WP 34S: Quick access to bitwise operations as on the 16C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP 34S: Quick access to bitwise operations as on the 16C (/thread-2932.html) Pages: 1 2 |
RE: WP 34S: Quick access to bitwise operations as on the 16C - Bit - 01-29-2015 12:32 AM (01-27-2015 01:35 AM)Bit Wrote:After I've been looking at the colored hotkeys for a while, I've started to like them -- although I prefer them above the buttons rather than below. Labeling the E and F keys was a good idea, too. Thank you for the suggestions.(01-26-2015 06:31 AM)BarryMead Wrote:I've added a new set of PDFs to the first post...(01-26-2015 05:57 AM)John Galt Wrote: It would make sense to label the top row A - F all the way left to right.See the attached modified text version of the legend that incorporates John's suggestions along with mine. RE: WP 34S: Quick access to bitwise operations as on the 16C - Bit - 01-31-2015 02:58 PM I've found a small problem: the print X register command ([f] [EXIT]) was broken. I've released an updated patch and binaries. |
