(DM42) Matrix exponential - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (DM42) Matrix exponential (/thread-20290.html) Pages: 1 2 |
RE: (DM42) Matrix exponential - Albert Chan - 08-21-2023 07:45 PM (08-21-2023 07:03 PM)Gjermund Skailand Wrote: A= [[ -49, 24][-64 ,31 ] ] I was doing expm1(A) = exp(A) - 1 (= identity matrix). Adjusted, both agreed. Quote:But my implementation on HP50g using double binary floating point fails. This is why example is nasty, if we just simply do e^A = 1 + A + A^2/2! + A^3/3! + ... The terms blows-up passes true answer. (Matrix A already bigger than final sum!) A^16/16! ≈ [[6977251.9061, -3488625.95305], [9303002.54147, -4651501.27073]] A^17/17! ≈ [[-6977251.9061, 3488625.95305], [-9303002.54147, 4651501.27073]] No. the 2 terms are not exactly negate of the others. But, catastrophic cancellation made the sum meaningless. RE: (DM42) Matrix exponential - Werner - 08-23-2023 07:16 AM (08-21-2023 11:49 AM)Albert Chan Wrote: 1118905.69945 1374815.06297 1630724.42651 I can reproduce these exactly on the 42S using the program below. (well making sure I have P=13 in the first example..) If you want MEXP, perform an extra M+I 00 { 99-Byte Prgm } 01▸LBL "MXP-1" 02 ENTER 03 FNRM 04 LN 05 2 06 LN 07 ÷ 08 10 09 + 10 IP 11 X<0? 12 CLX 13 X<>Y 14 2 15 RCL ST Z 16 +/- 17 Y^X 18 × 19 RCL ST X 20 4 21 ÷ 22 XEQ 01 23 3 24 ÷ 25 RCL× ST Y 26 XEQ 01 27 2 28 ÷ 29 RCL× ST Y 30 XEQ 01 31 X<>Y 32 × 33▸LBL 04 34 ENTER 35 + 36 LASTX 37 STOx ST X 38 + 39 DSE ST Y 40 GTO 04 41 RTN 42▸LBL "M+I" 43▸LBL 01 @ add I 44 EDIT 45 ^ 46▸LBL 02 47 ↓ 48 ENTER @ no, you can't remove this 49 1 50 + 51 → 52 FC? 77 53 GTO 02 54 EXITALL 55 END Cheers, Werner RE: (DM42) Matrix exponential - Gil - 08-23-2023 09:09 AM Two questions Line 40 : P=MAX(0,IROUND(LOG2(MAXAB(X)))+10) What is the meaning (perhaps with an example) of the function/command MAXAB(X)? And LOG2 (x) is log [in base 2] of x? Thanks for your help. Regards RE: (DM42) Matrix exponential - Albert Chan - 08-23-2023 02:51 PM (08-23-2023 09:09 AM)Gil Wrote: What is the meaning (perhaps with an example) of the function/command MAXAB(X)? MAXAB(X) is from JFG "Math Pac 2" - Version 2B Feb. 2021 MAXAB = Array Element Maximum Absolute Value. (Perhaps it should be named MAXABS) It has a side effect of saving where element is located. >mat disp x -5.46969688594 22010.2875425 -22141314.9958 >maxab(x), arow, acol 22141314.9958 3 1 >minab(x), arow, acol 5.46969688594 1 1 Quote:P=MAX(0,IROUND(LOG2(MAXAB(X)))+10) This is to make sure X/2^P elements size at most ε = 2^(-9.5) ≈ 0.00138 expm1(ε) = ε + ε^2/2! + ε^3/3! + ε^4/4! + ... If I drop..., expm1 relative error ≈ (ε^5/5!)/ε = ε^4/120 ≤ 3.0E-14, less than machine epsilon. Note: matrix multiply is a dot product of row and col, it really depends on cell values. Above is *very* rough estimate of relative errors. (and, only if ε is truly small) RE: (DM42) Matrix exponential - Albert Chan - 08-23-2023 07:55 PM Trivia, for A = 2x2 matrix, e^A only need its eigenvalues. (i.e. P, P-1 not needed) A = P D P-1 D diagonal has eigenvalues of A = c ± g --> D-c has diagonal of ± g Let X = A-c --> X^2 = g^2 // × identity matrix sinh(X) = (1 + X^2/3! + X^4/5! + ...) * X = sinh(g)/g * X cosh(X) = (1 + X^2/2! + X^4/4! + ...) = cosh(g) // × identity matrix e^X = sinh(X) + cosh(X) = sinh(g)/g * X + cosh(g) XCas> eA := ((sinh(g)/g) * (A-c) + cosh(g)) * e^c XCas> A := [[a11,a12],[a21,a22]]; XCas> x1, x2 := eigenvalues(A) :; XCas> c, g := [x1+x2, x1-x2]/2 :; XCas> simplify(hyp2exp(exp(A) - eA)) // confirmed symbolically \(\left(\begin{array}{cc}0&0\\0&0\end{array}\right)\) RE: (DM42) Matrix exponential - Albert Chan - 08-23-2023 09:39 PM (08-23-2023 07:55 PM)Albert Chan Wrote: sinh(X) = (1 + X^2/3! + X^4/5! + ...) * X = sinh(g)/g * X We can use same idea to get expm1(k*Jn), where Jn = matrix of all ones, dimensions n×n Identity used: (Jn/n)^(integer_powers) = (Jn/n) sinh(k*Jn) = (k*Jn) + (k*Jn)^3/3! + (k*Jn)^5/5! + ... = (1 + (k*n)^2/3! + (k*n)^4/5! + ...) * (k*Jn) sinh(k*Jn) = sinh(k*n) * (Jn/n) = 2*sinh(k*n/2)*cosh(k*n/2) * (Jn/n) cosh(k*Jn) − 1 = 2*sinh(k/2*Jn)^2 = 2*sinh(k*n/2)*sinh(k*n/2) * (Jn/n) Add the 2 lines: exp(x*Jn) - 1 = 2*sinh(n/2*x)*exp(n/2*x) * (Jn/n) exmp1(k*Jn) = expm1(k*n) * (Jn/n) Any function f with f(0) = 0, will have same pattern. (*) Taylor series (Jn/n)^(integer_powers) = (Jn/n), which can be factored out. f(k*Jn) = f(k*n * (Jn/n)) = f(k*n) * (Jn/n) For examples, these will work: sin, versin, tan, tanh, log1p, ... (and its inverse function) (*) Exception, if f cannot handle matrix argument. Example, because Jn is not invertible, this will not work: f(x) := sin(x^2)/x RE: (DM42) Matrix exponential - Gjermund Skailand - 08-24-2023 07:59 AM Here is another version of Alberts code for the DM42. There are two tuning parameters, to make use of the 32 digits accuracy of the DM32. Current values should give same result as Werners version. at line 24, increase from 10 for more reduction of input matrix at line 34, increase from 4 to e.g. 9, error ~ 0.00138^9/10!= 5.0E-33 If you want to calculate MEXP-1 delete last line (line 60) Code:
Gjermund RE: (DM42) Matrix exponential - Werner - 08-24-2023 01:14 PM Hi Gjermund, adapted mine as well so that the number of expm1 terms could be easily changed. I switched to 6 i.o. 10 squarings though - for the 42S version (where it matters most), that meant two fewer matrix multiplications (6 terms, 6 squarings give the same accuracy as 4 terms, 10 squarings), and for the DM42 it doesn't matter (6 terms and 14 squarings or 10 terms and 10 squarings). And, still all in the stack ;-) (I'd like to make it independent of the calculator's precision, but that proves to be a bit of a challenge, only using the stack ;-) 00 { 98-Byte Prgm } 01▸LBL "E↑M-I" 02 ENTER 03 FNRM 04 LN 05 2 06 LN 07 ÷ 08 6 09 + 10 IP 11 X<0? 12 CLX 13 X<>Y 14 2 15 RCL ST Z 16 +/- @ avoids overflow.. 17 Y^X 18 × 19 14 @ 6 for 42S 20 RCL ST Y 21▸LBL 05 @ X := (X/Y+I)*Z, keeping YZT 22 RCL÷ ST Y 23 XEQ 01 24 RCL× ST Z 25 DSE ST Y @ DSE n, skip when n=1 26 DSE ST Y 27 ISG ST Y 28 X=Y? @ aff 29 GTO 05 30 R^ 31 X<>Y 32▸LBL 04 33 ENTER 34 + 35 LASTX 36 STO× ST X 37 + 38 DSE ST Y 39 GTO 04 40 RTN 41▸LBL 01 @ add I 42▸LBL "M+I" 43 EDIT 44 ^ 45▸LBL 02 46 ↓ 47 SIGN 48 X<0? 49 +/- 50 RCL+ ST L 51 → 52 FC? 77 53 GTO 02 54 EXITALL 55 END Cheers, Werner RE: (DM42) Matrix exponential - Gjermund Skailand - 08-24-2023 07:12 PM Hi Werner on DM42 I found that matrix functions are very effective compared to user operations, so keeping a copy and adding of the Identity matrix really pays off. Albert's algoritm is much more robust (no surprise there) and about 10% faster than my original implementation. Best regards Gjermund RE: (DM42) Matrix exponential - Albert Chan - 08-26-2023 10:20 PM (08-23-2023 09:39 PM)Albert Chan Wrote: exmp1(k*Jn) = expm1(k*n) * (Jn/n) My old code epsilon has enough safety margin for small matrices. But, in general, perhaps we need to cover the edge case. If n×n elements sized about the same, say k, FNORM(X) ≈ k*n Code: < 40 P=MAX(0,IROUND(LOG2(MAXAB(X)))+10) @ MAT X=(1/2^P)*X Example, expm1(J20) = expm1(20)/20 * J20 = 24258259.7205 * J20 Old Patch: P=10 ---> 24258259.1465 * J20 New Patch: P=13 --> 24258259.7183 * J20 RE: (DM42) Matrix exponential - John Keith - 08-27-2023 04:46 PM (08-26-2023 10:20 PM)Albert Chan Wrote: If n×n elements sized about the same, say k, FNORM(X) ≈ k*n I like this, especially since the HP-28/48 don't have MAXAB but do have ABS (same as FNORM ). RE: (DM42) Matrix exponential - Gil - 08-28-2023 08:57 AM Is LOG2 (x) log [in base 2] of x? RE: (DM42) Matrix exponential - Albert Chan - 08-28-2023 01:10 PM (08-28-2023 08:57 AM)Gil Wrote: Is LOG2 (x) Yes, see Bits of integer |
