BASIC Programs on HP 50G
03-20-2014, 07:57 AM
Post: #41
RE: BASIC Programs on HP 50G
(03-19-2014 06:16 PM)Howard Owen Wrote: Wow! Thanks for the gift of your time and trouble! I'm curious how many people will take advantage of or be disadvantaged by this fact. My guess is 0 (zero). |
03-23-2014, 01:08 AM
Post: #42
UBASIC now has the IF-THEN-ENDIF command and IF-THEN-ELSE-ENDIF command implemented for several lines of code, also corrected several BUGS.
the next step is to provide the interpetre a real string handling executable size remains the same. keep you informed of the progress in these small development UBASIC new example of an Ubasic program: Code:
03-23-2014, 09:18 PM
Post: #43
(03-23-2014 01:08 AM)churichuro Wrote: UBASIC now has the IF-THEN-ENDIF command and IF-THEN-ELSE-ENDIF command implemented for several lines of code, also corrected several BUGS. Very nice churichuro. I just had a look about "Local Variables" definition in the HP´s Handbook and more and more I believe your UBASIC will be a "Must have" App for every one. |
03-26-2014, 02:59 PM
Post: #44
(03-23-2014 01:08 AM)churichuro Wrote: UBASIC now has the IF-THEN-ENDIF command and IF-THEN-ELSE-ENDIF command implemented for several lines of code, also corrected several BUGS. Churichuro, I want to thank you for sharing your project with us. I have been semi-interested in purchasing a 50G. I think that your uBasic may be just the application that gets me to "pull the trigger" on buying one. Thanks again. Shawn |
03-26-2014, 06:00 PM
Post: #45
(03-09-2014 11:45 AM)HP67 Wrote: Did you find any HP materials that claim BASIC is supported? I saw this comment in many places, but as far as I know I never saw it on anything HP put out. (03-09-2014 01:59 PM)Namir Wrote: There is NO BASIC in the HP50G!!!!!!!!!! True, but never-the-less, this link from hp.com lists the 49g+ languages as "RPL/ Assembly/ HP Basic" Someone in marketing no doubt. :-) http://h10025.www1.hp.com/ewfrf/wc/docum...0002#N1686 Interestingly, hpcalc.org states that the 50g has: "Five built-in programming languages: User RPL, HP Basic, System RPL, Saturn assembly, ARM assembly." I wonder if this was quoted from some marketing info. In case you've never seen an Algebraic program on the 50g, see this comp.sys.hp48 post. https://groups.google.com/d/msg/comp.sys...FHGoofOYAJ -Wes L |
03-26-2014, 06:13 PM
Post: #46
(03-26-2014 06:00 PM)Wes Loewer Wrote: In case you've never seen an Algebraic program on the 50g, see this comp.sys.hp48 post. Do you have a usenet message-id? I don't use google. It ain't OVER 'till it's 2 PICK |
03-26-2014, 07:54 PM
Post: #47
(03-26-2014 06:13 PM)HP67 Wrote:(03-26-2014 06:00 PM)Wes Loewer Wrote: In case you've never seen an Algebraic program on the 50g, see this comp.sys.hp48 post. Maybe someone else knows how to get the message-id. But since it was my own post, I'll just quote it here. It was a tiny little program intended only to demonstrate that it could be done. (It might be the only Algebra program I've ever written for the 49+/50g.) Code:
-Wes L |
03-26-2014, 07:56 PM
Post: #48
(03-26-2014 06:13 PM)HP67 Wrote:(03-26-2014 06:00 PM)Wes Loewer Wrote: In case you've never seen an Algebraic program on the 50g, see this comp.sys.hp48 post. If you are interested to see how a Algebraic Mode program ("HP BASIC"???) on the HP 50g looks like see also this link http://www.hpmuseum.org/forum/thread-851.html |
03-26-2014, 08:09 PM
Post: #49
Thanks Wes and Alvaro. That's very interesting. It looks kind of like a weird hybrid of RPL, PASCAL, and FORTRAN. I will stick to RPL for now!
03-26-2014, 08:46 PM
Post: #50
(03-26-2014 08:09 PM)HP67 Wrote: Thanks Wes and Alvaro. That's very interesting. It looks kind of like a weird hybrid of RPL, PASCAL, and FORTRAN. I will stick to RPL for now! Programing in RPL has a very interesting particularity: Every time you make a user INPUT you have to declare another PROGRAM begin or you have to SAVE that input variable a as GLOBAL so that a the end you have all your HP50g FULL of USELESS variables that you will need to PURGE manually. Weird, I would say. |
03-27-2014, 03:54 AM
Post: #51
(03-26-2014 08:46 PM)Alvaro Wrote: Programing in RPL has a very interesting particularity: Every time you make a user INPUT you have to declare another PROGRAM begin or you have to SAVE that input variable a as GLOBAL so that a the end you have all your HP50g FULL of USELESS variables that you will need to PURGE manually. Weird, I would say.Weird is your speed to get to conclusions having almost no idea what is it all about. Everything you say above is nonsense. |
03-27-2014, 08:05 AM
Post: #52
(03-27-2014 03:54 AM)RMollov Wrote:(03-26-2014 08:46 PM)Alvaro Wrote: Programing in RPL has a very interesting particularity: Every time you make a user INPUT you have to declare another PROGRAM begin or you have to SAVE that input variable a as GLOBAL so that a the end you have all your HP50g FULL of USELESS variables that you will need to PURGE manually. Weird, I would say.Weird is your speed to get to conclusions having almost no idea what is it all about. Everything you say above is nonsense. Fisrt, thank you very much. Very nice. Second, I am talking about Local variable Structure; please read page 3-303 (PDF 423) of the Advanced User Guide HP 50g, about (Create Local). A Local Variable must be followed either by a Expression or a Program. If you don´t proceed like that, you must use the Global Variable definition! And, inside a Program, every time you define a Local Variable it must be followed either by a Expression or a Program and repeat that so many times as you need to "pause" for variable input. Regarding the Disadvantage of Global Variables , please read page 1-7 (PDF 31) "Using Local Variables". And, if I am missing something or you know it better, then it would be much more usefull to share your knowledge, if you like. |
03-27-2014, 09:02 AM
(This post was last modified: 03-27-2014 09:08 AM by RMollov.)
Post: #53
(03-27-2014 08:05 AM)Alvaro Wrote: And, if I am missing something or you know it better, then it would be much more usefull to share your knowledge, if you like.Sorry mate, if you wanted to learn RPL and asked reasonable questions I would share my experience as just about everyone in this very helpful community. Rather you draw conclusions from your limited knowledge and leave no space for help or explanations. If I were you, I'd get myself familiar with this very powerful language starting with the HP48 (s) user manual which I consider "The Bible" of RPL. HP48G added more powerful functions, but the manual lacks some of the basics. Further manuals (HP49, 50) just assumed one knew "The Bible". Again, what you wrote in your previous post is just not true, and I wouldn't start commenting such a nonsense. What's more, I've read many times in this forum that RPL has a steep learning curve. I absolutely disagree. It's very easy, logical, and neat language as far as calculators are concerned. Regards, |
03-27-2014, 03:41 PM
Post: #54
(03-26-2014 08:46 PM)Alvaro Wrote: Programing in RPL has a very interesting particularity: Every time you make a user INPUT you have to declare another PROGRAM begin or you have to SAVE that input variable a as GLOBAL so that a the end you have all your HP50g FULL of USELESS variables that you will need to PURGE manually. Weird, I would say. I think you missed the point of RPL being a stack based language. While you could use local or even global variables, a common method is to just use the stack. Perhaps an example would help. Here's the same Hi-Lo demo program again in RPN mode using no local or global variables. Code: \<< RAND 100. * 1. + IP "GUESS A NUMBER, 1-100" "" INPUT OBJ\-> -Wes L |
03-27-2014, 06:24 PM
Post: #55
I am don´t care about RPL or what ever that Macro Like script language is called. By the way, this Train drives towards about BASIC on the HP50g...
03-27-2014, 09:29 PM
Post: #56
(03-27-2014 08:05 AM)Alvaro Wrote: Second, I am talking about Local variable Structure; please read page 3-303 (PDF 423) of the Advanced User Guide HP 50g, about (Create Local). A Local Variable must be followed either by a Expression or a Program. If you don´t proceed like that, you must use the Global Variable definition! And, inside a Program, every time you define a Local Variable it must be followed either by a Expression or a Program and repeat that so many times as you need to "pause" for variable input. This is true if you absolutely must create a new local variable deep within the program as opposed to declaring them at the start. If your program has a fixed number of variables, then you can always create the ALL variables ahead of time and initiate them with a dummy value: Code:
Graph 3D | QPI | SolveSys |
03-28-2014, 02:43 AM
Post: #57
(03-27-2014 06:24 PM)Alvaro Wrote: I am don´t care about RPL or what ever that Macro Like script language is called. By the way, this Train drives towards about BASIC on the HP50g...Saying that on this forum is nothing short of complete ignorance. If I understand properly what you meant, of coarse. |
03-29-2014, 03:32 AM
Post: #58
(03-28-2014 02:43 AM)RMollov Wrote: Saying that on this forum is nothing short of complete ignorance. If I understand properly what you meant, of coarse. This and this. Regards, Howard |
04-20-2014, 12:39 PM
Post: #59
(03-09-2014 07:20 PM)churichuro Wrote: well, I do a Basic in C from scratch for the HP50 Hi churichuro, Are still working on your uBASIC? In the mean time I installed HPGCC 2.0 for Windows and the ARMToolBox 3.12 on the HP 50g. I tried some of the examples that with HPGCC 2.0 that they complie OK and also run OK in the HP. Now, I tried your versions of uBASIC 0.2 and 0.1 but there are a lot of errors on the HPGCC compiler so that I do not get the necessary *.HP file. Can you help on this? Thanks. Alvaro |
04-21-2014, 01:02 AM
Post: #60
(04-20-2014 12:39 PM)Alvaro Wrote: Hi churichuro, Yes Alvaro, I still work on this project but my real job takes me 14 hours a day lately and I have little time for the development of BASIC anyway not think it's a rush job. I find it strange that the version 0.1 does not compile. anyway I prefer that you wait a bit to release version 0.3 which includes a real string handling and better error handling. I am developing for MAC OSX, and WIn-8 for convenience and then a version that works better will do the upgrade for the TI-89, TI-voyage calculators, and of course for HP-50 one more thing...I need a new name for UBASIC, any ideas? regards |
User(s) browsing this thread: 27 Guest(s)
