41 Cistern Program - Printable Version
+--- Thread: 41 Cistern Program (/thread-6677.html)
Pages: 1 2 3
RE: 41 Cistern Program - Gerson W. Barbosa - 08-17-2016 04:47 AM
(08-16-2016 07:08 PM)Gerson W. Barbosa Wrote:  Or, regardless the angle mode, but at the cost of 2.5 bytes and a few milliseconds more:
« OVER / 1 SWAP - DUP
ACOSH IM SWAP DUP
ACOS SIN * - SWAP SQ * *
A faster 55-byte solution:
  « OVER / 1. SWAP -
    DUP ACOS SIN DUP2 R→C
    ARG UNROT * - SWAP SQ
3 2 1 → 7.37021819169 (0.0497 s, 50g)
An even faster 60-byte solution:
  « OVER / 1. SWAP - 1.
    OVER SQ - √ DUP2 R→C
3 2 1 → 7.37021819169 (0.0352 s, 50g)
These require RADIANS mode, however. Also, 2.5 more bytes on the HP-48 (ROT ROT instead of UNROT).
\(V=L\cdot R^{2}\cdot \left \{ Arg\left [ \left ( 1-\frac{H}{R} \right ),\sqrt{1-\left ( 1-\frac{H}{R} \right )^{2}} \right ] - \left ( 1-\frac{H}{R} \right )\cdot \sqrt{1-\left ( 1-\frac{H}{R} \right )^{2}} \right \}\)
where
\(Arg(a,b) = \tan^{-1}\left ( \frac{b}{a} \right )\)
RE: 41 Cistern Program - wojtek - 08-17-2016 06:08 AM
Gerson W. Barbosa ' Wrote:  Or, regardless the angle mode, but at the cost of 2.5 bytes and a few milliseconds more:
ACOSH IM SWAP DUP
Gerson, you gave 15 variations of the code!! which one d'u like best?
RE: 41 Cistern Program - Ángel Martin - 08-17-2016 06:46 AM
ACOSH IM SWAP DUP
How about the original hp-41 program, was it ever found?
RE: 41 Cistern Program - aurelio - 08-17-2016 09:03 AM
(08-17-2016 06:46 AM)Ángel Martin Wrote:  How about the original hp-41 program, was it ever found?
unfortunately, not yet... I 've not planned to suscribe, yet, to the journal... Smile
RE: 41 Cistern Program - Dieter - 08-17-2016 01:30 PM
Simply make your own. ;-)
This version works in any angular mode, be it DEG, RAD or GRAD.
It also avoids calculating arccos(1–x) which may get inaccurate for small x. Instead a method with arcsin is used.
LBL"CISTERN"
" L↑R↑H=?"
PROMPT
X<>Y
ST* Z
ST* Z
ST+ X
SQRT
ASIN
4
SIN
LASTX
-1
ACOS
PI
X<>Y
2
"V="
ARCL X
AVIEW
END
If switching to RAD is OK and prompting is not required, here is a shorter version:
LBL"CISTERN"
RAD
X<>Y
ST* Z
ST* Z
ST+ X
SQRT
ASIN
4
ENTER
SIN
2
END
Or, if your prefer degrees:
LBL"CISTERN"
DEG
X<>Y
ST* Z
ST* Z
ST+ X
SQRT
ASIN
4
D-R
LASTX
SIN
2
END
Example:
L=10
r=3
h=1
=> V=30,9748
Dieter
RE: 41 Cistern Program - wojtek - 08-17-2016 02:13 PM
« Simply make your own. ;-) »
This is perhaps no so simple as it looks. Original program probably include calculations of partial volume of heads of the vessel. Calculating heads' volume can be not so simple as they can be of different shapes, for example spherical, conical etc. As far as I found in the internet calculations of heads' volume in most cases are estimated, the code for it being much longer than for simple cylinder body. On the other hand volume of heads is important as they have significant percentage of the whole volume.
It should be said here as well that body of the vessel can have different cross-sections, not only circular, but elliptical for example.
If the original program takes account af all this it certainly must be complicated
RE: 41 Cistern Program - 4ster - 08-17-2016 02:22 PM
And the original program allowed for a sloped tank if necessary. The great programs in the responses here all assume a perfect cylinder on a level base. The program in the original post allowed for different end shapes and slopes, definitely one worth resurrecting from the dead.
RE: 41 Cistern Program - aurelio - 08-17-2016 04:51 PM
(08-17-2016 02:13 PM)wojtek Wrote:  « Simply make your own. ;-) »
It should be said here as well that body of the vessel can have different cross-sections, not only circular, but elyptical for example.
Here they take in account also the different shape of the heads, unfortunately not a case of sloped vessels..
This can help of course, but is not actually what we are looking for, cause it is a "on-line" calculation.
By the way I don't understand very well the graphical rapresentation on the right Smile
RE: 41 Cistern Program - Gerson W. Barbosa - 08-18-2016 02:44 AM
ACOSH IM SWAP DUP
15? I've counted only 8. Wait, 11 now:
« OVER SQ UNROT
SWAP1. UNROT / -
DUP ACOS SIN DUP2
R→C ARG UNROT * - * *
« OVER SQ UNROT 1
UNROT SWAP / - DUP
ASIN COS * LASTARG
R→C ARG SWAP - * *
« OVER / 1. SWAP -
DUP ACOS SIN *
LASTARG R→C ARG
SWAP - OVER * * *
57.5, 57.5 and 55 bytes, respectively. All require RAD mode. No better than the previous ones, just another attempt.
Test with L = 4, R = 3 and H = 2. The exact result is '4*(9*ATAN(√8)-√8)' (33.0008305252831281644394).
If I had to discard some, I think I would keep the three programs in post #21.
RE: 41 Cistern Program - Gerson W. Barbosa - 08-19-2016 05:03 AM
(08-17-2016 04:51 PM)aurelio Wrote:  Here they take in account also the different shape of the heads, unfortunately not a case of sloped vessels..
The Oil & Gas article has the formulas. For instance, my unoptimized program for the elliptical head case (237 bytes) gives 0.916297857295 m^3 for D=1m, L=2m, a=0.25m and H=0.5m.
No stack-only code this time :-)
Gerson.
RE: 41 Cistern Program - Csaba Tizedes - 08-19-2016 08:23 AM
HP 15C version discussed in Hungarian Calculator Google group - With spherical ends and cylindrial body:
AutoCAD calculation:
https://groups.google.com/d/msg/szamologep/1MaqhoAhYgw/RwXs0EoO_EQJ
https://lh3.googleusercontent.com/-50Pg44f8EFI/VWfaYnCpieI/AAAAAAAABU4/sJ-3B7S-9_M/s1600/Benzintart%25C3%25A1ly.JPG
And the 15C program is here:
https://groups.google.com/d/msg/szamologep/1MaqhoAhYgw/WhcXHZYrFhUJ
Happy translating! Smile
Csaba
RE: 41 Cistern Program - aurelio - 08-19-2016 11:54 AM
(08-19-2016 08:23 AM)Csaba Tizedes Wrote:  Happy translating! Smile
Csaba
Smile Smile Smile
RE: 41 Cistern Program - wojtek - 08-19-2016 12:49 PM
(08-19-2016 08:23 AM)Csaba Tizedes Wrote:  https://groups.google.com/d/msg/szamologep/1MaqhoAhYgw/RwXs0EoO_EQJ
On android I can see only source of html header, no any data, no program...
RE: 41 Cistern Program - Gerson W. Barbosa - 08-19-2016 01:13 PM
%%HP: T(3)A(D)F(.);
\<< \-> L D a h
  \<< 'SQ(D)/4.*(L*(IM(ACOSH(1.-2.*h/D))-2./D*(1.-2.*h/D)*\v/(h*(D-h)))+2.*a*\pi/D*(h+4./(3.*SQ(D))*(D/2.-h)^3.-D/6.))' EVAL
Fill the stack with L, D, a, h. For a spherical tank, just make L=0 and a = D/2 (for instance, L=0, D=4, a=2 and h=4 --> a full spherical tank).
This can be simplified as
%%HP: T(3)A(D)F(.);
\<< \-> L D a h
  \<< 'SQ(D)/4.*L*IM(ACOSH(1.-2.*h/D))+\pi*a*SQ(h)*(1.-2.*h/(3.*D))+L*\v/(h*(D-h))*(h-D/2.)' EVAL
The angle mode is irrelevant on the HP 50g if IM(ACOSH) is used instead of ACOS. Size has now been reduced to 191 bytes.
2 1 0.25 0.5 --> 0.916297857295
0 4 2 4 --> 33.5103216383 (32*π/3)
0 4 2 2 -->16.7551608191 (16*π/3)
Is the latter half full or half empty? :-)
[Image: 28987150362_c3cdcf3319.jpg]
\(V= L\left [ \frac{D^{2}}{4}\cos^{-1}\left ( 1-\frac{2h}{D} \right )+ \sqrt{h\left ( D-h \right )}\left ( h-\frac{D}{2} \right ) \right ] +\pi a h^{2}\left ( 1-\frac{2h}{3D} \right )\)
Edited to include diagram and equation
RE: 41 Cistern Program - Csaba Tizedes - 08-19-2016 04:55 PM
(08-19-2016 12:49 PM)wojtek Wrote:  groups.google.com - On android I can see only source of html header, no any data, no program...
It means only that the Google needs to evolve.
If Android which is OS of Google and the Google groups is owned by Google also, but the Android can not to handle Google groups messages, that is a big FAIL.
Same thing like Leonardo can not to read his own mirror-writings...
Csaba
RE: 41 Cistern Program - Csaba Tizedes - 08-19-2016 05:07 PM
Csaba
Update: I checked under another user but logged in Google and works perfectly. Maybe you needs to login into your Google account?
The text is here but I guess this will not really helpful (Hungarian text only):
A kis HP15C-m szerint 2497.8 liter van benne.
A program - minden magyarázat nélkül:
LBL B
  STO 1
  RCL 0
  SQ
  RCL 6
  RCL-1
  SQ
  SQRT
  STO 5
  1/x
  RCL×2
  COS-1
  STO 3
  RCL×5
  RCL 3
  SIN
  RCL×2
  RCL×5
  RCL 3
  SIN
  RCL×5
  RCL×4
  2
RTN
A változók:
R0: R; a 0.2m-es gömbszelet sugara, R=2.60m
R1: h; ez az integrálás futó változója, h=0.0m ... 0.6m
R2: R-m; egy segédváltozó, ahol m=0.2m, a gömbszelet magassága
R3: alfa; egy szöget tárolok benne, az egyes gömbszeletek központi szögének a fele különböző magasságokon
R4: L; a tartály hossza L=3m
R5: r; az egyes gömbszeletek sugara különböző magasságokon
R6: d/2; a 2m átmérő fele, azaz 1m van benne tárolva
Futtatáshoz:
2.60 STO 0
2.40 STO 2
3.00 STO 4
1.00 STO 6
f RAD (csak radián módban működik a program!)
f FIX 4
0 ENTER 0.6 f INTEGRATE B
rövid futás után a kijelzőn a 2.4978 m3 érték
[Image: Benzintart%25C3%25A1ly.JPG]
Csaba
RE: 41 Cistern Program - wojtek - 08-19-2016 07:18 PM
Csaba Wrote:
"Update: I checked under another user but logged in Google and works perfectly. Maybe you needs to login into your Google account?"
I cannot login 'cos I do not see login window. My android is 2.3.3 but I do not think the problem is here. I won't change my device because it is first and last android device I bought. Anyway google apps should accept all google devices regardless of model number.
RE: 41 Cistern Program - Gerson W. Barbosa - 08-19-2016 08:37 PM
(08-19-2016 01:13 PM)Gerson W. Barbosa Wrote:
%%HP: T(3)A(D)F(.);
\<< \-> L D a h
Or, stack-only, 122.5 bytes:
%%HP: T(3)A(D)F(.);
\<< SWAP PICK3 PICK3 DUP + SWAP 3. * 1. UNROT / - * \pi * OVER SQ * 4. ROLLD DUP + OVER / NEG 1. + DUP ACOSH IM SWAP 1. OVER SQ - \v/ * - SWAP SQ * * 4. / +
This of course can be optimized even further, either for size or speed. Size optimization left out as an exercise for the interested reader :-)
L     D    a    h   -->       Volume
0     4    2    4   --> 33.5103216382 (32*π/3)
0     4    2    2   --> 16.7551608191 (16*π/3)
RE: 41 Cistern Program - aurelio - 08-19-2016 10:05 PM
Great job Gerson!!!
I lost your previous ....sorry
strange that in solving the problem is always considered as a parameter the cross section of the head, but not the section, which is assumed always circular
Vessels often have elliptical section
If I'm not wrong also Oil & Gas Journal article did not consider this case
RE: 41 Cistern Program - Csaba Tizedes - 08-19-2016 11:29 PM
(08-19-2016 10:05 PM)aurelio Wrote:  Vessels often have elliptical section
The end of the vessels are spherical in the center and the connected part is a toroid. This is connecting to the short cylindrical part - in the DIN standard. I guess in the ANSI this is same.
Csaba
