New member with a question - Printable Version
+--- Thread: New member with a question (/thread-14778.html)
Pages: 1 2
RE: New member with a question - tsb - 04-08-2020 01:16 PM
I would agree with pre-production. The unit looks very much like a production model. The key bezel placement is slightly off/shifted hard to one side, but otherwise indistinguishable. I'm assuming that the 85 in the serial number is the sequence in the batch produced. Don't know if I will ever get down to the significance/non-significance of the J. Gannon label, but I'm glad that I didn't remove it without first doing a bit of research.
RE: New member with a question - Massimo Gnerucci - 04-08-2020 01:50 PM
(04-08-2020 12:55 PM)rprosperi Wrote:
(04-08-2020 06:29 AM)Massimo Gnerucci Wrote:  My 17C has no serial # on its clear bottom case.
Don't believe I've seen a 17C. Can you post a photo of the top of the unit? Did you get this back in the day, and if so do you know much about its provenance?
I think I already shared it, however here it is!
Unfortunately the display is not OK and shows several blank pixels (have to check those zebra strips, one day or another). However self-test shows something like LP1 on the right end of the display.
Looks like it's a 17Bii proto,
RE: New member with a question - tsb - 04-08-2020 02:37 PM
That is amazing - very cool. How did you come across that if I may ask?
RE: New member with a question - Massimo Gnerucci - 04-08-2020 03:10 PM
(04-08-2020 02:37 PM)tsb Wrote:  That is amazing - very cool. How did you come across that if I may ask?
Well, sometimes eBay does wonders! :)
RE: New member with a question - ijabbott - 04-08-2020 09:29 PM
(04-08-2020 01:50 PM)Massimo Gnerucci Wrote:
(04-08-2020 12:55 PM)rprosperi Wrote:  Don't believe I've seen a 17C. Can you post a photo of the top of the unit? Did you get this back in the day, and if so do you know much about its provenance?
Since it's a rare item, I personally wouldn't risk trying to repair it.
RE: New member with a question - rprosperi - 04-08-2020 10:47 PM
(04-08-2020 01:50 PM)Massimo Gnerucci Wrote:  I think I already shared it, however here it is!
Cool! I've not see this before at all! Thanks for posting this! Smile
