CMT MC-II 8088 CMOS System
05-06-2018, 06:49 PM
I was at an hamfest this morning and picked up a CMT MC-II 8088 CMOS System manufactured by Corvallis Microtechnology. It's a handheld device that has the following modules:
four 128KB SRAM MC-ROS MC-41M I put five AA batteries in it and it does power up. But now I am at a loss. When it first powered up, I had a menu of items. I then ran the 41M module and that seems to be an emulation of the HP-41 calculator. Not sure now how to get back to the main menu. It only came with a hard leather case - no manuals. It looks like it would support keyboard overlays that would probably be a big help in using it. The top of the unit has two RJ-45 jacks. On the back is a covered connector. I just pulled the batteries and reinserted them and am now back as a list of items. There are a bunch of ".S" filenames (41M.S, OFF.S,KEYBEEP.S, TIME.S, DATE.S, MODE.S, etc), then KERMIT.X, MCED.X, CMD.X, CMT-ROSS. Then it says Bytes Free - 16016. Which seems odd, since there are supposedly four 128KB modules installed. Does anyone have any information - manuals, overlays etc. Thanks, Bill Smithville, NJ |
05-06-2018, 08:36 PM
(This post was last modified: 05-09-2018 12:49 AM by Sylvain Cote.)
RE: CMT MC-II 8088 CMOS System
Hello Bill,
This device is using a modified version of MS-DOS for its OS. (05-06-2018 06:49 PM)Bill (Smithville NJ) Wrote: There are a bunch of ".S" filenames (41M.S, OFF.S,KEYBEEP.S, TIME.S, DATE.S, MODE.S, etc), then KERMIT.X, MCED.X, CMD.X, CMT-ROSS..S are script files (similar to .BAT) and .X are executable files (like .exe) (05-06-2018 06:49 PM)Bill (Smithville NJ) Wrote: Then it says Bytes Free - 16016. Which seems odd, since there are supposedly four 128KB modules installed.That is the free space left in the MC-ROS 128KB EPROM module I have made available for a limited time this file: CMT-MCII-Documents.zip It contains these files:
To leave the 41M environment type: [XEQ] [ALPHA] [S] [Y] [S] [T] [E] [M] [ALPHA] FYI, in the 41M environment: [XEQ] is on the [K] key and [ALPHA] is on the [up arrow] key Sylvain edit: URL for zip file has been reactivated. |
05-06-2018, 10:17 PM
Hello Sylvain,
I have downloaded the zip file. Thank you very much. This is a big help on understanding this very interesting computer. From a quick read of the manual, the 41M module creates a super HP-41CX - very large memory storage, register access, and many other added commands. Hopefully some here will have a copy of the 41M manual. Thanks again for the files. Bill Smithville, NJ (05-06-2018 08:36 PM)Sylvain Cote Wrote: Hello Bill, |
05-08-2018, 06:20 AM
RE: CMT MC-II 8088 CMOS System | |||
05-08-2018, 10:40 AM
(This post was last modified: 05-09-2018 12:50 AM by Sylvain Cote.)
