HP50g or other: U. of Houston calc exams - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP50g or other: U. of Houston calc exams (/thread-4480.html) Pages: 1 2 |
RE: HP50g or other: U. of Houston calc exams - Hlib - 08-10-2015 02:12 PM (08-10-2015 12:07 AM)CR Haeger Wrote: ... If this is correct ... This is correct. Prime users aren't engaged in this little things. They go to sleep and don't know, whether their calculator will work tomorrow. RE: HP50g or other: U. of Houston calc exams - CR Haeger - 08-10-2015 03:42 PM (08-10-2015 02:12 PM)Hlib Wrote:(08-10-2015 12:07 AM)CR Haeger Wrote: ... If this is correct ...Prime users aren't engaged in this little things. They go to sleep and don't know, whether their calculator will work tomorrow. I'm a Prime user too... It seemed to work (quickly) today. I am a novice on the 50G. Using CAS: solve([(2*x-3*y) = (6-7*a^2),(-3*x+5*y) = (7+2*a),(7*x+11*y) = (4-6*a)],[x,y,a]) Exact x,y,a: {[(-52*√21106-7381)/8092,(-4*√21106+7213)/8092,(2*√21106+23)/238],[(52*√21106-7381)/8092,(4*√21106+7213)/8092,(-2*√21106+23)/238]} Approx x,y,a: {[−1.84571307168,0.819560532948,1.31747093989],[0.021442186857,0.963187860527,−1.12419362897]} RE: HP50g or other: U. of Houston calc exams - Didier Lachieze - 08-10-2015 03:50 PM (08-10-2015 02:12 PM)Hlib Wrote: Prime users aren't engaged in this little things. They go to sleep and don't know, whether their calculator will work tomorrow.My Prime has been working every day I needed it, so I don't fear tomorrow For the first problem (sum of factors of 224551579230): Code: CAS.ifactors(224551579230)▶L1 And for the second problem (2015 .19), in CAS mode: Code: solve({2x-3y=6-7a,-3x+5y=7+2a,7x+11y=4-6a},[a,x,y]) and with a^2 in the first equation : Code: solve({2x-3y=6-7a^2,-3x+5y=7+2a,7x+11y=4-6a},[a,x,y]) RE: HP50g or other: U. of Houston calc exams - Peter Murphy - 08-12-2015 04:22 PM The following problem, from the 2013 Houston calculator exam, seems conceptually simple to solve, but the manipulations necessary to solve it from start to finish on the 50g are not so obvious: 14. There are 3 points of intersection of pairs of the lines 2x+3y=4, 7x-2y=3 and x+y=15. Give the area of the triangle determined by these three points. It seems clear that the "shoelace formula" of Meister and Gauss* is needed, and a little program to apply that would be nice. Peter * <https://en.wikipedia.org/wiki/Shoelace_formula> RE: HP50g or other: U. of Houston calc exams - Thomas Klemm - 08-12-2015 05:26 PM (08-12-2015 04:22 PM)Peter Murphy Wrote: It seems clear that the "shoelace formula" of Meister and Gauss* is needed, and a little program to apply that would be nice. Cf. 50G Question, has anyone programmed gauss's... Cheers Thomas RE: HP50g or other: U. of Houston calc exams - Gilles - 08-12-2015 09:29 PM (08-12-2015 04:22 PM)Peter Murphy Wrote: The following problem, from the 2013 Houston calculator exam, seems conceptually simple to solve, but the manipulations necessary to solve it from start to finish on the 50g are not so obvious: We could also seek the points {A, B, C} of the intersections of d1 and d2, d2 and d3, d1 and d3 (with solve for example) and then S=1/2.||AB /\ AC || RE: HP50g or other: U. of Houston calc exams - Thomas Klemm - 08-12-2015 10:53 PM (08-12-2015 09:29 PM)Gilles Wrote: then S=1/2.||AB /\ AC || Which of course is the same since: \( \begin{align} (B-A)\wedge (C-A)&=B\wedge C-B\wedge A-A\wedge C+A\wedge A \\ &=B\wedge C+A\wedge B+C\wedge A+0 \\ &=A\wedge B+B\wedge C+C\wedge A \\ \end{align} \) Cheers Thomas RE: HP50g or other: U. of Houston calc exams - CR Haeger - 08-12-2015 11:21 PM (08-12-2015 04:22 PM)Peter Murphy Wrote: The following problem, from the 2013 Houston calculator exam, seems conceptually simple to solve, but the manipulations necessary to solve it from start to finish on the 50g are not so obvious: Are these questions expected to be solved solely via a calculator? Are these supposed to be approached via programming? Is some pencil to paper math allowed to simplify this? I worked an answer (A = 285 19/25 ?) by first rotating x+y=15 to y=15 then rotating the other lines slopes CCW by the same amount. Finding the intersection of these transformed lines yield the base, height of the triangle. RE: HP50g or other: U. of Houston calc exams - Peter Murphy - 08-13-2015 01:10 AM Only a numerical answer is required; solvers are free to rotate lines (which sounds like a very neat idea!) or to apply any other solving skills they may bring to bear. (In 2013, problem 9 asked for the sum of the first 213 odd integers. One hopes that some contestants did this in seconds, on paper, with a trivial calculation at the end.) But if we can become more competent users of our calculators (or if we can show others how they may do so) by putting them to work even when it's not required, we may want to do so, confirming results obtained more easily by thinking outside the calculator box. Or sleeve, as the case may be. Peter RE: HP50g or other: U. of Houston calc exams - Hlib - 08-13-2015 06:35 PM (08-12-2015 04:22 PM)Peter Murphy Wrote: The following problem, from the 2013 Houston calculator exam, seems conceptually simple to solve, but the manipulations necessary to solve it from start to finish on the 50g are not so obvious: I tried to calculate the area in a different way: Code:
RE: HP50g or other: U. of Houston calc exams - Gerson W. Barbosa - 08-13-2015 08:26 PM (08-13-2015 01:10 AM)Peter Murphy Wrote: (In 2013, problem 9 asked for the sum of the first 213 odd integers. One hopes that some contestants did this in seconds, on paper, with a trivial calculation at the end.) Yes, just one trivial calculation. Gerson. RE: HP50g or other: U. of Houston calc exams - CR Haeger - 08-13-2015 11:14 PM (08-13-2015 01:10 AM)Peter Murphy Wrote: Only a numerical answer is required; solvers are free to rotate lines (which sounds like a very neat idea!) or to apply any other solving skills they may bring to bear. Thanks and I agree that these are good exercises to explore. BTW - my idea to rotate the lines might work, but I did it wrong... so far. RE: HP50g or other: U. of Houston calc exams - pier4r - 05-03-2017 10:19 PM Gravedigging, maybe, but this is a nice source of problems. Thanks for sharing! |
