(71b) Problem reading files from disc on 9114B - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: (71b) Problem reading files from disc on 9114B (/thread-6495.html) Pages: 1 2 |
RE: (71b) Problem reading files from disc on 9114B - Dave Frederickson - 10-04-2016 06:10 PM (07-04-2016 09:07 PM)Erwin Wrote:Hi Erwin,(07-04-2016 07:26 PM)Dave Frederickson Wrote: Erwin, I forgot to mention, FDIO has a problem formatting floppies. The duplicate command works fine. Dave RE: (71b) Problem reading files from disc on 9114B - Erwin - 10-05-2016 07:05 AM (10-04-2016 05:43 PM)rprosperi Wrote:(10-04-2016 03:24 PM)Erwin Wrote: I installed the keyboard file which comes with the PYILPER, first device in loop an started the PILTERM comes with PYILPER too. But with the printer in the loop it is not running, only without. It's not much trouble cause I don't use it to much. Hi Bob, thanks I tried this like you proposed. The virtual printer ist OK. I made a reset of the HPIL on the calculator, started all fresh with the 9114B and the inkjet printer (which normally prints) the input "hangs" when i type on the terminal. When I push one of the arrow button on the calculator then the text appears in the terminal window and on the calculator. All very slowly. When I run the system without the printer all is running normal - as I can see. Maybe i should switch to the ILPER Forum with this problem. very mysterious Erwin |
