LOG for HP 12C
08-30-2017, 01:47 AM
LOG for HP 12C
Here is a LOG program for HP 12C
Find the LOG in any base of any number: LOGь X: X > 0, b > 1 01 LN 02 R↓ 03 LN 04 R↓ 05 R↓ 06 R↓ 07 ÷ 08 GTO 00 Example: LOG₃ 9 = 2 9 ENTER 3 R/S 2 LOG₈₁ 3 = ⅟₄ 3 ENTER 81 R/S 0.25 LOG₁₀₀₀ 10 = ⅓ 10 ENTER 1000 R/S 0.33 Gamo |
08-30-2017, 02:07 AM
(This post was last modified: 08-30-2017 02:13 AM by Gerson W. Barbosa.)
RE: LOG for HP 12C
Here is my version. Not exactly faster, better or more accurate, only three steps shorter:
01 LN 02 1/x 03 y^x 04 LN 05 GTO 00 Best regards, Gerson. -------- PS: Or, in a more conventional way, but one step longer: 01 LN 02 x<>y 03 LN 04 / 05 1/x 06 GTO 00 |
(This post was last modified: 08-30-2017 02:09 AM by Gene.)
RE: LOG for HP 12C
EDIT: Rats, Gerson was faster and shorter. :-) Is either method more accurate?
Good idea! How about: LN X<>Y LN X<>Y / GTO 00 |
08-30-2017, 02:20 AM
RE: LOG for HP 12C | |||
08-30-2017, 04:22 AM
RE: LOG for HP 12C
Thanks for more alternative ways of LOG program.
Just wondering about the compute functions like 1/x or y^x will take more time to calculate than just using Rv or X<>Y Gamo |
08-30-2017, 02:42 PM
RE: LOG for HP 12C
(08-30-2017 04:22 AM)Gamo Wrote: Just wondering about the compute functions like 1/x or y^x will take more time to calculate than just using Rv or X<>Y Rv and x<>y are simple operations involving transfer of contents between internal registers. y^x alone requires a call to LN and another to e^x, both transcendental functions that take a lot a shift and add operations plus access to external tables in ROM. On slow calculators like the original HP-12C the difference in speed is quite noticeable, even without a stopwatch. The choice of which solution to use depends on what amount of free memory you have. The five-step version would make sense if those were the last remaining free steps on you 12C. Gerson. |
