I need help with using the 41CL - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: I need help with using the 41CL (/thread-545.html) Pages: 1 2 |
RE: I need help with using the 41CL - Sylvain Cote - 09-18-2021 08:51 PM Hello David, (09-18-2021 01:05 PM)David Hayden Wrote:Nothing prevent you to do that, as long as you do not unmap one of the YFNZ/YFNX module, then the PLUG functions are no longer there, this is what happened to Namir in 2014 and to Uli this week. Test case: (note: by design, virtual module take precedence over physical ones.) Code: // assuming no physical modules is inserted into the 41CL (09-18-2021 01:05 PM)David Hayden Wrote:Not as easy as it sound, but it could have been done. ROM file format does not include contextual information as to which page and in what bank it must be mapped. MOD file format does have that information. 41CL DB ROM have most of that information thought. (09-18-2021 01:05 PM)David Hayden Wrote:As Mark said, all CCD ROM implementation has the CAT 8 to F allowing you to catalog a specific page. Also, several modules (ZenROM, HEPAX, etc) has a ROM editor that allows you to see what's in any page. But I agree with you that it would have been a great function to be included with the YFN? ROMs. I could probably create a small FOCAL program that extract the mapping information from the 41CL configuration space, let me have a look. Sylvain edit 1: typos edit 2: change the physical ROM to Home Management ROM to remove ambiguities RE: I need help with using the 41CL - Monte Dalrymple - 09-18-2021 10:12 PM (09-18-2021 08:51 PM)Sylvain Cote Wrote: Hello David, Use YFNX. The page it occupies is LOCKed so it can't be accidentally overwritten (YFNX Manual, page 6). If you want to protect other things you have plugged in, LOCK those pages (YFNX Manual, page 10). If you want to know what's plugged in via the MMU execute PLUG shift alpha alpha alpha "?" (YFNX Manual, page 18) and if you want to know what pages are locked execute EXCFG "0" (YFNX Manual, page 11). Letting the machine pick a page to plug in something seemed like a recipe for disaster. That's why I didn't implement that option. If there was room in the image I could easily add that feature. Unfortunately the ROM is full. RE: I need help with using the 41CL - Sylvain Cote - 09-18-2021 11:41 PM Hello Monte, (09-18-2021 10:12 PM)Monte Dalrymple Wrote: The page it occupies is LOCKed so it can't be accidentally overwritten (YFNX Manual, page 6).I had never looked at these functions, more investigation is needed on my part to really understand their behavior. (09-18-2021 10:12 PM)Monte Dalrymple Wrote: If you want to know what's plugged in via the MMU execute PLUG shift alpha alpha alpha "?" (YFNX Manual, page 18)Yes! I have used PPLUG from YFNX and it worked. Code: "MATH" I have learned something new today, thank you! Sylvain RE: I need help with using the 41CL - Geoff Quickfall - 09-19-2021 01:39 AM We have a saying in aviation. Once you have memorized an aircraft’s check list: CHANGE AIRCRAFT! Removes complacency. Not that ANYONE can accuse Sylvain. Of being complacent! ;-) Cheers Sylvain! RE: I need help with using the 41CL - Monte Dalrymple - 09-19-2021 02:16 AM (09-18-2021 11:41 PM)Sylvain Cote Wrote: Hello Monte, FYI, the "SEARCHING" message is put up while the function is going through the IMDB to find the mnemonic that corresponds to the address retrieved from the MMU. RE: I need help with using the 41CL - rprosperi - 09-19-2021 02:44 AM (09-18-2021 02:07 PM)mfleming Wrote: With OSX3 plugged in (page 6 in my case) a CAT 0 G will list each page and their content. You can also do a CAT 8 thru F to list individual commands in an occupied user page. I have OSX3 in page 6 and WARP in page 7 because I consider them to be part of then base O/S! Could not agree more, you took the words right out of my fingers. But especially the bold part - when I pick up a 41 without these, it feels somewhat broken and I often pause to wonder what may be wrong. As a partial cure, I just ordered yet another NoV-64d... RE: I need help with using the 41CL - Sylvain Cote - 09-19-2021 02:47 AM (09-19-2021 02:16 AM)Monte Dalrymple Wrote: FYI, the "SEARCHING" message is put up while the function is going through the IMDB to find the mnemonic that corresponds to the address retrieved from the MMU.Thanks, that's what I thought. RE: I need help with using the 41CL - Uli - 09-19-2021 01:09 PM " Use YFNX. ..........." ************* Oh my... To be honest I haven't looked in the 41CL Extreme Function manual. Now, I see that the missing things are implemented there. Sorry. The CL is a really, really big machine. I have to learn so much. |
