but I'm happy to share the library containing these commands if anyone's interested.Of course we are. :-) OK, now that I've given some thought to this, a potential issue has come to mind. 5 of the functions I created do inherent equality comparisons between elements of a list. In the case where the elements are numeric, there's a distinct difference between approximate and exact integers (eg. "1" vs. "1." [or "1," depending on your current fraction mark]). The way things are currently handled, "1" is considered to be different from "1.". So, for example, the LEQ command referenced above returns FALSE (0.) for the list { 1 1. }. It's not clear to me right now if this is actually a problem, or simply a non-intuitive feature. Even some of the built-in functions handle this situation differently. For example: { 1 } { 1. } == returns 0., whereas 1 1. == returns 1 (note that you have to be in exact mode to begin with when typing this in manually). I could change the commands to make them look for this situation and accommodate it, but it would degrade performance somewhat. Is it worth it? |
05-24-2017, 03:51 PM
Post: #85
David I started the processing list challenges exactly with the idea that slowly I would have created my library of solutions to understand better the list processing, so yay that it worked also for someone else! (whoever created libraries, please share!)
Sure sharing is great (why not the software library section?) and I do think that one could provide two versions of the command if needed, one generic and one optimized. I'm still blocked with the challenge on the graph, due to debugging problems with list operations. Either I go with for loops, but it is super slow (I'll try later with the new rpl), or I substitute dolist and dosubs with routines easy to debug, using the stack, but it is super not motivating. The alternative is to try other languages (no sysrpl) like new rpl / basic / hpgcc. Since I'm interested to solve the damn problem I'm using it to explore sqlite, so at the moment I'm solving it with sql only (of course not on the 50g, not yet at least, I'm using an embedded device that has half of the power of a Hp prime. Actually writing a sqlite like db on the prime is an idea) but still I fight with bugs. As soon as I'm finished I'll dive in new rpl vs user rpl using more list processing (I accumulated in the meanwhile like 10 other challenges to define). Wikis are great, Contribute :) |
05-24-2017, 06:12 PM
Post: #86
A quick test shows that the performance degradation is significant when comparing reals and integers for equality. A worst-case situation for LEQ checking 1000 list elements went from 0.69 seconds to 3.14. A similar test for LRPCT went from 0.66 seconds to 3.07. I may be able to speed that up by pre-checking types to see if the more permissive equality check is even needed. The additional tests may offset the advantage, though.
I could do two versions of the affected commands, and I could also create a command to convert any integers in a list to reals. That would allow pre-processing the initial list to a consistent (and faster) domain to begin with, so subsequent operations could all use the simpler equality test. Converting 1000 integers to reals takes about 5 seconds. Not insignificant, but it could still be worth it if it sets up the use of the optimized commands later. I realize that this set of commands is a bit more application-specific than something like GoferLists. But they may still be of some use. |
05-24-2017, 06:43 PM
Post: #87
(05-24-2017 03:51 PM)pier4r Wrote: I'm still blocked with the challenge on the graph, due to debugging problems with list operations. Either I go with for loops, but it is super slow (I'll try later with the new rpl), or I substitute dolist and dosubs with routines easy to debug, using the stack, but it is super not motivating. The alternative is to try other languages (no sysrpl) like new rpl / basic / hpgcc. I will confess that I've had no desire to approach that particular challenge, partially because it's probably been at least 20 years since I had to code any kind of graph-traversal routines. Also because it made my head spin every time I tried to reconcile the problem description with any kind of RPL approach. That said, I don't think I'd like to use SQL for it, either. I applaud your efforts and will be happy for you when you solve it. |
05-24-2017, 08:28 PM
(This post was last modified: 05-24-2017 08:39 PM by pier4r.)
Post: #88
(05-24-2017 06:12 PM)DavidM Wrote: A quick test shows that the performance degradation is significant when comparing reals and integers for equality. I'm a fan of "look this works under those conditions". Making super generic routines is surely helpful and maybe fun, but one has to start small, otherwise one never starts. So once you define properly the expected input, that's it. Another person can improve it (as it was done for the GoFerList. Open source has this strength). (05-24-2017 06:43 PM)DavidM Wrote: I will confess that I've had no desire to approach that particular challenge, partially because it's probably been at least 20 years since I had to code any kind of graph-traversal routines. Also because it made my head spin every time I tried to reconcile the problem description with any kind of RPL approach. That said, I don't think I'd like to use SQL for it, either. I applaud your efforts and will be happy for you when you solve it. I do believe the #20 (I mistook with the #21 all the time, damn me) is not that difficult to solve, at least trivially. Just for me it is divided in 3 parts: - generate the input, done. - process it to let it be analyze by the "find the clique" routine. That is the part where I#m stuck because I tried to use DOLIST and DOSUBS that are not debug friendly. And the idea to process the input is not even that difficult, but the details are. - compute the largest clique (naively), still undone part but I have the basic algorithm in mind. Graphs can be nasty, but not that of a problem. I mean especially when I pick the challenges from sites like careercup.com , even if I variate them a bit, the problems cannot be too hard because are meant to be solved in some hours (with python or other comfy languages I guess). As I wrote multiple times, I got frustrated by the attempts to debug DOLIST/DOSUBS (because sometimes they accept empty stacks as result of the program, sometimes not, for example, it is not so clear) and I started to look elsewhere before trying again. Since one of my todo-s is to explore SQLite (that is pretty beefy in terms of capabilities, I was not expecting that), I started to use it there. The code, not working, in userRPL, is here: https://app.assembla.com/spaces/various-...erations.s lines 2583 - 3117 (as usual, mostly are comments). The list generator and the input collector works. The part to extend the reachability of the nodes does not. In SQL is here: https://app.assembla.com/spaces/various-..._201705.sh So far it works, although the debug was intensive, but now I need to see how to determine the largest clique. I have the algorithm in mind but not its translation in SQL and I don't want to end up to use WITH RECURSIVE ... SELECT . Or maybe yes? dunno. If I have to be honest, I do think that, in the cause I had debug-friendly DOLIST and DOSUBS, the userRPL approach is way less weird than the SQL approach because userRPL has all those nice functions for lists, SQL does not have much functions to make actions between tables. Or at least I do not know them so far. So the actions allowed by userRPL give more freedom to the user. edit: I forgot, thanks for the moral support! I actually feel really bad, the #20 was a variant of a question for an amazon software engineer position and I guess they allowed like 1 hour to solve it, and I'm stuck since days. Wikis are great, Contribute :) |
05-24-2017, 11:14 PM
Post: #89
(05-24-2017 03:29 PM)DavidM Wrote: OK, now that I've given some thought to this, a potential issue has come to mind. 5 of the functions I created do inherent equality comparisons between elements of a list. In the case where the elements are numeric, there's a distinct difference between approximate and exact integers (eg. "1" vs. "1." [or "1," depending on your current fraction mark]). The way things are currently handled, "1" is considered to be different from "1.". So, for example, the LEQ command referenced above returns FALSE (0.) for the list { 1 1. }. It's not clear to me right now if this is actually a problem, or simply a non-intuitive feature. I would leave them as they are. One can use I->R and R->I as necessary to convert. I believe it is better to have faster, simpler functions wherever possible. OTOH, if you decide to post the code for your functions, you may want to post both versions and let subsequent users decide which version they want to use. John |
05-25-2017, 12:42 PM
Post: #90
(05-24-2017 11:14 PM)John Keith Wrote: I would leave them as they are. One can use I->R and R->I as necessary to convert. I believe it is better to have faster, simpler functions wherever possible. I agree with this idea. Wikis are great, Contribute :) |
05-25-2017, 04:33 PM
Post: #91
OK. I stewed on this for a bit (over)thinking through various options, but ultimately decided to leave things as they were.
For a short time, I considered having the commands check the status of system flag 105 (exact/approximate mode) to see whether they should use the faster equality check (1<>1.) or the slower one (1=1.). But ultimately I feel it's more important that the commands produce consistent results. So I opted against that. Besides the resounding feedback , the kicker for me was the realization that the internal command that LDDUP uses (COMPRIMext) also treats integers and reals as not being equivalent. Keeping the other commands as-is maintains consistency with how this built-in command operates. As has already been mentioned, it's simple enough to use I→R on a list to convert all the integers to reals before further processing. That mitigates any potential equivalency issues, and therefore allows all of the routines that need to perform these checks to use the faster methods. All of these commands were implemented in a Debug4x project as standard SysRPL objects, with a small amount of Saturn code sprinkled in as well. I'll be happy to share it with anyone that's interested -- PM me if you'd like to receive it. I do consider this to be a work in progress, so updates may occur at any time. Here's a complete list of the commands included in the attached library (#1423): LCNT (List Count) Input 2: { list of 0 or more objects } 1: Any object Output 1: Count Returns the number of instances of the object in SL1 that exist in the list from SL2. LDDUP (List DeDup) Input 1: { list of 0 or more objects } Output 1: { same list with duplicates removed } The objects in the result list are in the same order encountered in the original list. LEQ (List Equal) Input 1: { list of 0 or more objects } Output 1: 0 (FALSE) or 1 (TRUE) Checks to see if there are any non-matching elements in the list. For purposes of this function, an empty list assumes a result of TRUE as there are no non-matching elements. Likewise, a list of 1 element is also assumed to be TRUE for the same reason. LGRP (List Group) Input 1: { list of 0 or more objects } Output 1: { list of 0 or more objects } Returns the same list with only the first instance of any objects that are repeated. Objects are in the same order as they are encountered. LMRPT (List Multiple Repeat) Input 2: { list of 0 or more objects } 1: repeat factor [integer] Output 1: { list with same objects from SL2 input repeated as directed by repeat factor } A repeat factor of 1 returns the same list. A repeat factor of 0 returns an empty list. Otherwise, the list contents are repeated in the same order as in the original list. LREPL (List Replace) Input 3: { list of 0 or more objects } 2: { list of target objects } 1: { list of replacement objects } Output 1: { list from SL3 with objects matched in SL2 list replaced by objects in SL1 list } Example { 1 2 3 } { 1 3 } { 7 8 } LREPL result: { 7 2 8 } LROT (List Rotate) Input 2: { list of 0 or more objects } 1: rotation value [integer] (neg. for left rotation, pos. for right) Output 1: { list of 0 or more objects } Returns the same list rotated per the given rotation value. A value of 0 leaves the list unchanged. Rotation wraps accordingly if the rotation value is greater than the size of the list. LRPCT (List Repeat Count) Input 1: { list of 0 or more objects } Output 1: { { L1 } { L2 } } L1: Same as LGRP result L2: The count of each item in L1 that was in the input list An empty list will result in a list of two empty lists { } => { { } { } } for consistency. Example { 1 1 1 2 3 1 } LRPCT result: { { 1 2 3 1 } { 3 1 1 1 } } LSHF (List Shuffle) Input 1: { list of 0 or more objects } Output 1: { same objects as input, in random order } Randomizes the order of the elements in the list given as input. LSUM (List Sum) Input 1: { list of 0 or more objects } Output 1: <the result of the list elements added together> This command is essentially the same as ΣLIST, but it also accepts an empty list or a list with only 1 element as input. An empty list as input results in 0. The sum of a single element is simply that same element. Object types must be compatible for addition or an error will result. LSWP (List Swap) Input 3: { list of 0 or more objects } 2: index1 [real] 1: index2 [real] Output 1: { list of 0 or more objects } The result is the same list with elements <index1> and <index2> swapped. |
05-25-2017, 07:38 PM
Post: #92
Nice! I have two questions though:
(a) why not the software library section ? (to be reached by Google, otherwise here it will be difficult) (b) redundancy is never bad, so why not also hpcalc.org? I mean you just mention the code as beta if you don't want to be bold and that's it. Kudos anyway. Wikis are great, Contribute :) |
05-25-2017, 08:06 PM
Post: #93
(05-25-2017 07:38 PM)pier4r Wrote: Nice! I have two questions though: Answers to all of the above are the same right now: It's an evolving work that has limited value at present. I've actually already added a couple of commands since I posted the one above, and I'm thinking there could be a few more in the near future. I really don't feel that it has enough value to warrant posting to Eric's site (hpcalc.org) just yet. It might later, though. I'm still in "exploration mode" and new ideas for more commands are creeping into view. Plus, I still need to take a look at some of the other tools available. I suspect I'm reinventing the wheel with some of this. Once the command set stabilizes I'll add something to the General Software Library. |
05-25-2017, 09:57 PM
Post: #94
Thanks for posting that, David. I will be very busy for the next week or so but I will give it a try when I get the chance. SysRPL and Saturn assembly are mostly "above my pay grade" but I can see that several of the library functions will be very useful for the sort of programming that I do, and hopefully for others as well. I therefor strongly (and selfishly!) encourage further development of this library.
John |
05-26-2017, 06:36 PM
Post: #95
About reinventing the wheel: maybe, but one never knows the possible future ramifications if one does not start. So, if it is fun, great. I will post more processing challenges and then I'll try to solve them without and with your library (you see, already the idea of using go fer lists lost some priority)
05-26-2017, 10:48 PM
Post: #96
(05-25-2017 09:57 PM)John Keith Wrote: Thanks for posting that, David. I will be very busy for the next week or so but I will give it a try when I get the chance. SysRPL and Saturn assembly are mostly "above my pay grade" but I can see that several of the library functions will be very useful for the sort of programming that I do, and hopefully for others as well. I therefor strongly (and selfishly!) encourage further development of this library. I tried several of the functions, all with lists of 1000 exact integers. LCNT, LROT, and LSWP are impressively fast, taking less than 1/4 of a second. LDDUP is faster than GoferList's Nub (5.3s vs. 6.2s on the list I tried) and returns the same result list. LGRP takes around 3.2s on a list of 1000 integers in the range 0..9. LSHF takes about 8.8s and about 0.4s for a list of 52 integers. There seems to be a bug in the LREPL function- it works properly when executed from the command line but does nothing when used in a program, e.g.: \<< {10} {999} LREPL \>> I have not yet tried any other functions. John |
05-26-2017, 11:47 PM
Post: #97
(05-26-2017 10:48 PM)John Keith Wrote: ...LDDUP is faster than GoferList's Nub (5.3s vs. 6.2s on the list I tried) and returns the same result list. Wish I could take credit for that! It's using a built-in ROM routine which is apparently nicely optimized. (05-26-2017 10:48 PM)John Keith Wrote: LSHF takes about 8.8s and about 0.4s for a list of 52 integers. I could make that one faster, but I chose to stick with using the built-in RAND functions. This requires a couple of extra conversions between reals and BINTs (System Integers), but I figured it was better than me trying to come up with an acceptable alternative for a pseudo-random algorithm. (05-26-2017 10:48 PM)John Keith Wrote: There seems to be a bug in the LREPL function- it works properly when executed from the command line but does nothing when used in a program, e.g.: Hmmm... is there any possibility that this is one of those situations where the program has approximate numbers as targets and the source list has exact (or vice-versa)? Those wouldn't match, thus appearing as though it wasn't working. Otherwise I'm not sure what else might be happening, as I can't seem to replicate the issue. Any other details you can share would be greatly appreciated. Thanks for testing this out, John! I'll try a few more tests with LREPL to see if I can get it to misbehave. For the moment, it seems to be working as expected for me. But I'm not assuming that I've tried every possible combination of things that might trip it up. |
05-27-2017, 07:40 PM
Post: #98
All of my tests were with exact integers in exact mode. I have the library stored in port 2 (flash) if that makes a difference.
Example input: {1 2 3 4 5 6 7 8} {4} {9} Output: {1 2 3 9 5 6 7 8} Example 2: {1 2 3 4 5 6 7 8} \<< {4} {9} LREPL \>> EVAL Output: {1 2 3 4 5 6 7 8} (That is, no replacement) HTH, John |
05-27-2017, 08:07 PM
Post: #99
(05-27-2017 07:40 PM)John Keith Wrote: Example 2: John, I appreciate your trying this out. This is truly puzzling. I just tried the exact same steps you outlined above (in exact mode as well), and got the expected result of { 1 2 3 9 5 6 7 8 }. I also tried putting all three lists into a program, and still had the correct results after execution. There's obviously still something very different about our setups that isn't apparent. I'd love to know what it is. What happens if you change the numbers? Or better yet, what happens if you use letters (identifiers) instead? Something like { A B C D E F G H } \<< { D } { Z } LREPL \>> If I do the above, I get the expected result: { A B C Z E F G H } What result do you get? |
05-28-2017, 06:31 PM
Post: #100
DOH!
I realized what the problem was: I had a program in my HOME directory called LREPL, a similar program I had been working on a few weeks ago. I renamed that program and everything is working fine now. ;-) Sorry for wasting your time, I really appreciate your effort. Homer Simpson (aka John) |
