[Update - G1, Android] Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: [Update - G1, Android] Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS (/thread-13855.html) |
RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Dirk.nl - 10-26-2019 04:50 PM Hi mbeddo, Is this the same as I mentioned in a this post of my? (02-02-2019 09:32 PM)Dirk.nl Wrote: Problem solved. RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - mbeddo - 10-26-2019 05:17 PM (10-26-2019 04:50 PM)Dirk.nl Wrote: Hi mbeddo, Yes. Thank you very much! RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Dirk.nl - 10-26-2019 05:21 PM Okay!! RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - froehlic - 10-26-2019 07:44 PM I have some problems with the new firmware. My Prime is a G1, HW C, OS V0.050.640. After installing the new fw everything seems good as always (I have installed every new fw and beta the past three years). All programs in place. After playing a while I started the python-app. Pressing OK: Prime restarted. Second try starting python-app, calculating something worked as expected but pressing Symb: Restart again. Looking in the connkit (Win10, 64bit) Prime restarted again only opening the programs-tree (or sometimes the apps-tree). I decided to reset the Prime completely (C-F-O - Format, Reset). Instead of restoring an old backup, I only tried to copy one simple program via connkit to the Prime. In connkit the program is visible and I can open it. On the prime the program is in the program library, but only 1k in size and after opening there is nothing! The program file is empty. I also copied a whole HPPRGM. The app is on the Prime, but the corresponding program is empty. The same with all apps I copied! So I restored my Prime back to Firmware 2.1.14181 (2018 10 16) and everything works fine again! So I don't think it's a Hardware problem. Anybody similar problems? RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Eddie W. Shore - 10-27-2019 05:02 PM (10-24-2019 06:04 AM)Tim Wessman Wrote: Hello, Thanks Tim! Hope everything is well with you and the family, Eddie RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Eddie W. Shore - 10-27-2019 05:33 PM The firmware can't be found by the Connectivity Kit (32 bit) at all, no matter what folder I designate as the working folder. I installed the 64 bit, the Connectivity Kit still does not recognize the beta software. I run Windows 10. RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Wes Loewer - 10-27-2019 05:56 PM (10-27-2019 05:33 PM)Eddie W. Shore Wrote: The firmware can't be found by the Connectivity Kit (32 bit) at all, no matter what folder I designate as the working folder. Looks like a typo in the error messages. Too many Firmware's. If Documents/HP Connectivity Kit is your Working folder, then put the firmware files in Documents\HP Connectivity Kit\Firmware\PrimeG1 and Documents\HP Connectivity Kit\Firmware\PrimeG2 RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Eddie W. Shore - 10-27-2019 06:28 PM (10-27-2019 05:56 PM)Wes Loewer Wrote:(10-27-2019 05:33 PM)Eddie W. Shore Wrote: The firmware can't be found by the Connectivity Kit (32 bit) at all, no matter what folder I designate as the working folder. No success. I tried several locations on the C drive. When I click on Check for Update under the Help menu, it doesn't recognize the beta software. Is there a way to update an HP Prime outside of the Kit? RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - mbeddo - 10-27-2019 06:30 PM (10-27-2019 06:28 PM)Eddie W. Shore Wrote:(10-27-2019 05:56 PM)Wes Loewer Wrote: Looks like a typo in the error messages. Too many Firmware's. If In the HP Connectivity Kit, I had to go to the Help menu and choose "Update Calculator". RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Eddie W. Shore - 10-27-2019 06:44 PM I did that too Wes, still no success. RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - mbeddo - 10-27-2019 06:52 PM (10-27-2019 06:44 PM)Eddie W. Shore Wrote: I did that too Wes, still no success. My working folder (Preferences) is "C:/Users/meb/Documents/HP Connectivity Kit". In that folder, I have a "Firmware" subfolder, and under that I have "PrimeG1" and "PrimeG2" subfolders where I unzipped the beta files into. Then I did Help -> Update Calculator and it worked for me. I'm using Windows 10. RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Joe Horn - 10-27-2019 06:56 PM Eddie, in the Connectivity Kit, Preferences, Environment, the "Working folder" should end at "HP Connectivity Kit", and NOT include the "Firmware" subfolder. Mine is set to: C:/Users/Joe/Documents/HP Connectivity Kit Adjust yours appropriately... making sure it ends with "HP Connectivity Kit". EDIT: Oops, mbeddo beat me to it. RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Eddie W. Shore - 10-27-2019 07:08 PM Joe, I was going to copy your post onto this thread, but you beat me to it. Meddo, Joe, Wes; many thanks for your help! Much appreciated, Eddie RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Tim Wessman - 10-28-2019 04:02 AM (10-26-2019 07:44 PM)froehlic Wrote: Anybody similar problems? Yes! An incorrect G1 release that was NOT the one tested got uploaded to Eric. Anyone who installed that prior one, please delete it and put the new one just updated on. You will have extreme instability and lose data using that other one. RE: Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Tim Wessman - 10-28-2019 04:05 AM (10-26-2019 02:24 AM)Tim Wessman Wrote: That RPN this is bizarre.... Do not use the prior version that got uploaded. Immediately update! You will lose data and it will continue to get worse if you use that. The RPN issue was an offset of that untested and incorrect filethat was mistakenly given to Eric. A correct one was updated today! RE: [Update - G1]Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Stevetuc - 10-28-2019 05:45 AM (10-26-2019 07:44 PM)froehlic Wrote: [....].After playing a while I started the python-app. Pressing OK: [...] Python-app? Wasnt aware one existed, or do you mean python syntax in the cas? RE: [Update - G1]Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - pinkman - 10-28-2019 06:38 AM (10-28-2019 05:45 AM)Stevetuc Wrote:(10-26-2019 07:44 PM)froehlic Wrote: [....].After playing a while I started the python-app. Pressing OK: [...] I suspect that leaded Tim to the track of a bad firmware version, because yes there was a Python App, but it disappeared with today's update. RE: [Update - G1]Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - pinkman - 10-28-2019 06:39 AM (10-28-2019 04:05 AM)Tim Wessman Wrote:(10-26-2019 02:24 AM)Tim Wessman Wrote: That RPN this is bizarre.... Updated. RPN does work! RE: [Update - G1]Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - Carlos295pz - 10-28-2019 12:43 PM (10-28-2019 04:05 AM)Tim Wessman Wrote: Do not use the prior version that got uploaded. Immediately update! I just reported that they update the firmware to those who managed to do it, suspense RE: [Update - G1]Public Beta Availiable - Win/Mac/Linux/Firmware/Android/iOS - toml_12953 - 10-28-2019 01:03 PM (10-28-2019 06:38 AM)pinkman Wrote:(10-28-2019 05:45 AM)Stevetuc Wrote: Python-app? Wasnt aware one existed, or do you mean python syntax in the cas? I updated to the latest G1 firmware to eliminate the problem with RPN without trying the python app first. What was it? If it allowed real python code to run on Prime, then I hope HP puts it back in! |
