(50g) Möbius function (MOB)
03-16-2018, 02:34 PM
(This post was last modified: 03-16-2018 02:49 PM by Joe Horn.)
The Möbius function, used in number theory, usually written as μ(n) but called MOB(n) here, is defined thus:
Code: \<< BYTES: 132.5 #2EE7h <0|ɸ|0> -Joe- |
03-16-2018, 03:26 PM
(This post was last modified: 03-16-2018 10:58 PM by Luigi Vampa.)
RE: (50g) Möbius function (MOB)
Thanks for sharing. Your PDQ is more practical for good, but MOB certainly gives food for thought to avoid any prospect cognitive starvation! :O)
Saludos Saluti Cordialement Cumprimentos MfG BR + + + + + Luigi Vampa + Free42 '<3' I + + |
03-16-2018, 07:25 PM
(03-16-2018 02:34 PM)Joe Horn Wrote: The Möbius function, used in number theory, usually written as μ(n) but called MOB(n) here, is defined thus... Neat program, Joe, and well done! I recognize a couple of the sequences from having worked on a certain library lately. But while I can understand your code, I'm afraid the wikipedia function description leaves my head spinning as to what you might intend to do with this now that you have it. Are you using it for something special? Or would that description leave my head spinning the opposite direction? |
03-17-2018, 05:58 AM
Here a Sys version of the important function:
Size: 102. CkSum: # 22A4h Code: :: |
03-17-2018, 02:06 PM
(This post was last modified: 03-17-2018 02:08 PM by Joe Horn.)
(03-16-2018 07:25 PM)DavidM Wrote:(03-16-2018 02:34 PM)Joe Horn Wrote: The Möbius function, used in number theory, usually written as μ(n) but called MOB(n) here, is defined thus... Short answer: I use it mostly when playing around with multiplicative functions, as explained here: https://brilliant.org/wiki/mobius-functi...s-function Here's an interesting blog posting about it: https://rjlipton.wordpress.com/2011/02/2...-function/ Long answer: When playing with numbers, I always write tiny RPL routines to perform snippets of the task at hand. These are used at the time but soon abandoned and forgotten about. Such routines accumulate in RAM, and I hate to purge them because I know they were useful once upon a time, but I no longer remember what they are for. For example, the following routine is currently in my 50g, called 'PR.2' (on page 50 of my HOME directory): \<< NPR \GSLIST OVER MODSTO EXPANDMOD OVER EULER MOB \>> It calls MOB... but I have NO IDEA what it was intended for, nor what its name meant. Its first command is NPR, which is a global label, which no longer exists in my 50g! Many such ghosts haunt my 50g's RAM. I also have a few other routines that call MOB, as well as routines that call THOSE routines, and so on... but I don't remember what any of them are for. They are playthings which were abandoned and forgotten as new playthings were discovered. Just goes to show that HP 50g memory is more tenacious than my own brain's memory. I suspect that many MoHPC members have similar experiences. <0|ɸ|0> -Joe- |
03-17-2018, 09:38 PM
(03-16-2018 02:34 PM)Joe Horn Wrote: The Möbius function, used in number theory, usually written as μ(n) but called MOB(n) here, is defined thus: I wrote a similar program a few years ago for a similar reason (playing around with number theory). It is longer but also quite a bit faster: Code:
I imagine that an even faster program could be made by combining aspects of both programs, and I may give it a shot when I have some spare time. However, I'm sure that Gerald's sysRPL version will put both of ours to shame! John |
03-17-2018, 11:12 PM
(03-17-2018 02:06 PM)Joe Horn Wrote: I suspect that many MoHPC members have similar experiences. Guilty of the same. For this reason I normally have also a notebook as "log" of what I am doing. If possible then I write the reference to the log in a string or comment. Like "this dir (playthings grouped) was used for the test on the 2018-03-18" . Then I check the log related to that date and I find some useful info, if I wrote them down properly. Also with the 50g one can do tons of backups using the SD. With other systems I do not know. Wikis are great, Contribute :) |
03-18-2018, 06:08 AM
(This post was last modified: 03-18-2018 06:35 AM by Joe Horn.)
(03-17-2018 09:38 PM)John Keith Wrote: I wrote a similar program a few years ago for a similar reason (playing around with number theory). It is longer but also quite a bit faster... Yowza! I had thought that using FACTORS would be faster than using FACTOR because the former is faster... but that's not the only factor here (as it were). Good job! EDIT: (03-17-2018 09:38 PM)John Keith Wrote: However, I'm sure that Gerald's sysRPL version will put both of ours to shame! Yep. Timing for input of 12345678: Joe: 0.247_s John: 0.177_s Gerald: 0.041_s Gerald's shines even brighter on things like large factorials. Try 20! to see what I mean. <0|ɸ|0> -Joe- |
