EXC/ x<>Rn for stack efficiency
06-11-2017, 08:58 PM (This post was last modified: 06-11-2017 09:09 PM by Matt Agajanian.)
Hi all.
I'm trying to find the most effective way to perform a register exchange function that minimizes stack disruption. Although on the 34C and 67, and later models the I register and x<>(i) functions are available, how can x<>Rn be accomplished with the 25 or 33 without disrupting the stack drastically?
Thanks
06-11-2017, 10:07 PM
RE: EXC/ x<>Rn for stack efficiency
(06-11-2017 08:58 PM)Matt Agajanian Wrote:  I'm trying to find the most effective way to perform a register exchange function that minimizes stack disruption. Although on the 34C and 67, and later models the I register and x<>(i) functions are available, how can x<>Rn be accomplished with the 25 or 33 without disrupting the stack drastically?
The obvious solution (assuming X is exchanged with register 1) would be:
RCL 1
x<>y
STO 1
R↓
Since the current X-value and the content of R1 require two stack registers, this solution loses the T-register:
before   after
  T       X
  Z       Z
  Y       Y
  X       R1
LastX    LastX
Replacing the final R↓ with CLX + duplicates the previous Z to T while it clears LastX.
As far as I can see you always have to sacrifice one register.
Dieter
06-11-2017, 10:23 PM
Thank you, Dieter. These two variations will help.
06-11-2017, 11:08 PM
Save the stack in registers first?
Neither of those devices have indirect addressing which is a big impediment.
Pauli
06-11-2017, 11:54 PM
Yes. That's why I'm trying to optimize translating my SR-56 programs for Woodstock and the 33E/C.
06-11-2017, 11:57 PM
(06-11-2017 11:08 PM)Paul Dale Wrote:  Save the stack in registers first?
Pauli
It's either I put R/S into the program to manually save and restore the stack so as to save program steps or clutter up my program with save/restore stack code.
06-12-2017, 12:08 PM (This post was last modified: 06-12-2017 12:17 PM by Dieter.)
(06-11-2017 11:57 PM)Matt Agajanian Wrote:  save program steps or clutter up my program with save/restore stack code.
When translating a program from one calculator to another it's usually not a good idea to mirror the original code 1:1 on the other device. IMHO the best approach is trying to understand how the original code works and translate this idea (!!, not the code) into code for the other machine.
So if you have, say, TI-programs with Exc-commands you should not try to simulate this Exc-instruction in your HP code. Instead see how the program works and do it in RPN with the special features of the target calculator – which may be even shorter and more effective.
Often in RPN things can be done quite relaxed. Here is an example:
TI-58/59    HP-25/33
 (           RCL 1
 RCL         RCL 2
 01          +
 +           RCL 3
 RCL         x<>y
 02          STO 3
 EXC
 03
No need to worry about stack registers or how to emulate that Exc-instruction.
Another example – swap the contents of R1 and R2:
TI-58/59     HP-25/33
 RCL          RCL 2
 01           RCL 1
 EXC          STO 2
 02           x<>y
 STO          STO 1
 01
Again, there's no need to save the stack or emulate the Exc-instruction.
Dieter
06-12-2017, 03:50 PM
Yes, an even better mousetrap. To be honest, the hard work of understanding AOS programming, intermediate results, and trying to understand what contents are needing to be saved for pending operations and register operations are worth the work for RPN transation.
06-12-2017, 07:48 PM
TI-58/59    HP-25/33
 (           RCL 1
 RCL         RCL 2
 01          +
 +           RCL 3
 RCL         x<>y
 02          STO 3
 EXC
 03
TI-58/59     HP-25/33
 RCL          RCL 2
 01           RCL 1
 EXC          STO 2
 02           x<>y
 STO          STO 1
 01
Dieter
Dieter, on second look I'm confused. This actually loses several stack register value when an exchange occurs in the midst of a calculation. At the end of a calculation, an exchange like this is acceptable. But, if you have seen several SR-56 Application Library and TI-58/59 Specialty Packette/Solid State Module programs, exchange operations occasionally are within a calculation. So, how do I code for those instances?
Thanks
06-12-2017, 08:51 PM
(06-12-2017 07:48 PM)Matt Agajanian Wrote:  But, if you have seen several SR-56 Application Library and TI-58/59 Specialty Packette/Solid State Module programs, exchange operations occasionally are within a calculation. So, how do I code for those instances?
Please provide an example with the complete program code and the way the program is supposed to work.
Dieter
06-13-2017, 07:26 PM
Okay. I'm going to focus on examining the SR-56 Application Library in more detail in the event I scanned over a code too quickly. Also, I'm redirecting my concentration to see the flow of the program so as to reprogram myself out of my 'straight translation' habit.
06-14-2017, 10:19 AM
I've been trying to figure this out and I'm getting confused and forgetting the stack at the exchange steps. So, please help me. Maybe you've already responded with the answer. But, the ends I'm trying to accomplish removes the former value from the stack and leaves the exchanged value on the stack with Y, Z, and (if possible) the T registers intact.
All I'm trying to do is leave the exchanged value in the X register without the forner register content in the Y register.
Perhaps I shoud have been clearer to the point of exact in my original post. Sorry.
06-14-2017, 10:36 AM (This post was last modified: 06-14-2017 11:01 AM by Paul Dale.)
Dieter is correct, the best way to do this is to understand the algorithm and recode it. RPN programs should almost always be shorter than AOS ones.
Since you want some code, this sequence will swap X and register 1 using register 0 and preserving the rest of the stack:
01  X<>Y
02  STO 0
03  CLx
04  RCL 1
05  X<>Y
06  STO 1
07  CLx
08  RCL 0
09  X<>Y
To avoid using the register, Last X can be used instead but this requires the arithmetic operation in step 2 to be undone in step 8 without loss (multiplication and division would also work as a pair in the same manner). This code swaps X with register 0 and leaves the rest of the stack intact:
01  X<>Y
02  +
03  RCL 0
04  X<>Y
05  STO 0
06  CLx
07  LAST X
08  STO- 0
09  X<>Y
Both are for the HP-25. Using 20% of the program memory to swap X with a register seems a little wasteful.
Pauli
06-14-2017, 03:04 PM
First, let me apologise for my frustration. I'm trying too hard to fit an advanced technique (67/97/34) into a basic 25/33 (forgive me) programming language.
Second, I do appreciate your straughtforward four-to-multiple step variations. I shouldn't try so hard to make the most direct method into an elaborate one. Besides, I need to adapt to what a calculator does best by its own merits. For example, I can't expect the 25 or 33 to handle the memory register gymnastics for a Moving Averages program. If I want to code for something that complex, I should use the right tool for the task, a 67/97, 34C, or later. Besides, as capable as the 65 is, a Moving Averages program, for example, requiring indirect addressing isn't that feasable.
Once again apologies and thanks.
06-14-2017, 06:23 PM (This post was last modified: 06-14-2017 06:24 PM by Dieter.)
(06-14-2017 03:04 PM)Matt Agajanian Wrote:  First, let me apologise for my frustration. I'm trying too hard to fit an advanced technique (67/97/34) into a basic 25/33 (forgive me) programming language.
Well, of course most of the HP67/97 and maybe also 34C programs are so complex that they simply won't fit the 25 or 33. After all it is 224 steps plus 26 registers vs. 49 steps and 8 registers... plus a less comprehensive command set. So at least a more or less direct program transfer must fail. That said, many clever programs for the 25 exist that prove what can be done even with its limited ressources.
(06-14-2017 03:04 PM)Matt Agajanian Wrote:  Second, I do appreciate your straughtforward four-to-multiple step variations. I shouldn't try so hard to make the most direct method into an elaborate one. Besides, I need to adapt to what a calculator does best by its own merits. For example, I can't expect the 25 or 33 to handle the memory register gymnastics for a Moving Averages program.
While we're at it: I just looked at the HP67/97 moving average program that came with the Standard Pac. At one point the oldest value is removed from the curent sum while the newest one is added and stored. This can be done with an EXC command, if available, but the 67/97 does it this way:
037  RCL i
038  ST- 0
039  x<>y
040  STO i
041  ST+ 0
042  R↓
Compare this with the suggestion in my first post. ;-)
(06-14-2017 03:04 PM)Matt Agajanian Wrote:  If I want to code for something that complex, I should use the right tool for the task, a 67/97, 34C, or later. Besides, as capable as the 65 is, a Moving Averages program, for example, requiring indirect addressing isn't that feasable.
OK. But there are other programs that can be done on the 25. I recommend looking at the HP-25 Library by Jim Davidson, a list of programs that have been published in PPC Journal between 1976 and 1978 (this index can be found in PPC V5 P6). I think it was Gene who posted the whole package as a PDF about half a year ago.
But... I am still waiting for an SR56 program with the infamous EXC instruction that is waiting for a translation to HP25/33 code. ;-)
Dieter
06-14-2017, 06:39 PM (This post was last modified: 06-14-2017 06:45 PM by Dieter.)
(06-14-2017 10:19 AM)Matt Agajanian Wrote:  I've been trying to figure this out and I'm getting confused and forgetting the stack at the exchange steps. So, please help me. Maybe you've already responded with the answer. But, the ends I'm trying to accomplish removes the former value from the stack and leaves the exchanged value on the stack with Y, Z, and (if possible) the T registers intact.
This – leaving the whole stack or most of it unchanged – usually is not required at all. At least after some slight recoding usually you do not have to hold three intermediate values on the stack.
Example: Calculate R1 + R2*R3^R4 while pushing pi into R4
AOS      RPN
RCL      RCL 3
01       RCL 4
+        Pi
RCL      STO 4
02       R↓
*        y^x
RCL      RCL 2
03       *
y^x      RCL 1
Pi       +
EXC
04
RPN is different. You can do most calculations without having to keep track of lots of intermediate results – you always work with just two numbers. ;-)
(06-14-2017 10:19 AM)Matt Agajanian Wrote:  All I'm trying to do is leave the exchanged value in the X register without the forner register content in the Y register.
?!? After the exchange the former register content is in X of course.
That's what the EXC command does. As well as the four-step-code in my first post. Y and Z are preserved.
Dieter
06-14-2017, 07:38 PM
AOS      RPN
RCL      RCL 3
01       RCL 4
+        Pi
RCL      STO 4
02       R↓
*        y^x
RCL      RCL 2
03       *
y^x      RCL 1
Pi       +
EXC
04
Dieter
Dieter, again, sorry for my mixup. Yes, your methods accomplish what I need. For some reason, a mental block on my part is gettiing in the way of imagining/picturing the stack. Perhaps, I should create an Excel or Word six-row table to help me physically visualise these.
Thanks
06-14-2017, 08:46 PM (This post was last modified: 06-14-2017 08:51 PM by Dieter.)
(06-14-2017 07:38 PM)Matt Agajanian Wrote:  For some reason, a mental block on my part is gettiing in the way of imagining/picturing the stack. Perhaps, I should create an Excel or Word six-row table to help me physically visualise these.
Here we go:
T         Z         Z         Z         X
Z         Y         Y         Y         Z
Y         X         R1        R1        Y
X         R1        X         X         R1   <= at the end X and R1
R1        R1        R1        X         X    <= have swapped their contents
Start     RCL 1     X<>Y      STO 1     R↓
You see that X and R1 are swapped, Y and Z are preserved, only T is lost.
Dieter
06-14-2017, 09:40 PM
Here we go:
T         Z         Z         Z         X
Z         Y         Y         Y         Z
Y         X         R1        R1        Y
Dieter
Thanks for that extra effort doing what I should have. Much appreciated and quite helpful.
06-14-2017, 11:31 PM (This post was last modified: 06-14-2017 11:38 PM by Matt Agajanian.)
Okay, here are the three SR-56 program I'm translating:
Great Circle Navigation
General Aircraft Weight and Balance
and
T to π and π to T Transformations
