I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - Printable Version
+--- Forum: Test forum (/forum-18.html)
+--- Thread: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts (/thread-1426.html)
Pages: 1 2
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - EdS2 - 07-12-2014 09:16 PM
we're told annual posting is now sufficient.
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - Gene - 07-13-2014 11:39 AM
Just in case, I hear entropy is not what it used to be.
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - walter b - 07-13-2014 11:40 AM
(07-13-2014 11:39 AM)Gene Wrote:  Just in case, I hear entropy is not what it used to be.
Became a bit chaotic recently.
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - ovael - 08-15-2014 08:52 PM
Here the quoting seems to work... Strange...
Edit. So I couldn't use quote right and I came here to test it.
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - Thomas Radtke - 08-16-2014 07:09 AM
(08-15-2014 08:52 PM)ovael Wrote:  Edit. So I couldn't use quote right and I came here to test it.
Found that post. The Problem is the [Quote] keyword within a quote. It only works outside of it apparently but don't count on it. Generally don't use meta tags without their closing tags.
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - walter b - 08-16-2014 04:03 PM
Correct. I didn't anticipate that somebody would quote that. But there were more tags missing ...
d:-)
RE: I 20 years ago administered a CRAY-Y/MP AKA Meaningless posts - ovael - 08-17-2014 07:52 AM
(08-16-2014 04:03 PM)walter b Wrote:  Correct. I didn't anticipate that somebody would quote that. But there were more tags missing ...
d:-)
Well I couldn't use multiquote since I thought there is something wrong with the <new reply> button since you mentioned <new reply> causing problems so the post came out messy... And I have not bothered to look into tags before since I generally don't post to forums. But I learned something new! All though pretty trivial... :-)
Edit: Oh, and I learned that there is a threaded mode too!
