HP PPL and Statistical distributions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP PPL and Statistical distributions (/thread-16635.html) Pages: 1 2 |
RE: HP PPL and Statistical distributions - robmio - 05-23-2021 01:43 PM Undoubtedly your program is well done: fast and flexible. I use it for Tukey's post hoc analysis in randomized block-design ANOVA and for post hoc analysis in Fridman's ANOVA. Thanks, you helped me a lot. Best regards, Roberto. RE: HP PPL and Statistical distributions - C.Ret - 05-23-2021 02:00 PM (05-23-2021 01:32 PM)Albert Chan Wrote: CAS> inf > 3+4i → 1 I am very surprised by reading this. I must have missed a step in the advancement of mathematics. The last time I was told about the properties of complex numbers field, there were no order relation available for it. Therefore, no one may attempt a comparison between any complex number nor between a complex number and a real ! What's the new under the sky that have ordered the complex numbers ? That is surely a Vander full invention or an epic monster ! In this CAS software environment , what would be the result of comparing 4 + 7i and 14 + 0.3i ? RE: HP PPL and Statistical distributions - Albert Chan - 05-23-2021 03:36 PM (05-23-2021 02:00 PM)C.Ret Wrote: The last time I was told about the properties of complex numbers field, there were no order relation available for it. It was not about comparing 2 complex numbers, but against a "symbolic" infinity. My guess symbolic infinity is defined bigger than any finite values, independent of type. The issue is this line in quad: < IF bool(a>b) == bool(mode==2) THEN d:=-d END My patch to extend to complex numbers (which turned out not needed in PPL) // If integration limits are [a, -inf] or [-inf, b], switch direction of integration. > IF (mode==2 AND b<0) OR (mode==1 AND a<0) THEN d:=-d END But, you do have a point. Patch is more readable, and less reliance on PPL "feature" (which might changed in the future). I am patching this to quad. Thanks, C.Ret Update1: replace indirect (mode!=2) as (mode==1) Update2: replace complicated test with simpler equivalent code < IF mode == 2 THEN c:=a ELSE c:=b END < IF (mode==2 AND b<0) OR (mode==1 AND a<0) THEN d:=-d END < s := f(c+d) > c, s := a, b; // c = finite edge > IF mode == 1 THEN c, s := b, a END > IF s < 0 THEN d:=-d END > s := f(c+d) |
