A manual suggestion - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: A manual suggestion (/thread-3158.html) Pages: 1 2 |
RE: A manual suggestion - BarryMead - 04-09-2015 11:36 PM (04-09-2015 08:35 PM)walter b Wrote: Just try the Manual Calculation Guide published here. Any difficulties reading it? With whatever OS you have? Thanks Walter, I downloaded your Manual Calculation Guide, and it is viewable in Linux with standard PDF viewers. RE: A manual suggestion - Sylvain Cote - 04-10-2015 02:09 AM (04-09-2015 05:59 PM)walter b Wrote: What kind of problems do you expect? Depending on what software you are using, some generator are using extensions not compatible with other PDF reader. I have often seen this with data entry PDF files. (04-09-2015 11:36 PM)BarryMead Wrote: Thanks Walter, I downloaded your Manual Calculation Guide, and it is viewable in Linux with standard PDF viewers. Same here on OSX v10.10.3 with OSX Preview, Acrobat Reader and with PDFPenPro. Sylvain RE: A manual suggestion - EmmanuelC - 04-10-2015 08:53 PM (02-24-2015 07:23 PM)Jlouis Wrote: I'll buy it when it's available. +1 too! |
