emu48 now for android-OS - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: emu48 now for android-OS (/thread-12540.html) |
RE: emu48 now for android-OS - John Keith - 04-02-2019 06:29 PM I just installed the app on my phone and I have to say it is amazing! It is noticeably faster on my phone (a year-old Samsung Galaxy running Android 9) than on my 2.6GHz Windows 7 PC! I have run into one problem however. All of the settings related to Ports are grayed out, and any objects stored in Port 2 are lost when the app is closed. I use several libraries and I like to store them in ports so that they do not detract from main RAM. Is there (or will there be) a fix for this? RE: emu48 now for android-OS - Lode - 04-04-2019 07:53 AM The previous version (before 14 march update I think) of the app had black background (or at least one that was not noticeable, which was good), now it's bright gray (there are now two thick bright gray borders left light and right on android, for all built in calculators/skins/kml files) I liked it much better without the bright gray, is there a way to get rid of it again, for all built in ones? (preferably a global setting, no fiddling with all individual kml files an android please ) RE: emu48 now for android-OS - ijabbott - 04-04-2019 12:16 PM (03-27-2019 05:16 PM)Christoph Giesselink Wrote:(03-25-2019 09:25 AM)Marco Polo Wrote: Installed on an Honor 7x (Android 8). I wonder why BOOL was defined as signed char for the Android build? If it was for iOS I could maybe understand it. EDIT: It looks like the problem is fixed in the GitHub master branch now thanks to compatibility patches from Christoph! RE: emu48 now for android-OS - Thomas Okken - 04-04-2019 01:05 PM (04-04-2019 12:16 PM)ijabbott Wrote: I wonder why BOOL was defined as signed char for the Android build? If it was for iOS I could maybe understand it. To save space? Using a 32-bit type of which you're only using one bit is rather wasteful. Using an 8-bit quantity is still wasteful, but a common compromise since it's usually the smallest addressable unit. In early C, there was no dedicated Boolean type, so they used int instead, with the convention of saying 0 = false and 1 = true (or any nonzero value). This convention survived for a long time, because it took so long before C adopted bool -- I think bool only became an official part of C in the C99 standard. In Free42 I used int for bool originally for that exact reason. When I changed the project from C to C++, I started using bool instead of int where appropriate, but mostly in new code, leaving old code alone. Replacing int with bool made data structures more compact, but it also caused compatibility headaches where data structures are persistent, i.e. in the state file. RE: emu48 now for android-OS - Eddie W. Shore - 04-04-2019 01:39 PM Amazing, thank you. I really like the HP 48S skin. RE: emu48 now for android-OS - Eric Rechlin - 04-04-2019 05:47 PM (04-04-2019 07:53 AM)Lode Wrote: The previous version (before 14 march update I think) of the app had black background (or at least one that was not noticeable, which was good), now it's bright gray (there are now two thick bright gray borders left light and right on android, for all built in calculators/skins/kml files) Since 1.2 (I think) it now respects the Color attribute in the KML file, which is currently often the gray value that I set them to in my original scripts, which was good for their original intended desktop use, but admittedly is not ideal for the Android version. The next version, 1.3, now lets you set Emu48 for Android to either use the KML's default color (gray in this case), or black, or the status bar color (which is a dark shade of gray, almost black, on my phone). I just verified this with the code currently in github (but not yet released) and it works as expected. So just wait for 1.3 and it should work better. RE: emu48 now for android-OS - Lode - 04-04-2019 07:06 PM An update also changed rom 2.15 into 2.10. Does that mean 2.10 is actually better? RE: emu48 now for android-OS - compsystems - 04-04-2019 07:19 PM For CG, request for emu48 source The LCD of the calculators, really have in a fixed state of contrast three colors, background, pixel off, and pixel on, the color of pixel off is not the same background color, for this reason you need to add a new parameter on Lcd-End block, color -1 R G B PHP Code: Lcd Thanks RE: emu48 now for android-OS - ijabbott - 04-04-2019 07:51 PM (04-04-2019 07:19 PM)compsystems Wrote: For CG, request for emu48 source The source for the Android version is on GitHub: https://github.com/dgis/emu48android RE: emu48 now for android-OS - rprosperi - 04-05-2019 12:25 AM My phone just updated to v1.3, so it's available now. RE: emu48 now for android-OS - Vincent Weber - 04-06-2019 03:04 PM Works great now, no more speed/display problems, and haptic feedback is great, congrats and thanks ! Only bug I could find, on the SX at least the calculator clock becomes quickly desynchronized with the Android clock... Anyway to readjust every time the app is back in the foreground ? RE: emu48 now for android-OS - SammysHP - 04-08-2019 11:01 AM When emulating a 50g with 1.3 I'm not able to store something in port 2. Once I store something in port 2 and restart emu48 (even with explicit save state), the emulated calculator will perform a warmstart and everything in port 2 is lost (except for the default equation library and periodic table). RE: emu48 now for android-OS - Marco Polo - 04-08-2019 11:46 AM (04-08-2019 11:01 AM)SammysHP Wrote: When emulating a 50g with 1.3 I'm not able to store something in port 2. Once I store something in port 2 and restart emu48 (even with explicit save state), the emulated calculator will perform a warmstart and everything in port 2 is lost (except for the default equation library and periodic table).Similar problem here. I copied the state file and rom file (2.15) of my emulated 50g. When i try to open it, the loaded rom is the one provided with the emulator (2.10) and of course with Port 2 empty except equation library and periodic table. Apparently the emulator refuses to load roms not provided with the app. RE: emu48 now for android-OS - John Keith - 04-08-2019 01:29 PM I mentioned the Port 2 issue a few posts back. Hopefully it will be fixed soon. The ROM issue may be due to binary differences between Intel and ARM processors. RE: emu48 now for android-OS - Eric Rechlin - 04-08-2019 03:07 PM (04-08-2019 11:46 AM)Marco Polo Wrote:(04-08-2019 11:01 AM)SammysHP Wrote: When emulating a 50g with 1.3 I'm not able to store something in port 2. Once I store something in port 2 and restart emu48 (even with explicit save state), the emulated calculator will perform a warmstart and everything in port 2 is lost (except for the default equation library and periodic table).Similar problem here. I believe the ROM file used is tied to the KML file. If you want to use a custom ROM, then use a custom KML file that points to that ROM and put both in the same directory. I haven't tried this myself, though. You should probably use 2.10, not 2.15, with the emulator, FYI, because the only difference between the two is some ARM-specific code added for the StreamSmart, which won't work in the emulator. RE: emu48 now for android-OS - SammysHP - 04-08-2019 06:07 PM I opened an issue on GitHub to keep the development process more central: https://github.com/dgis/emu48android/issues/3 Btw: Is there a way to donate via Google Play (paid donation app)? RE: emu48 now for android-OS - Chris Dreher - 04-09-2019 05:32 AM (04-08-2019 06:07 PM)SammysHP Wrote: I opened an issue on GitHub to keep the development process more central: https://github.com/dgis/emu48android/issues/3 Thanks for reminding me that GitHub has a place to enter issues. I'll add mine there. RE: emu48 now for android-OS - Chris Dreher - 04-09-2019 05:41 AM My hope is to see Emu48 at a point where I can mostly retire Droid48 Reader. Android Q is coming and the new security features will prevent Droid48 Reader from reading Droid48's files... unless updates are made to Droid48, which hasn't happened in a few years. I've been expecting the end-of-life of my app to eventually happen given how Google has been tightening security over the past several OS releases. The last several versions of Droid48 Reader only came out to support security updates in Android. If Droid48 and Droid48 Reader can not made compatible again for Android Q, it would be good to have an alternative I can point my users to (i.e. Emu48). My brief initial test drive of Emu48 looked good but I'll need to poke at it a little more. RE: emu48 now for android-OS - Regis Cosnier - 04-15-2019 12:53 PM Hello, This is my first post here in the forum, I'm Régis Cosnier, the author of this port to Android. I'm glad to see this app so well received. Thanks a lot to Eric Rechlin for all the faceplates, ROMs, bug reports and his amazing web site, and to Christoph Giesselink to have found the compatibility issue with the Windows version and above all, its fantastic Emu48 that I use almost every day. Christoph can correct me if I'm wrong, but for the port 2 issue with HP49/50, the flash is written in the ROM file (i.e.: "rom.49g"). By default when you create a new HP49/50 with the embedded readonly file "rom.49g", everything that you store in port 2 is lost just because the file "rom.49g" is READONLY. But it works exactly like with Windows. If you can write in the ROM file, it should save the content of port 2 in the ROM file with Android too. To save the port 2 in the HP49/50 with Emu48 for Android (it works with version 1.3): * copy "real50g-lc.kml", "real50g-lc.png", "keyb4950.kmi", "rom.49g" in a FOLDER of your Android device, * in the menu: ** touch "New..." to create a new device ** or touch "Change KML Script..." to change the current KML script and ROM location * select "[Custom KML script...]" * select the FOLDER * pick the calculator (which should be "Eric's Real 50g (Large Cropped)")! And because, the file "FOLDER/rom.49g" is not readonly anymore, you can save your port 2. I hope it help. Regards, Régis RE: emu48 now for android-OS - ijabbott - 04-15-2019 02:29 PM Hi Régis, Emu48 for Android is very useful, but I have a couple of questions:
Thanks! |
