Bugs: EMU48 V1.59
11-16-2017, 12:34 PM
Bugs: EMU48 V1.59
Hello, there are two errors in the latest versions of emu48 (1.59) and emu48+
1: when capturing the screen, with zoomXY, different of 2x2, this capture always with zoom1x1 2: emu48 is not working with zoomXY different of 2x2 Suggestion for next release: ZoomXY can be changed from the menu bar, with the purpose of making the screen capture in several dimensions, without having to change KML script Thanks http://hp.giesselink.com/emu48.htm |
11-17-2017, 02:17 PM
RE: Bugs: EMU48 V1.59
(11-16-2017 12:34 PM)compsystems Wrote: Hello, there are two errors in the latest versions of emu48 (1.59) and emu48+ I don't like generalizing. To 1:, this is a known bug in all versions and already fixed in my classic 1.60 sources. To 2:, this is incorrect, Emu48 v1.59 and Emu48+ v1.58 from the Debug4x package work properly. Affected is Eric's Emu48+ v1.57 distribution on hpcalc.org Christoph |
11-17-2017, 04:05 PM
(This post was last modified: 11-18-2017 02:07 AM by compsystems.)
2: is true, the latest version available of emu48plus on debug4x.com (V 2.2 Build 168d) is ok
____ Another idea, we wish emu48 multilanguage, please CG can support by means of a file (spn.txt, eng.txt, frn.txt, ger.txt) that reads the text strings from the menus of the toolbar. new keyword: language PHP Code: Global Thanks |
