Automatic differentiation using dual numbers - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Automatic differentiation using dual numbers (/thread-18482.html) Pages: 1 2 |
RE: Automatic differentiation using dual numbers - Albert Chan - 06-25-2022 11:05 AM (06-22-2022 10:36 PM)Thomas Klemm Wrote: Halley's Method Is correction factor to Newton's always positive ? How do we ensure Halley's method is safe to use ? I've seen some page (search for householder) flip the correction: 1/(1-ε) ≈ 1+ε Correction is less aggressive, but safer (if f'≠0, no division by zero problem) \( \displaystyle x_{n+1} =x_{n}-{\frac {f(x_{n})}{f'(x_{n})}}\left[1+{\frac {f(x_{n})}{f'(x_{n})}}\cdot {\frac {f''(x_{n})}{2f'(x_{n})}}\right] \) RE: Automatic differentiation using dual numbers - Albert Chan - 06-26-2022 10:55 AM An example that c = (1 - 1/2 * (f/f') * (f''/f')) can turn negative. f = x^4 - 30*x^3 +63*x^2 - 12*x + 33 // real roots ≈ [2.31090, 27.7432] f' = 4*x^3 - 90*x^2 + 126*x - 12 // real roots ≈ [0.102744, 1.38994, 21.0073] f'' = 12*x^2 -180*x + 126 // real roots ≈ [0.736125, 14.2639] m = f'^2 - 1/2*f*f'' // real roots ≈ [-0.34128, 0.484147] c = m / f'^2 c = ±∞ when guess = f' roots (Newton's correction also ±∞) c = 0 when guess = m roots (Halley's method hit by divide-by-zero) c < 0 when guess within m roots (iterate opposite direction of Newton's) Comment: Above example is easier to solve for roots of f(1/x), then flip the results. g = 33*x^4 - 12*x^3 + 63*x^2 - 30*x + 1 g' = 132*x^3 - 36*x^2 + 126*x - 30 g'' = 396*x^2 - 72*x + 126 g'', with negative quadratic discriminant, have no root g'' > 0 ⇒ g is concave up. RE: Automatic differentiation using dual numbers - Albert Chan - 07-03-2022 02:12 PM If guess is close to root, we can consider f as the independent variable. x = x0 + (dx/df)(f=f0) * (f-f0)/1! + (d²x/df²)(f=f0) * (f-f0)²/2! + ... dx/df = 1 / (df/dx) = 1/f' d²x/df² = d/df (dx/df) = d/dx (1/f') * dx/df = (-f''/f'^2) / f' = -f''/f'^3 Solving root is simplify x at f=0, with iteration formula: x ← x + (1/f')*(-f) + (-f''/f'^3)*(f^2/2) + ... = x - f/f' - (f^2*f'')/(2*f'^3) + ... Drop ... = O(f^3), we have: (06-25-2022 11:05 AM)Albert Chan Wrote: I've seen some page (search for householder) flip the correction: 1/(1-ε) ≈ 1+ε RE: Automatic differentiation using dual numbers - Ángel Martin - 07-07-2022 07:35 AM (06-26-2022 10:55 AM)Albert Chan Wrote: "Concave and Convex" works better for me. RE: Automatic differentiation using dual numbers - Ángel Martin - 07-07-2022 07:40 AM (06-21-2022 02:19 AM)Thomas Klemm Wrote:(06-20-2022 09:50 PM)Albert Chan Wrote: … forget about ε … ε is a bad idea Sorry for coming this late to this, but I'm not sure I follow your point about higher order derivatives (I'm sure it's my own fault). By definition \(\varepsilon^2 = 0\)., right? RE: Automatic differentiation using dual numbers - Thomas Klemm - 07-07-2022 08:02 AM (07-07-2022 07:40 AM)Ángel Martin Wrote: By definition \(\varepsilon^2 = 0\)., right? If we want to extend the idea of dual numbers for higher order derivatives we can define \(\varepsilon^n = 0\). Slightly sloppy, we ignore the terms of \(\varepsilon^n\) and higher. RE: Automatic differentiation using dual numbers - ijabbott - 07-07-2022 10:42 AM (07-07-2022 07:35 AM)Ángel Martin Wrote:(06-26-2022 10:55 AM)Albert Chan Wrote: [ "Concave up / Concave down" illustration was here ] Then you need to remember the viewpoint. |
