Summation based benchmark for calculators - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Summation based benchmark for calculators (/thread-9750.html) |
RE: Summation based benchmark for calculators - Guenter Schink - 04-22-2021 06:33 PM I think we have new champion -- by quite a margin Prime G2 Beta 2.1.14549 using Python Code: #PYTHON name From the Home screen invoke this Python program with sums(?) where "?" question mark has to be replaced by the exponent which denotes the magnitude
Output will be the exponent, the resulting number, the time and the sum. E.g. 3 1000 0.036 sec 1395.3462877433426 Code: Results: I think that's quite impressive specifically when compared with the values for native PPL. Günter Edit: put the timing into the Python code rather than using TEVAL RE: Summation based benchmark for calculators - OlidaBel - 05-01-2021 09:18 AM Something new to me, maybe a lack of Prime knowledge. My Prime is configured in RPN (for stack Home computations). I tried the sum "benchmark" proposed here, then Pick (copy) the first formula to modify it in the command line, I want to run a bigger one, from a 1000 to 10000 sum. I only added a zero behind "1000", the Editor refuses to validate the formula. Why ? https://ibb.co/wgZJbrL https://ibb.co/VD2Wzp6 https://ibb.co/WfpDSGv RE: Summation based benchmark for calculators - pier4r - 08-05-2021 04:06 PM Finally updated up to post #221 (yay after years! Well priorities...) It took more than 2 hours, so it wasn't that trivial. Updated also here: http://www.wiki4hp.com/doku.php?id=benchmarks:sum_trig_exp_root and here: https://osdn.net/users/pier4r/pf/various_works_only_code/scm/blobs/master/rpl_hp48-50/wiki_notes_backup/summation_based_benchmark.txt I am not so sure about some results regarding 500k with the prime G2. Now you all need to add more entries so that I have to catch up again RE: Summation based benchmark for calculators - Guenter Schink - 08-08-2021 10:59 AM (08-05-2021 04:06 PM)pier4r Wrote: Finally updated up to post #221 (yay after years! Well priorities...) The HP Expander (not XP Expander) is a calculator from HP, not a mobile device. It never saw the light of the markets. I've got a prototype at one of the HHCCs. Günter RE: Summation based benchmark for calculators - Massimo Gnerucci - 08-08-2021 11:03 AM (08-08-2021 10:59 AM)Guenter Schink Wrote: The HP Expander (not XP Expander) is a calculator from HP, not a mobile device. But I think it never saw the light of the markets. I've got a prototype at one of the HHCCs. It actually was "HP Xpander". Have a couple, from different development stages. RE: Summation based benchmark for calculators - Guenter Schink - 08-08-2021 11:44 AM (08-08-2021 11:03 AM)Massimo Gnerucci Wrote:(08-08-2021 10:59 AM)Guenter Schink Wrote: The HP Expander (not XP Expander) is a calculator from HP, not a mobile device. But I think it never saw the light of the markets. I've got a prototype at one of the HHCCs. Thanks for the correction. I could have had a closer look either to the device or the Wiki article Günter RE: Summation based benchmark for calculators - Felix Stehli - 08-12-2021 08:00 AM ThetaCalc, an RPN calculator app running on iOS which can be programmed in JavaScript, produced the following result for n = 1000000 on an iPhone 12: HP museum benchmark (n = 1000000) Sum = 1395612.1587253837 Time = 0.189 seconds I don't know, however, whether the app fits into one of the given categories. Here is the program: Code: function benchmark(n) { RE: Summation based benchmark for calculators - Marc van Lemmen - 08-17-2021 11:04 PM I recently received a Sharp PC-1201 and was currious how this nice little machine would perform, here are the results : N=10 ~25s result 13,318529402 N=100 ~285s result 138,90159786 N=1000 ~2844s result 1394,95067416 RE: Summation based benchmark for calculators - toml_12953 - 08-17-2021 11:23 PM (04-22-2021 06:33 PM)Guenter Schink Wrote: I think we have new champion -- by quite a margin When I copy and paste that code into the emulator, I get Code: Traceback (most recent call last): File "<stdin>", line 5, in <module> RE: Summation based benchmark for calculators - Guenter Schink - 08-18-2021 03:09 PM (08-17-2021 11:23 PM)toml_12953 Wrote:(04-22-2021 06:33 PM)Guenter Schink Wrote: I think we have new champion -- by quite a margin I just also copied it to the virtual Prime. works flawlessly. (?) The error actually points to line 6 "c=int(sys.argv[0])" Can't assume what's going wrong. Günter RE: Summation based benchmark for calculators - toml_12953 - 08-18-2021 04:01 PM (08-18-2021 03:09 PM)Guenter Schink Wrote:(08-17-2021 11:23 PM)toml_12953 Wrote: When I copy and paste that code into the emulator, I get I had digit grouping set to 123,456.789. When I change it to 123456.789, I don't get an error but I get a lot of zeroes on the screen and what may be an infinite loop. RE: Summation based benchmark for calculators - Guenter Schink - 08-18-2021 06:56 PM (08-18-2021 04:01 PM)toml_12953 Wrote: I had digit grouping set to 123,456.789. When I change it to 123456.789, I don't get an error but I get a lot of zeroes on the screen and what may be an infinite loop. o.K. I think I found the problem. It wasn't clearly explained. You have to enter the exponent rather then the number. E.g. enter 3 to get 1000 iterations. Have a look at the code and now it should become obvious. I chose this because "sys.argv[0]" doesn't seem to work reliably with numbers greater 999. Consequently if it works somehow, the first output is a digit with as many zeros as requested, and that output takes a while. Günter edit: I just realized that I can't run the program from the command line I had to go to the program catalog <SHIFT> <1> and run it fro there RE: Summation based benchmark for calculators - toml_12953 - 08-18-2021 07:18 PM (08-18-2021 06:56 PM)Guenter Schink Wrote:(08-18-2021 04:01 PM)toml_12953 Wrote: I had digit grouping set to 123,456.789. When I change it to 123456.789, I don't get an error but I get a lot of zeroes on the screen and what may be an infinite loop. Oof! Es tuit mir leid! Yes, an exponent of 1000 would take a long time! Thank you for replying. RE: Summation based benchmark for calculators - pier4r - 11-27-2022 10:34 AM Updated up to post #233 Also the HP Xpander name and category fixed. Hopefully I didn't miss anything. RE: Summation based benchmark for calculators - BINUBALL - 01-24-2023 01:12 PM I have bought newer casio model, fx-570CW several months ago and reminded this thread. Test results below: max = 10000 ~ 581s - casio fx-570CW, 13955.8579 (sum function) max = 1000 ~ 59s - casio fx-570CW, 1395.346288 (sum function) max = 100 ~ 7s - casio fx-570CW, 139.297187 (sum function) max = 10 ~ 1s - casio fx-570CW, 13.71183502 (sum function) fx-570CW is significantly faster than fx-570EX. Let's compare them. 1s / 2s (max = 10) 7s / 12s (max = 100) 59s / 109s (max = 1000) 581s / 1073s (max = 10000) RE: Summation based benchmark for calculators - BINUBALL - 01-28-2023 09:22 AM Tested with HP-200LX too. max = 10000 ~ 257s - HP-200LX turbo c 2.01, 13955.857904 max = 1000 ~ 27s - HP-200LX turbo c 2.01, 1395.346288 max = 100 ~ 4s - HP-200LX turbo c 2.01, 139.297187 max = 10 ~ 2s - HP-200LX turbo c 2.01, 13.711835 Code: #include <math.h> RE: Summation based benchmark for calculators - Eddie W. Shore - 04-05-2023 12:53 PM Σ( ³√[e^(sin(tan^-1(x)))], x=1 to 1000) Casio fx-991CW: Result: 1395.346288 Time: approx. 57 seconds TI-30X Pro MathPrint (Europe): Result: 1395.346288 Time: approx. 1 minute, 44 seconds RE: Summation based benchmark for calculators - Guenter Schink - 04-05-2023 08:01 PM Once again Python on PRIME This time using "Generator" Code: from math import * significantly faster than the previous published Python code (Top of this page). The calculation is done in this one-liner: >>Sum = sum(pow(e**(sin(atan(i))),1/3) for i in range(1,Number+1)) << Code: 10,000 -> 0.101 sec 13955.8579042916 Günter RE: Summation based benchmark for calculators - gehakte_bits - 04-10-2023 02:13 PM HP Prime G2 V.14603 Python ========================== 100.000 -> 0.84s 1.000.000 -> 8.4s 10.000.000 -> 84.1s optimized post #238: x=1/3 Sum = sum(exp(sin(atan(i)))**x for i in range(1,Number+1)) RE: Summation based benchmark for calculators - Mike T. - 04-10-2023 10:21 PM (01-28-2023 09:22 AM)BINUBALL Wrote: Tested with HP-200LX too. Couldn't resist trying this on a modern PC... Code:
