TI-58C Clone - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: TI-58C Clone (/thread-22596.html) |
RE: TI-58C Clone - toml_12953 - 10-29-2024 04:16 PM (10-29-2024 12:01 PM)AnnoyedOne Wrote:(10-28-2024 07:47 PM)Pierre Wrote: The site only sells in kit form. You don't know anyone who would assemble it for you? I assemble kits for all my friends just for the pleasure of the assembly. In fact, when I buy a kit, I assemble it, test it then usually give it away or sell it cheaply because that's the fun of it for me. RE: TI-58C Clone - Pierre - 10-30-2024 10:50 AM (10-29-2024 12:01 PM)AnnoyedOne Wrote: So my search for a decent emulator (not a simulator) continues. Being attached to semantics, I will therefore repeat here the introductory message present on my site : Quote:It seems that some people qualify my TI-58C program as a simulator on the pretext that an emulator is a program which takes the kernel (ROM) of a machine "to run" it, in computer science, in France, it is common to say "to process" it. So, AnnoyedOne, if you are looking for a ROM microcode "executor" I recommend : The “purist” TI59e of Hrast Programmer (https://www.hrastprogrammer.com/ti59e/ and http://www.hrastprogrammer.com/ti59e/ti59epc.zip) (10-29-2024 12:01 PM)AnnoyedOne Wrote: And yes Pierre I've tried yours Thanks for trying, and sorry it didn't meet your expectations. RE: TI-58C Clone - AnnoyedOne - 10-30-2024 12:56 PM (10-30-2024 10:50 AM)Pierre Wrote: So, AnnoyedOne, if you are looking for a ROM microcode "executor" I recommend : That my definition of an emulator yes. Runs the original ROM code vs what anyone thinks it does/should do (simulator). I've tried the Hrast Programmer emulator. No thanks. A1 PS: It seems that TI has threatened anyone who publicly publishes ROM images of ancient products. Their code and choice. I assume that's why there's are almost no emulators but many simulators. RE: TI-58C Clone - Matt Agajanian - 10-30-2024 04:28 PM Hi all. Some insight, please. The faceplate of the ET-58 in the OP looks a bit crowded and cluttered with way too much nomenclature. Is that the actual faceplate or is that from a prototype? RE: TI-58C Clone - Pierre - 10-30-2024 04:50 PM (10-30-2024 04:28 PM)Matt Agajanian Wrote: Is that the actual faceplate or is that from a prototype? That is the actual faceplate ! When, like me, you know the TI-58C keyboard, nothing monstrous. Just a 3rd function to assimilate in addition. 3 functions per key is quite usual on HP... (without speaking about the WP34S) To explain : Above the button in large characters: the basic function To the left of the button, upper text: the 2nd function To the left of the button, lower text: the 3rd function Ex: the 1/X key gives tan if 2nd before 1/X and gives tanh if 3rd before 1/X... (We can also make a color overlay) RE: TI-58C Clone - Pierre - 11-01-2024 01:13 PM Among the "plus" I was going to forget : the alphanumeric display that the TI-58C did not know! To which must be added a list of 112 pre-recorded terms to help compose the texts. (OK, ERROR, Diagnose, Result, Input, Enter, Index, Row, Column, Continue, STOP, Matrix, Complex, Number, Element, Item...) RE: TI-58C Clone - badaze - 11-01-2024 02:33 PM Very interesting. TI deserves clones as well as HP. Will buy one when available. @Pierre. tu as mis un drapeau hongrois au lieu d’un drapeau tchèque sur ton site. RE: TI-58C Clone - Pierre - 11-01-2024 03:17 PM (11-01-2024 02:33 PM)badaze Wrote: @Pierre. tu as mis un drapeau hongrois au lieu d’un drapeau tchèque sur ton site. @badaze. Merci mais je ne me suis pas trompé sur mon site mais sur mes deux sites ! RE: TI-58C Clone - Helix - 11-01-2024 11:19 PM (11-01-2024 01:13 PM)Pierre Wrote: Among the "plus" I was going to forget : When you post an image from your site, I think you should remove http:// after [img], because I can’t see it. I would certainly buy this clone if it was sold assembled... RE: TI-58C Clone - carey - 11-02-2024 12:58 AM (11-01-2024 11:19 PM)Helix Wrote:Same here! (hint for ET-58 maker :)(11-01-2024 01:13 PM)Pierre Wrote: Among the "plus" I was going to forget :I would certainly buy this clone if it was sold assembled... RE: TI-58C Clone - Pierre - 11-02-2024 07:41 AM (11-01-2024 11:19 PM)Helix Wrote: I think you should remove http:// after [img], because I can’t see it. Sorry but without http:// [img]clones.phweb.me/download/alpha.jpg[/img] otherwise with https:// RE: TI-58C Clone - RPNerd - 11-02-2024 08:17 AM (11-01-2024 03:17 PM)Pierre Wrote:(11-01-2024 02:33 PM)badaze Wrote: @Pierre. tu as mis un drapeau hongrois au lieu d’un drapeau tchèque sur ton site. Hé, les gars, pas besoin de chuchoter. On a du mal à vous entendre sans une loupe ! RE: TI-58C Clone - Marc van Lemmen - 11-03-2024 11:47 AM Hello Pierre, Thank you for pointing this out ! Nice ! And thanks to Miroslav Nemecek for creating the ET-58. My first programmable device was a TI-57, I couldn't afford a TI-58 or 59. I had an oppertunitie to play with a TI-58 for a couple of weeks, and I still love it. So when I saw your post, I immediatly ordered a kit ! It arrived yesterday, but now I have to find the time to solder it. Luckely there are only two smd parts, I'm no hero soldering smd Regards, Marc. RE: TI-58C Clone - Pierre - 11-03-2024 12:41 PM (11-03-2024 11:47 AM)Marc van Lemmen Wrote: Hello Pierre, Thank you for pointing this out ! Nice ! And thanks to Miroslav Nemecek for creating the ET-58. Hi Marc, Congratulations on your purchase. Don't hesitate to take pictures during your assembly work that will be useful to other fans. (and I can publish them on my site with your agreement!) And your comments will be welcome. For my part, being bad at electronics and especially at soldering, I can only help you with the use and programming of the ET-58. For the manual you will have to be patient... I have as much skills in Czech as in soldering... but I will know how to do it! I have already made a 259 steps program that I immediately transposed for the PX-41CX then for the HP-15C... Have fun ! Best regards Pierre RE: TI-58C Clone - Marc van Lemmen - 11-03-2024 06:42 PM Quote:Hi Marc, Hi Pierre, I will take pictures when I assemble/solder the ET-58 and post them here, and you may put them on your site. The building instructions, in English, can be found at : https://www.breatharian.eu/hw/et58/index_en.html I first have to make room in my office or storage. both are packed Best regards, Marc. RE: TI-58C Clone - Pierre - 11-08-2024 01:47 PM The Pajenicko.cz website has restocked the ET-58 kits and is therefore putting several of them back on sale! RE: TI-58C Clone - badaze - 11-08-2024 04:44 PM I’ve just ordered one. I just have to learn how to solder ! Cost 43€ shipping to France included. RE: TI-58C Clone - Pierre - 11-08-2024 06:06 PM (11-08-2024 04:44 PM)badaze Wrote: I’ve just ordered one. Félicitations ! Je pense que vous aurez fini le montage avant que j'ai pu terminer le manuel. Le manuel en français avance doucement... J'en suis à une trentaine de pages sur 260 environ... Plus que 230 pages à faire avant d'attaquer la version anglaise ! Congratulations ! I think you will have finished the soldering before I had finish the manual. The French owner's manual is progressing slowly... I am at about thirty pages out of about 260... Only 230 pages to translate before starting the English version ! RE: TI-58C Clone - Marc van Lemmen - 11-09-2024 09:31 PM Hi Pierre, I am ready soldering the ET-58, but I have to find out how to program the Atmega328p. I'm only familiar with pic microcontrollers, and Arduino ( also a 328p, but with a bootloader ). For now I've used an ic socket so I can reprogram the 328p. It only makes the distance from the top cover plate to the pcb greater, I'll have to find out if this is workable once I have a working 328p. I'll let you know if there's any progress. Regards, Marc. RE: TI-58C Clone - Pierre - 11-09-2024 10:41 PM (11-09-2024 09:31 PM)Marc van Lemmen Wrote: Hi Pierre, Hi Marc, Thanks for the information. I will be very interested in your progress. Best regards Pierre |
