Function "contains" in HOME and CAS
01-02-2018, 03:15 PM
I've found a different behavior of the function "contents" in HOME and CAS, in the following situation:
L1:={"A","B"} In CAS contains(L1,"A") -> 1 contains(L1,"B") -> 2 In HOME contains(L1,"A") -> 0 !!! contains(L1,"B") -> 0 !!! |
01-02-2018, 03:18 PM
RE: Function "contains" in HOME and CAS
its name is in lowercase, so I think it should be only a CAS command (not Home)...
∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-02-2018, 03:27 PM
RE: Function "contains" in HOME and CAS | |||
01-02-2018, 03:29 PM
The lower case [CAS] command can work the same way in [Home] if you provide a CAS wrapper:
[CAS] contains(L1,"A"); ==> 1 [Home] CAS(contains(L1,"A")); ==> 1 |
01-02-2018, 06:18 PM
(This post was last modified: 01-02-2018 06:22 PM by JMB.)
Ok, I realize that the safe way to execute a CAS function in HOME is to use the structure CAS(CAS_function).
What still bothers me is that you can use the CAS function directly in HOME and, depending on the arguments, get correct or incorrect results. As I said before, when L1 contains numbers instead of strings "contains" works correctly both in HOME and CAS. |
01-02-2018, 06:32 PM
01-08-2018, 06:10 AM
home contains(L1, "A") will cause A to be parsed as a CAS command line before the switch to CAS mode and the execution of contains. Assuming that the var A contains 0, what you execute is: contains(L1,0). CAS(contains(L1,"A")) will not cause a parse of the string. Subtelties of HOME/CAS interraction :-) Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
01-08-2018, 07:00 AM
01-08-2018, 07:56 AM
(This post was last modified: 01-08-2018 07:57 AM by Carlos295pz.)
It is as indicated by Cyrille, it is due to the topic of Home/CAS interaction, since strings are interpreted by using CAS commands such as contains, head, solve, etc. (similar post http://www.hpmuseum.org/forum/thread-8149.html)
It can be said that all CAS functions (~ lowercase commands) will present this interpretation of a string data. This article Home/CAS-Spanish may be useful. Correct use under this consideration: CAS(contains(L1,"A")) contains(L1,("A")) contains(L1,'"A"') contains(L1,"A"+"") LOCAL Strg="A" contains(L1,Strg) Viga C | TD | FB |
