RPN Question
10-25-2017, 11:11 AM
(This post was last modified: 10-25-2017 01:02 PM by Gamo.)
RPN Question
To divide x by 2
ENTER 2 ÷ What other keystokes will do the same that use only functions and No numbers except number to enter ? No (÷ x + -) Gamo - I got answer |
10-25-2017, 12:10 PM
(This post was last modified: 10-25-2017 12:12 PM by Paul Dale.)
RE: RPN Question
The WP 34S possibly has the shortest solution at two functions:
Code: yards->m More general is a statistical approach: Code: CLSigma Neither the arithmetic operators nor digits are required in either sequence. Pauli |
10-25-2017, 12:29 PM
(This post was last modified: 10-25-2017 12:30 PM by Gerson W. Barbosa.)
RE: RPN Question | |||
10-25-2017, 12:43 PM
RE: RPN Question
My first thought was the || function but I then made a mistake trying it and moved on.
Pauli |
10-25-2017, 01:05 PM
RE: RPN Question
(10-25-2017 12:29 PM)Gerson W. Barbosa Wrote: Also, if losing T is not an issue: Am I wrong, or it is the Electronics Engineer in you that came up with that elegant answer? Jose Mesquita RadioMuseum.org member |
10-25-2017, 01:10 PM
(This post was last modified: 10-25-2017 01:16 PM by Didier Lachieze.)
RE: RPN Question
For small numbers (between -99 & 99) you can do: [10^x] [√x] [LOG]
You can extend the range to [-230.25, 230.25] with: [e^x] [√x] [LN] |
10-25-2017, 01:33 PM
RE: RPN Question
(10-25-2017 01:05 PM)jebem Wrote:(10-25-2017 12:29 PM)Gerson W. Barbosa Wrote: Also, if losing T is not an issue: Here is a funny example of different coding for the same problem, according to the authors’ professions: http://www.hpmuseum.org/cgi-sys/cgiwrap/...read=74095 (See link in message #3) BTW, my solution for that one was “3 XOR” (valid for the HP-42S only). No, I am not logic circuit designer :-) Gerson. |
10-25-2017, 01:37 PM
10-25-2017, 01:54 PM
RE: RPN Question
Didier is right my intended answer is [e^x] [√x] [LN]
Someone also suggest ENTER 50 % is very good idea. |
10-25-2017, 02:21 PM
(This post was last modified: 10-25-2017 03:23 PM by emece67.)
RE: RPN Question
(10-25-2017 12:29 PM)Gerson W. Barbosa Wrote: This seems hardly beatable to me. Other approach still in the wp34s may be: Code: LB Also: Code: 1/x This last one keeps T intact, updates L in the right way, and also works with arguments <=0: Code: STO L Regards. |
10-25-2017, 06:32 PM
RE: RPN Question
Solution for HP 41CX
Try CC41! |
10-25-2017, 08:59 PM
RE: RPN Question
(10-25-2017 12:10 PM)Paul Dale Wrote: The WP 34S possibly has the shortest solution at two functions: It could have the definitely shortest solution with one single function call if (if!) the HALF function proposed back then would have made it into the 34s firmware. ;-) Yes, I still would appreciate such a function, and I think it would nicely complement STO+X or RCL+X for doubling X. Dieter |
10-29-2017, 02:43 AM
RE: RPN Question
(10-25-2017 02:21 PM)emece67 Wrote: Since the 41C doesn't have RCL+ Code: 1/x Try CC41! |
10-29-2017, 07:44 AM
10-29-2017, 09:42 PM
RE: RPN Question
(10-29-2017 07:44 AM)Dieter Wrote: Note that this method may cause roundoff errors: 7 → 3,499999999. I believe we have found machine epsilon for the 41, 1x10^-9. Since HP could have achieved a smaller epsilon if they had used binary vs. bcd format in the HP-41, there must have been some other tradeoff or legacy design that led them to use BCD. Try CC41! |
10-29-2017, 09:47 PM
RE: RPN Question
Ceci n'est pas une signature. |
10-29-2017, 11:49 PM
RE: RPN Question
--Bob Prosperi |
