saving generall equation to Hp prime
01-30-2018, 08:33 AM
hello
how/where can i save a list of generall math equation to the hp prime calculater for later use ? thanks |
01-30-2018, 06:22 PM
RE: saving generall equation to Hp prime
(01-30-2018 08:33 AM)Hamada-77 Wrote: hello You can enter your equations into any one of the Symb views of the various apps. For example, if you enter your formulas in the Solve app's Symb view, then you can copy that app into a new app and save it under a new name. There are also custom applications that will enable you to create your own custom library of equations if you check the HP Prime Software Library section. Graph 3D | QPI | SolveSys |
