Can any Micro-USB cable be used with Swiss Micro calcs?
11-28-2017, 08:11 AM
Can any Micro-USB cable be used with the DM15L or the DM42? Would the cable from my HP Prime work or do I have to get the cable available at the Swiss Micro web site...
11-28-2017, 08:41 AM
RE: Can any Micro-USB cable be used with Swiss Micro calcs?
I know that random micro USB cables work with my DM15C; I believe that these cables are standard.
Nigel (UK)
11-28-2017, 01:00 PM
(11-28-2017 08:11 AM)zeno333 Wrote:  Can any Micro-USB cable be used with the DM15L or the DM42? Would the cable from my HP Prime work or do I have to get the cable available at the Swiss Micro web site...
Please note that the DM15L requires a miniUSB cable and the DM42 a microUSB cable.
The microUSB cable that came with your HP Prime should work fine on the DM42.
11-28-2017, 02:58 PM
I've discovered (after MUCH frustration), that some micro USB cables do NOT have the data lines connected. I believe these cables came with one of the rechargable external batteries - the ones that are marketed for keeping your cell phone alive.. These cables, while physically appearing like a normal micro USB cable will NOT work to upgrade the DM42.
TomC
11-28-2017, 11:19 PM
(11-28-2017 02:58 PM)TomC Wrote:  I've discovered (after MUCH frustration), that some micro USB cables do NOT have the data lines connected. I believe these cables came with one of the rechargable external batteries - the ones that are marketed for keeping your cell phone alive.. These cables, while physically appearing like a normal micro USB cable will NOT work to upgrade the DM42.
TomC
That's my experience too: some cables are only suitable for charging...
11-29-2017, 12:19 AM
TomC
Dedicated USB wall chargers with higher charging current signal devices of their higher current capability by having the data lines in the cable shorted together. Consequently, these charge-only cables won't work for data.
11-30-2017, 04:21 AM
I use a Micro-USB cable for a HP Prime to update the firmware on my DM42 and have no issues doing so.
