Request for "Decimal Period of 1/X in Base Y" program - Printable Version
+--- Thread: Request for "Decimal Period of 1/X in Base Y" program (/thread-3212.html)
Pages: 1 2
RE: Request for "Multiplicative Order of Y (mod X)" program - Gerald H - 03-01-2015 10:17 PM
If you want to do it for any base, instead of removing 2s & 5s, remove any factors of that base & change the 10 near the end for the required base - I believe that will solve it.
It might be an idea to change title of thread so others can find solution to length of period problem.
RE: Request for "Decimal Period of 1/X in Base Y" program - Joe Horn - 03-02-2015 07:09 AM
(03-01-2015 10:17 PM)Gerald H Wrote:  If you want to do it for any base, instead of removing 2s & 5s, remove any factors of that base & change the 10 near the end for the required base - I believe that will solve it.
Will try that. I hope it's a valid method, because that's the method used by my URPL program, but it's much slower than yours.
Quote:It might be an idea to change title of thread so others can find solution to length of period problem.
Good idea. Done.
RE: Request for "Decimal Period of 1/X in Base Y" program - Gerald H - 03-02-2015 08:10 AM
(03-01-2015 05:40 PM)Joe Horn Wrote:
(02-27-2015 09:57 AM)Gerald H Wrote:  IF you're only interested in integer values for X & Y, this 50G prog does the job: ...
Z0_
The 9th line of your program won't compile using the built-in tools. What is Z0_?
EDIT: Never mind, I figured out it means ZINT 0. What assembler is that for?
Sorry, it's a custom EXTABLE for ROM 2.10-7.
Yes, Z0_ is ZINT 0.
RE: Request for "Decimal Period of 1/X in Base Y" program - Gerald H - 03-02-2015 10:33 AM
Good idea. Done.
OK, how about this prog:
WHILE DUP PICK3 GCD DUP 1 >
REPEAT /
END DROP SWAP ORD
RE: Request for "Decimal Period of 1/X in Base Y" program - StephenG1CMZ - 01-21-2018 09:17 PM
(02-27-2015 08:49 AM)Thomas Ritschel Wrote:  Here is a simple non-CAS variant:
EXPORT MultiplicativeOrder(a,base)
  LOCAL k:=0;
  LOCAL res:=1;
  REPEAT
    res:=res*base;
    k:=k+1;
    res:=res MOD a;
  UNTIL res==1;
  RETURN(k);
I am using this procedure to analyze repeating decimals/recurring decimals here:
http://www.hpmuseum.org/forum/thread-9986.html
RE: Request for "Decimal Period of 1/X in Base Y" program - StephenG1CMZ - 01-26-2018 11:32 PM
I now have an optimised version of MultiplicativeOrder for base 10 on the Prime here:
RE: Request for "Decimal Period of 1/X in Base Y" program - Albert Chan - 08-11-2019 07:00 PM
(03-01-2015 06:17 PM)Joe Horn (post 18) Wrote:  Uh oh. Running it after 12 ENTER 23 yields 22, but the correct answer for the period of 1/23 in base 12
(as returned by my URPL program above) is 11, as can be seen by actually writing 1/23 in base 12:
0.06316948421 06316948421 06316948421 06316948421 ...
Am I misunderstanding something here?
The code for order(a,n) were wrong. order(12,23) = 11, matching repeating decimals period.
GCD does 2 duties: satisfy order() co-prime arguments requirement, and to track where to put the "decimal" point.
Example, 1/360 to base 12
12/360 = 1/30
12/30 = 2/5
Stop further scaling since gcd(12,5) = 1
order(12,5) = 4
12^4-1 = 20735
2/5 = (20735*2/5) / 20735 = 8294/20735 = 4972/BBBB (base 12)
1/360 = 0.00 \(\overline{4972}\) (base 12)
