OEIS A229580 mini challenge (RPL)
05-01-2018, 06:47 AM
Write an RPL program to compute the elements of OEIS sequence A229580, the shorter and faster the better.
Examples: 1 -> 1 18 -> 300647710720 30 -> 8502796096475496448 (0.0619 on the 50g in exact mode) Currently 37.5 bytes. |
05-01-2018, 07:48 AM
(This post was last modified: 05-01-2018 09:34 AM by Joe Horn.)
RE: OEIS A229580 mini challenge (RPL)
Oh dear... 81 bytes, same answers for 1 and 30, but 0.0989_s for 30. I used a local variable and an algebraic expression. I suspect that you wrote it using only the stack. I gotta see that.
EDIT: Rewrote using just the stack, but it only shrank to 50 bytes, and takes 0.0792_s for an input of 30. Hmmmm..... EDIT 2: Down to 47.5 bytes, 0.0778_s for an input of 30. You are keeping me up all night! <0|ɸ|0> -Joe- |
05-01-2018, 11:40 AM
(This post was last modified: 05-01-2018 11:41 AM by Gerson W. Barbosa.)
(05-01-2018 07:48 AM)Joe Horn Wrote: Oh dear... 81 bytes, same answers for 1 and 30, but 0.0989_s for 30. Great! This means you’ve found a much better formula than the one at OEIS. That’s what really matters here. (05-01-2018 07:48 AM)Joe Horn Wrote: EDIT: Rewrote using just the stack, but it only shrank to 50 bytes, and takes 0.0792_s for an input of 30. Hmmmm..... 52.5 bytes, 0.0980 s; 50 bytes, 0,1000 s. My first and second attempts, respectively. Times change slightly at each run. (05-01-2018 07:48 AM)Joe Horn Wrote: You are keeping me up all night! That was not my intention, sorry! It was almost 4:00 AM here when I posted. Perhaps I should’ve waited a few hours more, but then again someone else would lose sleep over this little problem. I wish you all have a nice Sunday! Gerson. |
05-01-2018, 11:51 AM
For n > 2 on
a(n) = 4*(a(n-1)) + 4^(n-1) but I find neither a small programme nor one as fast as yours. |
05-01-2018, 11:56 AM
(05-01-2018 11:51 AM)Gerald H Wrote: For n > 2 on SPOILER ALERT. A non-recursive, direct function of n exists. Examining the sequence's prime factors reveals it. <0|ɸ|0> -Joe- |
05-01-2018, 12:11 PM
Thank you, Joe.
Programme now has size 37.5 Bytes CkSum F06B h |
05-01-2018, 12:19 PM
But same size programme with
CkSum 3095 h is faster. |
05-01-2018, 12:30 PM
(This post was last modified: 05-01-2018 12:31 PM by Gerson W. Barbosa.)
RE: OEIS A229580 mini challenge (RPL) | |||
05-01-2018, 12:33 PM
05-01-2018, 02:10 PM
(05-01-2018 12:19 PM)Gerald H Wrote: But same size programme with I guess you mean because the code producing that checksum is different... But it had me wondering whether a program can access its own checksum and use it to save a few bytes/cycles? I wonder if that has ever been useful? Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
05-01-2018, 05:22 PM
(This post was last modified: 05-01-2018 05:25 PM by Gerson W. Barbosa.)
RE: OEIS A229580 mini challenge (RPL & RPN)
Changing target. Eight steps on the wp34s (not counting LBL and END).
05-01-2018, 06:07 PM
RE: OEIS A229580 mini challenge (RPL and RPN *and* HP-71B)
Hi, Gerson: (05-01-2018 06:47 AM)Gerson W. Barbosa Wrote: Write an RPL program to compute the elements of OEIS sequence A229580, the shorter and faster the better. Since you just changed the Subject to include RPN, I'm changing it again to include the HP-71B, I hope you won't mind. This is how I solved your challenge with my HP-71B: The sequence is: 1,6,40,224,1152,5632,26624,122880,557056,... 1) I ran my LINREC program to find the recurrence (and see if it agrees with the one given in the OEIS page), ignoring the first term (1) as the OEIS page warns us that the recurrence doesn't apply to it: >CAT LINREC BASIC 540 bytes >RUN ? 6,40,224,1152 2-term recurrence: a(n) = 8*a(n-1)-16*a(n-2) 6,40,224,1152,5632,... As can be seen, my program found the correct recurrence and for checking purposes it produced an additional term which fully agrees with the sequence. 2) Thus, the characteristic polynomial for this recurrence is a\(^2\)-8*a+16 = 0 which has a double root 4, so the explicit formula is of the form: a(n)=(k1+k2*n)*4\(^n\) for some constants k1 and k2 which can be computed from the initial terms (or any two others) as follows: n=2 => (k1+2*k2)*16 = 6 n=3 => (k1+3*k2)*64 = 40 and solving this trivial system we get k1=-1/8, k2 = 1/4 so the explicit formula is: if n=1 then a(1) = 1 else a(n) = (-1/8+1/4*n)*4\(^n\) = (4*n-2)*4\(^{n-2}\) which takes essentially zero time for any n, no matter how big. 3) Let's check it: >FOR N=2 TO 18 @ N;(4*N-2)*4^(N-2) @ NEXT N 2 6 3 40 4 224 5 1152 6 5632 7 26624 8 122880 9 557056 10 2490368 11 11010048 12 48234496 13 209715200 14 905969664 15 3892314112 16 16642998272 17 70866960384 18 300647710720 And, of course, the trivial HP-71B user-defined function would be: 1 DEF FNA(N) = (4*N-2)*4^(N-2) Regards. V. . All My Articles & other Materials here: Valentin Albillo's HP Collection |
05-01-2018, 07:05 PM
05-01-2018, 07:40 PM
(This post was last modified: 05-01-2018 07:43 PM by Gerson W. Barbosa.)
Hello, Valentin,
Thank you very much for you valuable contribution! (05-01-2018 06:07 PM)Valentin Albillo Wrote: . Of course not! This should have been opened to other calculators in the first place, my bad. As I said, more important than the resulting optimization was the better formula the participants would eventually come up with. My first attempt using your formula gives me 40 bytes on the hp 50g, but others may improve on that. By factoring the first few elements, I have obtained an = (2n - 1)*2^(2n - 3), which is probably the same formula Joe has come up with, since he used the same method I did. Both formulas are of course equivalent and hopefully will make for even better optimizations on the original target. Best regards, Gerson. |
05-01-2018, 08:18 PM
Mine is 40 bytes, checksum FEB4h. Time for A(30) is .0527 seconds.
05-01-2018, 08:56 PM
(05-01-2018 07:40 PM)Gerson W. Barbosa Wrote: Hello, Valentin, Your formula returns 1/2 for input 1 |
05-01-2018, 09:12 PM
(This post was last modified: 05-01-2018 09:14 PM by Gerson W. Barbosa.)
(05-01-2018 08:56 PM)Gerald H Wrote:(05-01-2018 07:40 PM)Gerson W. Barbosa Wrote: Hello, Valentin, The first element in the sequence is anomalous. The formula is valid for n > 1, but you are right, I’ve forgotten to mention that. Fortunately a simple built-in function, available on the wp34s as well, will turn that fraction into the right integer while keeping all the remaining elements unchanged, as we are aware of. |
05-01-2018, 11:05 PM
(05-01-2018 07:40 PM)Gerson W. Barbosa Wrote: By factoring the first few elements, I have obtained an = (2n - 1)*2^(2n - 3), which is probably the same formula Joe has come up with, since he used the same method I did. Correct. My final attempt (before going to bed) was: << DUP + 1 - 2 DUP2 - ^ * CEIL >> BYTES: 35.0 #D66Dh 0.057_s for an input of 30 (on my 50g). <0|ɸ|0> -Joe- |
05-01-2018, 11:08 PM
05-01-2018, 11:21 PM
(05-01-2018 11:05 PM)Joe Horn Wrote:(05-01-2018 07:40 PM)Gerson W. Barbosa Wrote: By factoring the first few elements, I have obtained an = (2n - 1)*2^(2n - 3), which is probably the same formula Joe has come up with, since he used the same method I did. Very nice! Here is my (now) lengthy one: « DUP + 3 - 2 SWAP ^ LASTARG + * CEIL » 37.5 bytes, 0.062 s, #296Fh Glad the 37.5-byte barrier has been broken! |
