Can you check for string parameters without a magic number?
11-15-2017, 09:43 PM (This post was last modified: 11-15-2017 11:43 PM by StephenG1CMZ.)
You can check for floats, integers, lists etc. In PPL.
Can you detect a string too? Without using a magic number...
EXPORT STRINGMAGIC()
BEGIN
 PRINT(IFTE(TYPE(12.5)==DOM_FLOAT-1,STRING('DOM_FLOAT'),"NOT"));
 PRINT(IFTE(TYPE(#12)==DOM_INT-1,STRING('DOM_INT'),"NOT"));
 PRINT(IFTE(TYPE("ST")==DOM_STRING-1,STRING('DOM_STRING'),"OOPS"));
 PRINT(IFTE(TYPE("ST")==3-1,"It IS a THREE, NOT A STRING","OOPS"));
 PRINT(IFTE(TYPE({})==DOM_LIST-1,STRING('DOM_LIST'),"NOT"));
END;
yields:
DOM_FLOAT
DOM_INT
OOPS
DOM_LIST
Is there an alternative constant?
Stephen Lewkowicz (G1CMZ)
11-16-2017, 12:20 AM
RE: Can you check for string parameters without a magic number?
Exists:
type() → CAS
TYPE() → Home
Viga C | TD | FB
11-16-2017, 07:09 AM
Using type instead of TYPE even though I am in PPL not CAS doesnt seem to help
BEGIN
 PRINT();
 PRINT(type(12.5)==DOM_FLOAT-1);
 PRINT(type(#12)==DOM_INT-1);
 PRINT(type("ST")==DOM_STRING-1);
 PRINT(IFTE(type("ST")==DOM_STRING-1,"It IS A STRING","NO, IT IS NOT A STRING "+type("M")));
 PRINT(type({})==DOM_LIST-1);
END;
What am I missing?
11-16-2017, 07:28 AM
In Home → TYPE
Syntax:
TYPE(object)
Returns the type of the object:
0: Real
1: Integer
2: String
3: Complex
4: Matrix
5: Error
6: List
8: Function
9: Unit
14.?: CAS object. the fractional part is the CAS type
In CAS → type (CAS.type in Home)
Syntax:
type(Object)
Returns the type of an object.
DOM_int
DOM_FLOAT, float
DOM_INT, integer
DOM_COMPLEX, complex
DOM_IDENT
DOM_LIST
DOM_SYMBOLIC, symbol
DOM_RAT, rational
DOM_STRING
DOM_FUNC
The types in Home and CAS are different, they are not related, for example the format #FFh for integers in CAS does not exist
Viga C | TD | FB
11-16-2017, 07:37 AM
Uso común: TYPE(n)
EXPORT TypeString(n)
BEGIN
  n:=TYPE(n);
  CASE
    IF n=0 THEN "Real" END
    IF n=1 THEN "Integer" END
    IF n=2 THEN "String" END
    IF n=3 THEN "Complex" END
    IF n=4 THEN "Matrix" END
    IF n=6 THEN "List" END
    IF n=8 THEN "Function" END
    IF n=9 THEN "Unit" END
  END
END;
Viga C | TD | FB
11-19-2017, 03:05 AM (This post was last modified: 11-19-2017 03:14 AM by TravisE.)
If I understand the OP correctly, they want to compare the types without directly using numeric constants.
(11-16-2017 07:09 AM)StephenG1CMZ Wrote:  Using type instead of TYPE even though I am in PPL not CAS doesnt seem to help
BEGIN
 PRINT();
END;
What am I missing?
From playing around a bit, it looks like it's necessary to:
1. Call the CAS type function with “CAS.type()”
2. Don't subtract 1 from the DOM_* constants you're comparing to (I'm not sure why you're doing that)
The PPL TYPE() function appears to returns a different set of values, so comparing its return values to the DOM_* constants isn't appropriate. If you really want to avoid using a magic number there, you could either define your own named constants in your program, or you could possibly use something like:
IF TYPE(SOMEVAR) == TYPE(123.4) // Check for real
IF TYPE(SOMEVAR) == TYPE("string") // Check for string
etc.
11-19-2017, 08:00 AM (This post was last modified: 11-20-2017 06:43 AM by StephenG1CMZ.)
(11-19-2017 03:05 AM)TravisE Wrote:  If I understand the OP correctly, they want to compare the types without directly using numeric constants.
BEGIN
 PRINT();
END;
What am I missing?
etc.
Thanks for that tip.
Using IF TYPE(...)==TYPE(1.2) etc. Seems the best way to avoid using constants like 3-1, or even DOM_STRING, which can lead you astray.
To avoid having a 1.2 here and a PI there, which would be distracting, I'd perhaps use
MY_DOM_FLOAT==TYPE(1.2)
IF TYPE(...)==MY_DOM_FLOAT
11-20-2017, 04:38 AM
* In Home
[Image: 38502735732_661645192a_o.png]
IF TYPE(VAR)=0 THEN ... //REAL
IF TYPE(VAR)=1 THEN ... //INTEGER
IF TYPE(VAR)=2 THEN ... //STRING
IF TYPE(VAR)=6 THEN ... //LIST
* In Home with type (CAS)
[Image: 38534358291_0d5831448e_o.png]
[Image: 38502735592_87940e5c55_o.png]
IF CAS.type(VAR)=1 THEN ... //REAL
IF CAS.type(VAR)=DOM_FLOAT THEN ... //REAL
IF CAS.type(VAR)=12 THEN ... //STRING
IF CAS.type(VAR)=DOM_STRING THEN ... //STRING
IF CAS.type(VAR)=7 THEN ... //LIST
IF CAS.type(VAR)=DOM_LIST THEN ... //LIST
Viga C | TD | FB
