RE: BASIC Programs on HP 50G - churichuro - 03-09-2014 07:20 PM
well, I do a Basic in C from scratch for the HP50
and for TI-89/Ti-voyager
but never finish it, this work but in beta state.
the name is UBASIC (U= useless), and do it only for hobby.
example:
CLS
FIX 0
INPUT "NUM=",N
FOR I=1 TO N
LOCATE 1,1
PRINT I
NEXT
END
this must be a string in a SD card whit name for example "CONT"
put the string "CONT" in the stack
then run the program BAS
then the program BAS look for the file or string in the SD card
and interpret the program line to line
is very fast.
you need the HP50 with the library HPGCC
RE: BASIC Programs on HP 50G - HP67 - 03-10-2014 07:35 AM
(03-09-2014 07:02 PM)Alvaro Wrote: RPL is not a easy thing and I have no time to spend with it. I need something that makes "my life easier".
TINSTAAFL! Especially not in matters technical.
RE: BASIC Programs on HP 50G - David Hayden - 03-11-2014 03:05 AM
(03-06-2014 12:33 PM)Alvaro Wrote: I have a several BASIC programs writen for my CASIO FX 850P and I am looking for a EASY way to run them with the HP.
If you post the source code here, there's a good chance that someone will be willing to port them to RPL for you.
Then 3 dozen people will find ways to make the code 50% faster and 25% smaller....
Dave
RE: BASIC Programs on HP 50G - Joe Horn - 03-11-2014 04:18 AM
(03-09-2014 07:20 PM)churichuro Wrote: well, I do a Basic in C from scratch for the HP50
FYI, the name "UBASIC" is already in use. UBASIC has a bunch of Number Theory functions built in, and adjustable accuracy. Runs great under Windows 7 in a DOS window (except the graphics commands). Here's the Wikipedia article about it.
RE: BASIC Programs on HP 50G - Massimo Gnerucci - 03-11-2014 07:21 AM
(03-11-2014 04:18 AM)Joe Horn Wrote: (03-09-2014 07:20 PM)churichuro Wrote: well, I do a Basic in C from scratch for the HP50
In the '80s there was an "ubasic" for MSI barcode readers...
RE: BASIC Programs on HP 50G - churichuro - 03-11-2014 03:17 PM
UBASIC then I think I was not very imaginative, right?
BASIC this has nothing to do with these wonders you say.
This BASIC program it from scratch.
here I leave the version 0.1 and version 0.2
version 0.1 if it runs well on the HP50, that is the version specified for the HP calculator, unfortunately lost the info of my drive and could only recover the database to version 0.2, ie the version base from which to derive versions for texas instrument, linux, windows xp, and the HP-50.
never ever shared the code that was not yet ready. but as
I do not have time to continue with this project I leave the code sources so that if someone is interested to continue with the project.
who initially see it somewhat useless why is UselessBasic
as it is good to make your programs on the calculator, and they run much faster than the rpl programs.
regards
version 0.1
// C Source File
// Created 27/10/2004; 02:13:01 p.m.
#include <stdio.h>
#include <math.h>
/* # include <math.h> */
#include <string.h>
/* # include <kbd.h> */
#include <setjmp.h>
#include <ctype.h>
#include <stdlib.h>
/* ## include <args.h>
## include <graph.h>
## include <statline.h>
## include <estack.h>
#include <termios.h>
#include <unistd.h>
int getch(void)
struct termios oldt,
newt;
int ch;
tcgetattr( STDIN_FILENO, &oldt );
newt = oldt;
newt.c_lflag &= ~( ICANON | ECHO );
tcsetattr( STDIN_FILENO, TCSANOW, &newt );
ch = getchar();
tcsetattr( STDIN_FILENO, TCSANOW, &oldt );
return ch;
#define NUM_LAB 1000
#define LAB_LEN 50
#define FOR_NEST 250
#define SUB_NEST 2500
#define WHILE_NEST 250
#define DO_LOOP_NEST 250
#define IF_NEST 100
#define PROG_SIZE 640000
#define DELIMITADOR 1
#define VARIABLE 2
#define NUMERO 3
#define ORDEN 4
#define CADENA 5
#define COMILLA 6
#define FUNCION 7
#define MSTRING 8
#define MATRIX 20
#define EOL 9
#define FINISHED 10
#define AND 11
#define OR 12
#define IGUAL '='
#define NOIGUAL 14
#define MAYOR '>'
#define MAYORIGUAL 16
#define MENOR '<'
#define MENORIGUAL 18
#define NOT 19
#define PRINT 21
#define INPUT 22
#define IF 23
#define THEN 24
#define ELSE 25
#define FOR 26
#define NEXT 27
#define TO 28
#define GOTO 29
#define GOSUB 30
#define RETURN 31
#define END 32
#define REM 33
#define STEP 34
#define CLS 35
#define LOCATE 36
#define PAUSE 37
#define WHILE 38
#define WEND 39
#define DO 40
#define LOOP 41
#define UNTIL 42
#define DIM 43
#define EXIT 44
#define LET 45
#define PI 3.141516
void clrscr()
system("clear"); //clears the screen
//gotoxy function
void gotoxy(int x,int y)
printf("%c[%d;%df",0x1B,y,x);
#define trunc(x) (int) (x)
float AtoF(char *s)
char c;
int i;
for (i = 0; (c = s[i]); i++)
// Yes, the second '=' is really '=', not '=='...
if (c == '-') s[i] = 0xAD;
if ((c|32) == 'e') s[i] = 0x95;
return atof(s);
char *prog;
jmp_buf e_buf;
int obtiene_simbolo(), esdelim(), esalfa(), esdigito(),
esblanco(), busca(),obtiene_siguiente_etiqueta(),
carga_programa(), buscaf();
float encuentra_var(), funcion();
void obtiene_exp(), nivel0(), nivel1(), nivel2(), nivel3(), nivel4(), nivel5();
void nivel6(),primitiva(), arit(), unario();
void visualiza_error(), retorno(), asignar();
void rem(), locate(), ejecuta_dim(), ejecuta_exit();
//float variables[26];
typedef struct Var {
char *name;
short type;
int filas, columnas;
union {
float val;
float *matrix;
char *str;
char *mstring;
} u;
struct Var *next;
} Var;
Var *varlist = 0;
Var *lookup(char *s)
Var *sp;
for (sp = varlist; sp != (Var *) 0; sp = sp->next)
if (strcmp(sp->name, s) == 0)
return sp;
return 0;
void LiberaRamVar()
Var *sp, temp;
for (sp = varlist; sp != (Var *) 0; sp = temp.next) {
if (sp->type == CADENA) free(sp->u.str);
else if (sp->type == MATRIX) free(sp->u.matrix);
free(sp->name);
temp.next = sp->next;
free(sp);
Var *install(char *s, int t, float d)
/* char *s;
int t;
float d; */
Var *sp;
if ((sp = (Var *) malloc(sizeof(Var))) == (Var *) 0) visualiza_error("install",20);
if ((sp->name = (char *) malloc(strlen(s)+1)) == (char *) 0) visualiza_error("install",20);
strcpy(sp->name, s);
sp->type = t;
sp->u.val = d;
sp->next = varlist;
varlist = sp;
return sp;
char simbolo[200];
char simbolo_tipo, simb;
char var_tipo;
char e[22][40] = {
"error de sintaxis",
"parentesis no balanceados",
"ninguna expresion presente",
"signo igual esperado",
"no es una variable",
"tabla de etiquetas llena",
"etiqueta duplicada",
"etiqueta no definida",
"THEN esperado",
"TO esperado",
"demasiados bucles FOR anidados",
"NEXT sin FOR",
"demasiados GOSUBs anidados",
"RETURN sin GOSUB",
"Division por CERO",
"demasiados bucles WHILE anidados",
"WEND sin WHILE",
"STOP por el usuario",
"demasiados bucles DO anidados",
"LOOP sin DO",
"Fallo de Memoria",
"No se permite Redimensionar var"
struct ordenes {
char orden[20];
char simb;
} tabla[] = {
{"print", PRINT},
{"input", INPUT},
{"and",AND},
{"or",OR},
{"not",NOT},
{"if", IF},
{"then", THEN},
{"else",ELSE},
{"goto", GOTO},
{"for", FOR},
{"next", NEXT},
{"to", TO},
{"gosub", GOSUB},
{"return", RETURN},
{"rem", REM},
{"step", STEP},
{"cls", CLS },
{"locate",LOCATE},
{"pause",PAUSE},
{"while", WHILE},
{"wend",WEND},
{"do", DO},
{"loop", LOOP},
{"until", UNTIL},
{"continue",NEXT},
{"dim", DIM},
{"exit",EXIT},
{"let",LET},
{"stop",END},
{"end", END},
{"", END}
#define ABS 70
#define ACOS 71
#define ACOSH 72
#define ASIN 73
#define ASINH 74
#define ATAN 75
#define ATANH 76
#define VALOR 77
#define CIELO 78
#define COS 79
#define COSH 80
#define EXP 81
#define FLOOR 82
#define LOG 83
#define LOG10 84
#define SIN 85
#define SINH 86
#define SQRT 87
#define TAN 88
#define TANH 89
#define PII 90
#define TRUNC 91
#define FRACC 92
#define SIGN 93
#define RND 94
struct ordenes tablaf[] = {
{"abs",ABS},
{"acos",ACOS},
{"acosh",ACOSH},
{"asin",ASIN},
{"asinh",ASINH},
{"atan",ATAN},
{"atanh",ATANH},
{"val",VALOR},
{"ceil",CIELO},
{"cos",COS},
{"cosh",COSH},
{"exp",EXP},
{"floor",FLOOR},
{"log",LOG},
{"log10",LOG10},
{"sin",SIN},
{"sinh",SINH},
{"sqr",SQRT},
{"tan",TAN},
{"tanh",TANH},
{"pi",PII},
{"int",TRUNC},
{"fracc",FRACC},
{"sign",SIGN},
{"rnd",RND},
{"",END}
struct etiqueta {
char nombre[LAB_LEN];
char *p;
struct etiqueta etiqueta_tabla[NUM_LAB];
char *encuentra_etiqueta(), *gpop();
struct pila_for {
Var *var; //int var;
float objeto;
float step;
char *loc;
} fstack[FOR_NEST];
struct pila_for fpop();
char *wpila[WHILE_NEST];
char *gpila[SUB_NEST];
char *dpila[DO_LOOP_NEST];
int ifpila[IF_NEST];
int ftos;
int gtos;
int wtos;
int dtos;
int iftos;
//int exit;
void print(), examina_etiquetas(), encuentra_eol(), ejecuta_goto();
void ejecuta_if(), ejecuta_for(), siguiente(), fempuja(), input();
void gosub(), greturn(), gempuja(), inicializa_eti(), ejecuta_while(), end_while();
void ejecuta_doloop(), end_doloop(), ejecuta_else(), encuentra_else();
void obtiene_exp(float *resultado)
obtiene_simbolo();
if(!*simbolo) {
visualiza_error("obtiene simbolo",2);
return;
nivel0(resultado);
retorno();
void nivel0(float *resultado)
register int op;
float hold;
nivel1(resultado);
while ((op = simb) == AND || op == OR) {
obtiene_simbolo();
nivel1(&hold);
arit(op, resultado, &hold);
void nivel1(float *resultado)
register int op;
float hold;
nivel2(resultado);
while ((op=simb) ==IGUAL || op==NOIGUAL || op==MAYOR
|| op==MAYORIGUAL || op==MENOR || op==MENORIGUAL)
obtiene_simbolo();
nivel2(&hold);
void nivel2(float *resultado)
register char op;
float hold;
nivel3(resultado);
while ((op = *simbolo) == '+' || op == '-') {
obtiene_simbolo();
nivel3(&hold);
void nivel3(float *resultado)
register char op;
float hold;
nivel4(resultado);
while ((op = *simbolo) == '*' || op == '/' || op == '%') {
obtiene_simbolo();
nivel4(&hold);
void nivel4(float *resultado)
float hold;
nivel5(resultado);
if (*simbolo == '^') {
obtiene_simbolo();
nivel4(&hold);
arit('^', resultado, &hold);
void nivel5(float *resultado)
register char op;
op = 0;
if ((simbolo_tipo == DELIMITADOR) && ((*simbolo == (char) 173) ||
(*simbolo == '+') || (*simbolo == '-') || (simb == NOT))) {
if (simb == NOT ) op = simb; else op = *simbolo;
obtiene_simbolo();
nivel6(resultado);
if (op == NOT) *resultado = !(*resultado);
else if (op)
unario (op, resultado);
void nivel6(float *resultado)
if ((*simbolo == '(') && (simbolo_tipo == DELIMITADOR )) {
obtiene_simbolo();
nivel0(resultado);
if (*simbolo != ')')
visualiza_error("nivel6",1);
obtiene_simbolo();
else
primitiva(resultado);
void primitiva(resultado)
float *resultado;
Var *s;
float valor;
switch(simbolo_tipo) {
case VARIABLE:
if (( s = lookup(simbolo)) == 0 )
s = install(simbolo, var_tipo, 0.0);
if (s->type == MATRIX) {
obtiene_simbolo();
if ( *simbolo != '(' ) visualiza_error("primitiva",0);
obtiene_exp(&valor);
filas = trunc(valor);
columnas = 1;
obtiene_simbolo();
if (*simbolo == ',') {
columnas = trunc(valor);
obtiene_simbolo();
if (*simbolo != ')') visualiza_error("primitiva",1);
if (filas < 1 || columnas <1) visualiza_error("primitiva",0);
if (filas > s->filas || columnas > s->columnas) visualiza_error("primitiva",0);
*resultado = s->u.matrix[(filas-1)*(s->columnas)+(columnas-1)];
else
*resultado = s->u.val;
obtiene_simbolo();
return;
case NUMERO:
*resultado = AtoF(simbolo);
obtiene_simbolo();
return;
case FUNCION:
*resultado= funcion(simb);
obtiene_simbolo();
return;
default:
visualiza_error("primitiva default",0);
float funcion(ind)
int ind;
float valor = 0.0;
if (ind == PII) return PI;
obtiene_simbolo();
if (*simbolo != '(') visualiza_error("funcion",1);
obtiene_simbolo();
if (ind != VALOR) nivel0(&valor);
switch (ind) {
case ABS:
valor = abs(valor);
break;
case ACOS:
valor = acos(valor);
break;
case ACOSH:
valor = acosh(valor);
break;
case ASIN:
valor = asin(valor);
break;
case ASINH:
valor = asinh(valor);
break;
case ATAN:
valor = atan(valor);
break;
case ATANH:
valor = atanh(valor);
break;
case VALOR:
if (simbolo_tipo == COMILLA)
char *temp, simb[80];
temp = prog;
strcpy(simb,simbolo);
prog = simb;
prog = temp;
obtiene_simbolo();
break;
if ((simbolo_tipo == VARIABLE) && (var_tipo == CADENA))
Var *s;
if((s = lookup(simbolo)) == 0)
visualiza_error("funcion val",4);
temp = prog;
strcpy(simb,s->u.str);
prog = simb;
prog = temp;
obtiene_simbolo();
break;
visualiza_error("funcion val",0);
break;
case CIELO:
valor = ceil(valor);
break;
case COS:
valor = cos(valor);
break;
case COSH:
valor = cosh(valor);
break;
case EXP:
valor = exp(valor);
break;
case FLOOR:
valor = floor(valor);
break;
case LOG:
valor = log(valor);
break;
case LOG10:
valor = log10(valor);
break;
case SIN:
valor = sin(valor);
break;
case SINH:
valor = sinh(valor);
break;
case SQRT:
valor = sqrt(valor);
break;
case TAN:
valor = tan(valor);
break;
case TANH:
valor = tanh(valor);
break;
case TRUNC:
valor = (float) trunc(valor);
break;
case FRACC:
valor = (valor - trunc(valor));
break;
case SIGN:
if (valor > 0) valor = 1;
else if (valor < 0) valor = -1;
else if (!valor) valor = 0;
break;
case RND:
valor = (float) random();
break;
default:
valor = 0.0;
break;
if (*simbolo != ')') visualiza_error("funcion",1);
return valor;
void arit(o,r,h)
char o;
float *r, *h;
register int t;
switch(o) {
case '-':
*r = *r - *h;
break;
case '+':
*r = *r + *h;
break;
case '*':
*r = *r * *h;
break;
case '/':
if (*h == 0) visualiza_error("arit",14);
*r = (*r)/(*h);
break;
case '%' :
t = (*r) / (*h);
*r = *r - (t * (*h));
break;
case '^':
*r = pow(*r,*h);
break;
case AND:
*r = *r && *h;
break;
case OR:
*r = *r || *h;
break;
case IGUAL:
*r = *r == *h;
break;
case NOIGUAL:
*r = *r != *h;
break;
case MAYOR:
*r = *r > *h;
break;
case MAYORIGUAL:
*r = *r >= *h;
break;
case MENOR:
*r = *r < *h;
break;
case MENORIGUAL:
*r = *r <= *h;
break;
void unario(o,r)
char o;
float *r;
if ((o == '-') || (o == (char) 173 )) *r = -(*r);
float encuentra_var(s)
char *s;
Var *v;
if (!esalfa(*s)) {
visualiza_error("encuentra_var",4);
return 0;
if (( v = lookup(simbolo)) == 0 )
v = install(simbolo, var_tipo, 0.0);
return v->u.val;
void visualiza_error(rutina,error)
char *rutina;
int error;
printf("\n%s Error #%d:\n%s\n", rutina, error, e[error]);
longjmp(e_buf, 1);
register char *temp, op;
simbolo_tipo = 0; simb = 0; var_tipo = VARIABLE;
temp = simbolo;
/* if (kbhit() == KEY_ESC) { GKeyFlush(); visualiza_error("obtiene_simbolo",17);} */
if (*prog == '\0') {
*simbolo = 0;
simb = FINISHED;
return(simbolo_tipo = DELIMITADOR);
while (esblanco(*prog)) ++prog;
if (*prog == ':') {
*temp = *prog;
++prog; temp++;
temp = '\0';
simb = EOL;
return (simbolo_tipo = DELIMITADOR);
if (*prog == '\n') {
++prog;
iftos = 0;
simb = EOL;
*simbolo = '\0';
if (*prog == '\'') {
*temp = *prog; ++prog; ++temp; temp= '\0';
simb = REM;
return (simbolo_tipo= ORDEN);
if (strchr("<>=", *prog)) {
*temp = *prog;
op = *prog;
prog++;
temp++;
switch (op) {
case '>' :
if (*prog == '=') { simb= MAYORIGUAL; prog++; temp++; }
else simb= MAYOR;
break;
case '<' :
if (*prog == '=') { simb = MENORIGUAL; prog++; temp++; }
else if (*prog == '>') { simb = NOIGUAL; prog++; temp++; }
else simb = MENOR;
break;
case '=' : simb = IGUAL;
break;
*temp = 0;
return ( simbolo_tipo = DELIMITADOR);
if (strchr("+-*/^%;(),", *prog) || *prog == (char) 173) {
*temp = *prog;
prog++;
temp++;
*temp = 0;
if (*prog == '"') {
prog++;
while (*prog != '"' && *prog != '\n') *temp++ = *prog++;
if ( *prog == '\n') visualiza_error("obtiene_simbolo",1);
prog++; *temp = 0;
return( simbolo_tipo = COMILLA);
if (esdigito( *prog) || *prog == '.' ) {
while ( !esdelim(*prog)) *temp++ = *prog++;
*temp = '\0';
return (simbolo_tipo = NUMERO);
if (esalfa(*prog)) {
while (!esdelim(*prog)) *temp++ = *prog++;
if (*(temp-1) == '$') var_tipo = CADENA; else var_tipo = VARIABLE;
simbolo_tipo = CADENA;
*temp = '\0';
if(simbolo_tipo == CADENA ) {
simb = busca(simbolo);
if (!simb) {
simb = buscaf(simbolo);
if (!simb)
simbolo_tipo = VARIABLE;
else
simbolo_tipo = FUNCION;
else
switch (simb) {
case AND:
simbolo_tipo = DELIMITADOR;
break;
case OR:
break;
case NOT:
break;
default :
simbolo_tipo = ORDEN;
break;
return simbolo_tipo;
void retorno()
char *t;
t = simbolo;
if (*simbolo == '\0') prog--;
else
for ( ; *t; t++ ) prog-- ;
int busca(s)
char *s;
register int i;
char *p;
p = s;
while (*p) {
*p = tolower(*p); p++;
for (i = 0; *tabla[i].orden; i++)
if (!strcmp(tabla[i].orden, s)) return tabla[i].simb;
return 0;
int buscaf(s)
char *s;
register int i;
char *p;
p = s;
while (*p) {
for (i = 0; *tablaf[i].orden; i++)
if (!strcmp(tablaf[i].orden, s)) return tablaf[i].simb;
return 0;
int esblanco(c)
char c;
if (c== ' ' || c == '\t') return 1;
else return 0;
int esdelim(c)
char c;
if (strchr(" +-*/^%;=(),<>:", c) || c == '\n') return 1;
else return 0;
int esalfa(c)
char c;
return isalpha(c);
int esdigito(c)
char c;
return isdigit(c);
// Main Function
int main(int argc,char *argv[])
char *p_buf;
// char name[12];
char instruccion[255];
char *path= "./", name[128];
// FILE *out;
clrscr();
printf("Useless BASIC V 0.1B\n");
if (argc< 2) {
printf("\nUSE: BASIC FileName\n");
exit(1);
varlist = NULL;
if (!(p_buf = (char *) malloc(PROG_SIZE))) {
printf("\nasignacion fracasada.");
exit(1);
//strcpy(name, "bas");
sprintf(name,"%s%s.bas",path,argv[1]);
if(!carga_programa(p_buf, name)) { free(p_buf); exit(1); };
if (setjmp(e_buf)) {
LiberaRamVar();
free(p_buf);
exit(1);
prog = p_buf;
examina_etiquetas();
ftos = 0;
gtos = 0;
wtos = 0;
dtos = 0;
iftos = 0;
out = fopen("lst","wt");
while (*prog) {
obtiene_simbolo();
if (*simbolo == '\n') {*simbolo = '\n'; simbolo[1]= '\0';}
fprintf(out,"simb=%s,tipo:%d,char:%d\n", simbolo, simbolo_tipo, simb);
fclose(out);
prog = p_buf;
//GKeyIn (NULL, 0); free(p_buf); exit(1);
do {
do {
simbolo_tipo = obtiene_simbolo();
//printf("[%s]",simbolo);
if (simbolo_tipo == VARIABLE) {
retorno();
asignar();
else
switch(simb) {
case LET:
asignar();
break;
case PRINT:
print();
break;
case GOTO:
ejecuta_goto();
break;
case IF:
ejecuta_if();
break;
case ELSE:
ejecuta_else();
break;
case FOR:
ejecuta_for();
break;
case NEXT:
siguiente();
break;
case WHILE:
ejecuta_while();
break;
case WEND:
end_while();
break;
case INPUT:
input();
break;
case GOSUB:
gosub();
break;
case RETURN:
greturn();
break;
case REM:
rem();
break;
case CLS:
clrscr();
break;
case LOCATE:
locate();
break;
case PAUSE:
getch();
break;
case DO:
ejecuta_doloop();
break;
case LOOP:
end_doloop();
break;
case DIM :
ejecuta_dim();
break;
case EXIT:
ejecuta_exit();
break;
case END:
free(p_buf);
exit(0);
} while ( simb != FINISHED);
printf("\n? ");
//scanf("%s",instruccion); //
fgets(instruccion,sizeof(instruccion),stdin);
//printf(instruccion);
prog = instruccion;
obtiene_simbolo();
retorno();
} while (simb != FINISHED);
free(p_buf);
LiberaRamVar();
printf("Bye!\n\n");
return(0);
int carga_programa( char *p, char *fnombre)
FILE *fp;
int i = 0;
if (!(fp = fopen(fnombre, "rt"))) return 0;
i = 0;
do {
*p = getc(fp);
p++; i++;
} while (!feof(fp) && i < PROG_SIZE);
*(--p) = '\0';
fclose(fp);
return 1;
void asignar()
float valor;
Var *s;
filas = 0; columnas= 1;
obtiene_simbolo();
if (!esalfa(*simbolo)) {
visualiza_error("asignar",4);
return;
obtiene_simbolo();
if ( *simbolo != '(' ) visualiza_error("asignar",0);
columnas = 1;
obtiene_simbolo();
obtiene_simbolo();
if (*simbolo != ')') visualiza_error("asignar",1);
if (filas < 1 || columnas <1) visualiza_error("asignar",0);
if (filas > s->filas || columnas > s->columnas) visualiza_error("asignar",0);
obtiene_simbolo();
if (*simbolo != '=') {
visualiza_error("asignar",3);
return;
obtiene_simbolo();
if (simbolo_tipo == COMILLA) {
if ((s->u.str = (char *) malloc(strlen(simbolo)+1)) == 0) visualiza_error("asignar",20);
strcpy(s->u.str, simbolo);
else {
retorno();
s->u.matrix[(filas-1)*s->columnas+columnas-1]= valor;
else
s->u.val = valor;
void print()
float result;
int len = 0, espacios;
char ultimo_delim= '\0';
char buffer[80];
do {
obtiene_simbolo();
if ( simb == EOL || simb == FINISHED) break;
if ( simbolo_tipo == COMILLA) {
printf(simbolo);
len += strlen(simbolo);
obtiene_simbolo();
else if ( (simbolo_tipo == VARIABLE) && (var_tipo == CADENA) ) {
Var *s;
printf(s->u.str);
obtiene_simbolo();
else {
retorno();
obtiene_exp(&result);
obtiene_simbolo();
sprintf(buffer,"%f",result);
printf(buffer);
len += strlen(buffer);
ultimo_delim = *simbolo;
espacios = 4 - (len % 4);
len += espacios;
while (espacios) {
printf(" ");
espacios--;
else if (*simbolo == ';') ;
else if (simb != EOL && simb != FINISHED) visualiza_error("print",0);
} while ( *simbolo == ';' || *simbolo == ',');
if (simb == EOL || simb == FINISHED) {
if ( ultimo_delim != ';' && ultimo_delim != ',') printf ("\n");
else visualiza_error("print",0);
void examina_etiquetas()
register int loc;
char *temp;
inicializa_eti();
temp = prog;
obtiene_simbolo();
if (simbolo_tipo == NUMERO) {
strcpy(etiqueta_tabla[0].nombre, simbolo);
etiqueta_tabla[0].p = prog;
encuentra_eol();
do {
obtiene_simbolo();
if ( simbolo_tipo == NUMERO ) {
loc = obtiene_siguiente_etiqueta(simbolo);
if ( loc == -1 || loc == -2 ) {
(loc == -1) ? visualiza_error("examina_etiquetas",5) : visualiza_error("examina_etiquetas",6);
strcpy(etiqueta_tabla[loc].nombre, simbolo);
etiqueta_tabla[loc].p = prog;
if (simb != EOL ) encuentra_eol();
prog = temp;
void encuentra_eol()
while( *prog != '\n' && *prog != '\0' && *prog != '\r') ++prog;
if (*prog) prog++;
int obtiene_siguiente_etiqueta(char *s)
register int t;
for (t = 0; t<NUM_LAB; ++t) {
if (etiqueta_tabla[t].nombre[0] == 0) return t;
if (!strcmp(etiqueta_tabla[t].nombre,s)) return -2;
return -1;
char *encuentra_etiqueta(char *s)
register int t;
if ( !strcmp(etiqueta_tabla[t].nombre,s)) return etiqueta_tabla[t].p;
return '\0';
void ejecuta_goto()
char *loc;
obtiene_simbolo();
loc = encuentra_etiqueta(simbolo);
if (loc == '\0')
visualiza_error("ejecuta_goto",7);
else prog = loc;
void inicializa_eti()
register int t;
for ( t = 0; t<NUM_LAB; ++t) etiqueta_tabla[t].nombre[0] = '\0';
void ejecuta_if()
float x;
obtiene_exp(&x);
if (x) {
obtiene_simbolo();
if ( simb != THEN) {
visualiza_error("ejecuta_if",8);
return;
obtiene_simbolo();
retorno();
ejecuta_goto();
return;
else retorno();
ifpila[iftos++] = 1;
else { ifpila[iftos++] = 0; encuentra_else();}
void encuentra_else()
int count = 0;
while ((count >0) || (*simbolo == ':') || ( simb != EOL && simb != ELSE) ) {
if (simb == IF) count++;
if (simb == ELSE) count--;
obtiene_simbolo();
retorno();
void ejecuta_else()
if (ifpila[--iftos]) encuentra_eol();
void ejecuta_for()
struct pila_for i;
float valor;
int count = 1;
obtiene_simbolo();
visualiza_error("ejecuta_for",4);
return;
if (( i.var = lookup(simbolo)) == 0 )
i.var = install(simbolo, var_tipo, 0.0);
obtiene_simbolo();
if (*simbolo != '=' ) {
visualiza_error("ejecuta_for",3);
return;
i.var->u.val = valor;
obtiene_simbolo();
if ( simb != TO ) visualiza_error("ejecuta_for",9);
obtiene_exp(&i.objeto);
obtiene_simbolo();
if (simb == STEP)
obtiene_exp(&i.step);
else {
retorno();
i.step = 1.0;
if ( ((i.objeto >= valor) && (i.step > 0)) ||
((i.objeto < valor) && (i.step < 0)) ) {
i.loc = prog;
fempuja(i);
else
do {
if (simb == FOR ) count ++;
if (simb == NEXT) count --;
obtiene_simbolo();
} while (count > 0);
void siguiente()
struct pila_for i;
i = fpop();
i.var->u.val = i.var->u.val + i.step;
if (i.var->u.val > i.objeto) return;
fempuja(i);
prog = i.loc;
void fempuja(struct pila_for i)
if (ftos > FOR_NEST)
visualiza_error("fempuja",10);
fstack[ftos] = i;
ftos++;
ftos--;
if (ftos<0) visualiza_error("fpop",11);
return( fstack[ftos]);
void input()
char str[80];
float valor, index;
Var *s;
do {
obtiene_simbolo();
printf(simbolo);
obtiene_simbolo();
if (*simbolo != ',') visualiza_error("input",1);
obtiene_simbolo();
printf("? ");
scanf("%s", str); //gets(str);
if (var_tipo == VARIABLE)
temp = prog;
strcpy(simb,str);
prog = simb;
prog = temp;
obtiene_simbolo();
visualiza_error("input",0);
obtiene_exp(&index);
filas = trunc(index);
columnas = 1;
obtiene_simbolo();
columnas = trunc(index);
obtiene_simbolo();
s->u.matrix[(filas-1)*(s->columnas)+(columnas-1)]= valor;
else
s->u.val = valor;
else {
if ((s->u.str = (char *) malloc(strlen(str)+1)) == 0)
visualiza_error("input",20);
strcpy(s->u.str, str);
putchar('\n');
obtiene_simbolo();
} while(*simbolo == ',');
retorno();
void gosub()
char *loc;
obtiene_simbolo();
if (loc == '\0')
visualiza_error("gosub",7);
else {
gempuja(prog);
prog = loc;
void greturn()
prog = gpop();
void gempuja(char *s)
gtos ++;
if ( gtos == SUB_NEST) {
visualiza_error("gempuja",12);
return;
gpila[gtos]= s;
char *gpop()
if (gtos == 0) {
visualiza_error("gpop",13);
return 0;
return (gpila[gtos--]);
void wempuja(char *s)
wtos++;
if (wtos == WHILE_NEST) {
visualiza_error("wempuja",15);
return;
wpila[wtos]= s;
char *wpop()
if (wtos == 0) {
visualiza_error("wpop",16);
return 0;
return (wpila[wtos--]);
void ejecuta_while()
float valor;
int count = 1;
retorno(); //regresa simbolo while
wempuja(prog); // toma nota de la posicion
obtiene_simbolo(); // recupera el simbolo while
obtiene_exp(&valor); // ve si se va a ejecutar
if (!valor) { // si no se salta hasta el wend final
do {
if (simb == WHILE ) count++;
if (simb == WEND ) count--;
obtiene_simbolo();
wtos--;
void end_while()
prog = wpop();
void dempuja(char *s)
dtos++;
if (dtos == DO_LOOP_NEST) {
visualiza_error("dempuja",18);
return;
dpila[dtos]= s;
char *dpop()
if (dtos == 0) {
visualiza_error("dpop",19);
return 0;
return dpila[dtos];
dempuja(prog);
void end_doloop()
float valor;
obtiene_simbolo();
switch (simb) {
case WHILE:
if (valor) prog = dpop();
else dtos--;
break;
case UNTIL:
if (!valor) prog = dpop();
else dtos --;
break;
default : //do - loop sin fin
prog= dpop();
//visualiza_error("end_doloop",0);
break;
void rem()
encuentra_eol();
void locate()
float valor;
int x, y;
x= trunc(valor);
obtiene_simbolo();
if (*simbolo != ',') visualiza_error("locate",0);
y= trunc(valor);
gotoxy(x,y);
void ejecuta_exit()
LiberaRamVar();
exit(1);
void ejecuta_dim()
Var *s;
int i, j, filas, columnas;
short tipo;
float valor;
do {
obtiene_simbolo();
if (simbolo_tipo != VARIABLE) visualiza_error("ejecuta_dim",0);
tipo = MATRIX;
else
tipo = MSTRING;
if ((s = lookup(simbolo)) == 0)
s = install(simbolo, tipo, 0.0);
else
visualiza_error("ejecuta_dim",21);
obtiene_simbolo();
if ( *simbolo != '(' ) visualiza_error("ejecuta_dim",0);
filas = trunc(valor); s->filas = filas;
columnas = 1; s->columnas = columnas;
obtiene_simbolo();
obtiene_simbolo();
if (*simbolo != ')') visualiza_error("ejecuta_dim",1);
if (tipo == MATRIX) {
if ((s->u.matrix = (float *) malloc((filas)*(columnas)*sizeof(float))) == 0)
visualiza_error("ejecuta_dim",20);
for (i = 0; i < filas; i++)
for (j = 0; j < columnas; j++)
s->u.matrix[i*columnas+j] = 0.0;
else {
if ((s->u.mstring = (char *) malloc(filas*columnas*255*sizeof(char))) == 0 )
s->u.mstring[(i*columnas+j)]='\0';
obtiene_simbolo();
} while (*simbolo == ',');
version 0.2 in the next post
RE: BASIC Programs on HP 50G - churichuro - 03-11-2014 03:20 PM
version 0.2 the MY UBasic:
// UBASIC
// Created 06/03/2010
//#include <hpgcc49.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <setjmp.h>
#include <ctype.h>
#include <stdlib.h>
#include <conio.h>
//#include <termios.h>
//#include <unistd.h>
/*int getch(void)
newt;
int ch;
newt = oldt;
ch = getchar();
return ch;
void clrscr()
system("cls"); //clears the screen
void clear_screen()
clrscr();
#include <windows.h>
//Emulador de gotoxy
void gotoxy(int x, int y)
COORD coord;
coord.X=x;
coord.Y=y;
SetConsoleCursorPosition(GetStdHandle(STD_OUTPUT_HANDLE),coord);
//gotoxy function
//void gotoxy(int x,int y)
// printf("%c[%d;%df",0x1B,y,x);
float AtoF(char *s)
char c;
int i;
return atof(s);
#define WAIT_CANCEL system("PAUSE")
#define sys_slowOn() ;
#define sys_slowOff() ;
#define sat_stack_pop_string_alloc(n) ;
#define sat_pop_real(n) ;
#define sat_stack_push_string(n) ;
//#define beep() ;
#define VERSIONUBASIC "UBasic v 0.2b\n"
#define LAB_LEN 20
#define FOR_NEST 100
#define WHILE_NEST 100
#define DO_LOOP_NEST 100
#define IF_NEST 100
#define PROG_SIZE 160000
#define VARIABLE 2
#define NUMERO 3
#define ORDEN 4
#define CADENA 5
#define COMILLA 6
#define FUNCION 7
#define MSTRING 8
#define MATRIX 20
#define EOL 9
#define FINISHED 10
#define AND 11
#define OR 12
#define IGUAL '='
#define NOIGUAL 14
#define MAYOR '>'
#define MENOR '<'
#define NOT 19
#define MOD 20
#define PRINT 21
#define INPUT 22
#define IF 23
#define ELSE 24
#define FOR 25
#define NEXT 26
#define GOTO 27
#define GOSUB 28
#define RETURN 29
#define REM 30
#define CLS 31
#define LOCATE 32
#define PAUSE 33
#define WHILE 34
#define WEND 35
#define DO 36
#define LOOP 37
#define DIM 38
#define EXIT 39
#define LET 40
#define BEEP 41
#define DATA 42
#define READ 43
#define RESTORE 44
#define FIX 45
#define PUSH 46
#define CLEAR 47
#define PLAY 48
#define END 49
#define THEN 53
#define TO 54
#define STEP 55
#define UNTIL 56
#define ABS 70
#define ACOS 71
#define ACOSH 72
#define ASIN 73
#define ASINH 74
#define ATAN 75
#define ATANH 76
#define VALOR 77
#define CIELO 78
#define COS 79
#define COSH 80
#define EXP 81
#define FLOOR 82
#define LOG 83
#define LOG10 84
#define SIN 85
#define SINH 86
#define SQRT 87
#define TAN 88
#define TANH 89
#define PII 90
#define TRUNC 91
#define FRACC 92
#define SIGN 93
#define RND 94
#define LEN 95
#define ASC 96
#define INSTR 97
#define INT 98
#define POP 99
#define LEFT 100
#define RIGHT 101
#define MID 102
#define TAB 103
#define CHR 104
#define STRING 105
#define POPSTR 106
#define STR 107
#define INKEY 108
#define PI 3.141516
char *prog, *prog_begin;
char *p_buf;
double fixval = 6.2;
FILE *datread;
carga_programa(), buscaf(), indice_cad();
double encuentra_var(), funcion();
void printbasic(), examina_etiquetas(), encuentra_eol(), ejecuta_goto();
void ejecuta_if(), ejecuta_for(), siguiente(), fempuja(), input(), Pause();
void /*beep(),*/ data(), restore(), Read(), fix(), push(), play(), final();
typedef void (*xyx)(void);
xyx XYX[] = {
printbasic,
input,
ejecuta_if,
ejecuta_else,
ejecuta_for,
siguiente,
ejecuta_goto,
gosub,
greturn,
rem,
clear_screen,
locate,
pause,
ejecuta_while,
end_while,
ejecuta_doloop,
ejecuta_dim,
ejecuta_exit,
asignar,
beep,
data,
read,
fix,
push,
clear,
play
typedef union {
double val;
double *matrix;
char *str;
char *mstring;
} tipos;
char *name;
short type;
union {
double val;
double *matrix;
char *str;
char *mstring;
} u;
struct Var *next;
} Var;
Var *varlist = 0;
Var *sp;
for (sp = varlist; sp !=NULL; sp = sp->next)
return sp;
return 0;
void LiberaRamVar()
Var *sp, temp;
for (sp = varlist; sp != NULL; sp = temp.next) {
free(sp->u.str);
free(sp->u.matrix);
free(sp->name);
free(sp);
Var *install(char *s, int t, double d)
Var *sp;
if ((sp = (Var *) malloc(sizeof(Var))) == NULL)
if ((sp->name = (char *) malloc(strlen(s)+1)) == NULL)
sp->type = t;
sp->u.val = d;
sp->next = varlist;
varlist = sp;
return sp;
char simbolo[200];
char var_tipo;
char e[23][40] = {
"THEN esperado",
"TO esperado",
"NEXT sin FOR",
"RETURN sin GOSUB",
"WEND sin WHILE",
"LOOP sin DO",
"Fallo de Memoria",
"No se permite Redimensionar var",
"argumento negativo"
struct ordenes {
char orden[20];
char simb;
} tabla[] = {
{"print", PRINT},
{"input", INPUT},
{"and",AND},
{"or",OR},
{"not",NOT},
{"if", IF},
{"then", THEN},
{"else",ELSE},
{"goto", GOTO},
{"for", FOR},
{"next", NEXT},
{"to", TO},
{"gosub", GOSUB},
{"return", RETURN},
{"rem", REM},
{"step", STEP},
{"cls", CLS },
{"locate",LOCATE},
{"pause",PAUSE},
{"while", WHILE},
{"wend",WEND},
{"do", DO},
{"loop", LOOP},
{"until", UNTIL},
{"continue",NEXT},
{"dim", DIM},
{"exit",EXIT},
{"let",LET},
{"stop",END},
{"beep", BEEP},
{"restore",RESTORE},
{"data",DATA},
{"read",READ},
{"end", END},
{"fix", FIX},
{"push", PUSH},
{"clear", CLEAR},
{"play", PLAY},
{"mod", MOD},
{"", END}
{"abs",ABS},
{"acos",ACOS},
{"acosh",ACOSH},
{"asin",ASIN},
{"asinh",ASINH},
{"atan",ATAN},
{"atanh",ATANH},
{"val",VALOR},
{"ceil",CIELO},
{"cos",COS},
{"cosh",COSH},
{"exp",EXP},
{"floor",FLOOR},
{"log",LOG},
{"log10",LOG10},
{"sin",SIN},
{"sinh",SINH},
{"sqr",SQRT},
{"tan",TAN},
{"tanh",TANH},
{"pi",PII},
{"int",TRUNC},
{"fracc",FRACC},
{"sign",SIGN},
{"rnd",RND},
{"len",LEN},
{"asc",ASC},
{"instr",INSTR},
{"int",INT},
{"pop",POP},
{"",END}
struct ordenes tablafstr[] = {
{"inkey", INKEY},
{"left", LEFT},
{"right", RIGHT},
{"mid", MID},
{"chr", CHR},
{"str", STR},
{"tab", TAB},
{"string", STRING},
{"popstr", POPSTR},
{"", END}
struct etiqueta {
char *p;
struct pila_for {
Var *var;
double objeto;
double step;
char *loc;
} fstack[FOR_NEST];
int ftos;
int gtos;
int wtos;
int dtos;
int iftos;
#define DATAFILENAME "datbasfl.dat"
int DataOK;
void obtiene_exp(double *resultado)
obtiene_simbolo();
if(!*simbolo) {
return;
nivel0(resultado);
retorno();
void nivel0(double *resultado)
register int op;
double hold;
nivel1(resultado);
obtiene_simbolo();
nivel1(&hold);
void nivel1(double *resultado)
register int op;
double hold;
nivel2(resultado);
obtiene_simbolo();
nivel2(&hold);
void nivel2(double *resultado)
register char op;
double hold;
nivel3(resultado);
obtiene_simbolo();
nivel3(&hold);
void nivel3(double *resultado)
register char op;
double hold;
nivel4(resultado);
while ((op = *simbolo) == '*' || op == '/' || simb == MOD) {
if (simb == MOD) op = simb; else op = *simbolo;
obtiene_simbolo();
nivel4(&hold);
void nivel4(double *resultado)
double hold;
nivel5(resultado);
obtiene_simbolo();
nivel4(&hold);
void nivel5(double *resultado)
register char op;
op = 0;
obtiene_simbolo();
nivel6(resultado);
else if (op)
void nivel6(double *resultado)
obtiene_simbolo();
nivel0(resultado);
obtiene_simbolo();
else
double *resultado;
Var *s;
double valor;
case VARIABLE:
obtiene_simbolo();
columnas = 1;
obtiene_simbolo();
obtiene_simbolo();
else
obtiene_simbolo();
return;
case NUMERO:
*resultado = atof(simbolo);
obtiene_simbolo();
return;
case FUNCION:
obtiene_simbolo();
return;
default:
double acosh(double valor) {return(log(valor+sqrt(valor*valor-1.0)));};
double asinh(double valor) {return(log(valor+sqrt(valor*valor+1.0)));};
double atanh(double valor) {return(0.5*log((1.0+valor)/(1.0-valor)));};
double cosh(double valor) {return((exp(valor)+exp(-valor))/2.0);};
double sinh(double valor) {return((exp(valor)-exp(-valor))/2.0);};
double tanh(double valor) {return(sinh(valor)/cosh(valor));};
double funcion(ind)
int ind;
double valor = 0.0;
if (ind == POP) {
//char *c;
// double x;
// c= sat_stack_pop_string_alloc();
// x= sat_pop_real();
// sat_stack_push_string(c);
// return(x);
obtiene_simbolo();
obtiene_simbolo();
if (!((ind == VALOR) || (ind == LEN) || (ind == ASC) || (ind == INSTR))) nivel0(&valor);
switch (ind) {
case ABS:
valor = abs(valor);
break;
case ACOS:
break;
case ACOSH:
break;
case ASIN:
break;
case ASINH:
break;
case ATAN:
break;
case ATANH:
break;
case VALOR:
temp = prog;
prog = simb;
prog = temp;
obtiene_simbolo();
break;
Var *s;
temp = prog;
prog = simb;
prog = temp;
obtiene_simbolo();
break;
break;
case LEN:
valor = strlen(simbolo);
obtiene_simbolo();
break;
Var *s;
visualiza_error("funcion len",4);
valor = strlen(s->u.str);
obtiene_simbolo();
break;
visualiza_error("funcion len",0);
break;
case ASC:
valor = (double) simbolo[0];
obtiene_simbolo();
break;
Var *s;
visualiza_error("funcion asc",4);
valor = (double) (s->u.str)[0];
obtiene_simbolo();
break;
visualiza_error("funcion asc",0);
break;
case INSTR:
char buffer1[200],buffer2[200];
if (!(simbolo_tipo == COMILLA || ((simbolo_tipo == VARIABLE) && (var_tipo == CADENA))))
visualiza_error("funcion instr", 0);
strcpy(buffer1,simbolo);
else if ((simbolo_tipo == VARIABLE) && (var_tipo == CADENA))
Var *s;
visualiza_error("funcion instr",4);
strcpy(buffer1,s->u.str);
obtiene_simbolo();
if (*simbolo != ',') visualiza_error("funcion instr",0);
obtiene_simbolo();
if (!(simbolo_tipo == COMILLA || ((simbolo_tipo == VARIABLE) && (var_tipo == CADENA)) ))
strcpy(buffer2,simbolo);
Var *s;
strcpy(buffer2,s->u.str);
obtiene_simbolo();
valor = (double) indice_cad(buffer1, buffer2);
break;
break;
case CIELO:
break;
case COS:
valor = cos(valor);
break;
case COSH:
break;
case EXP:
valor = exp(valor);
break;
case FLOOR:
break;
case LOG:
valor = log(valor);
break;
case LOG10:
break;
case SIN:
valor = sin(valor);
break;
case SINH:
break;
case SQRT:
if (valor<0) visualiza_error("sqrt",22);
break;
case TAN:
valor = tan(valor);
break;
case TANH:
break;
case TRUNC:
valor = (double) trunc(valor);
break;
case INT:
break;
case FRACC:
break;
case SIGN:
break;
case RND:
valor = (double) rand();
break;
default:
valor = 0.0;
break;
return valor;
void arit(o,r,h)
char o;
double *r, *h;
register int t;
switch(o) {
case '-':
*r = *r - *h;
break;
case '+':
*r = *r + *h;
break;
case '*':
*r = *r * *h;
break;
case '/':
*r = (*r)/(*h);
break;
case MOD :
t = (*r) / (*h);
break;
case '^':
*r = pow(*r,*h);
break;
case AND:
*r = *r && *h;
break;
case OR:
*r = *r || *h;
break;
case IGUAL:
*r = *r == *h;
break;
case NOIGUAL:
*r = *r != *h;
break;
case MAYOR:
*r = *r > *h;
break;
case MAYORIGUAL:
*r = *r >= *h;
break;
case MENOR:
*r = *r < *h;
break;
case MENORIGUAL:
*r = *r <= *h;
break;
void unario(o,r)
char o;
double *r;
double encuentra_var(s)
char *s;
Var *v;
if (!esalfa(*s)) {
return 0;
return v->u.val;
char *rutina;
int error;
encuentra_eol();
LiberaRamVar();
sys_slowOn();
beep();
printf("press [ON].");
WAIT_CANCEL;
if (datread != NULL) fclose(datread);
if (p_buf != NULL) free(p_buf);
exit(1); */
// longjmp(e_buf, 1);
temp = simbolo;
*simbolo = 0;
simb = FINISHED;
if (*prog == ':') {
*temp = *prog;
++prog; temp++;
temp = '\0';
simb = EOL;
if ((*prog == '\n') || (*prog == '\r')) {
++prog;
iftos = 0;
simb = EOL;
*simbolo = '\0';
simb = REM;
*temp = *prog;
op = *prog;
prog++;
temp++;
switch (op) {
case '>' :
else simb= MAYOR;
break;
case '<' :
else simb = MENOR;
break;
break;
*temp = 0;
if (strchr("+-*/^;(),", *prog) || *prog == (char) 173) {
*temp = *prog;
prog++;
temp++;
*temp = 0;
if (*prog == '"') {
prog++;
*temp++ = *prog++;
//if ( *prog == '\n')
// visualiza_error("obtiene_simbolo",0);
prog++; *temp = 0;
*temp = '\0';
*temp = '\0';
if (!simb) {
if (!simb)
else
else
switch (simb) {
case AND:
break;
case OR:
break;
case NOT:
break;
case MOD:
break;
default :
break;
void retorno()
char *t;
t = simbolo;
else
int busca(s)
char *s;
register int i;
char *p;
p = s;
while (*p) {
return 0;
int buscaf(s)
char *s;
register int i;
char *p;
p = s;
while (*p) {
return 0;
int esblanco(c)
char c;
else return 0;
int esdelim(c)
char c;
if (strchr(" +-*/^;=(),<>:", c) || c == '\n' || c == '\r') return 1;
else return 0;
int esalfa(c)
char c;
return isalpha(c);
int esdigito(c)
char c;
return isdigit(c);
int indice_cad(char *cadena, char *subcadena)
int i,j,k;
if ((cadena== NULL) || (subcadena == NULL)) return(0);
for(i=0; cadena[i] != (char *)NULL; i++)
for (j=i, k=0; subcadena[k] == cadena[j]; k++, j++)
if ( subcadena[k+1] == NULL)
return(i+1);
return(0);
void Pause(void)
getch();
while(1)
if (keyb_isAnyKeyPressed())
break;
// sys_setupTimers();
// sys_waitTicks(300000);
// sys_restoreTimers();
// Main Function
// int main(void)
int main(int argc, char *argv[])
//char *p_buf;
char name[128];
char *path= "./";
// SAT_STACK_ELEMENT e;
// SAT_STACK_DATA d;
// char instruccion[255];
// FILE *out;
// sat_get_stack_element(1, &e);
// sat_decode_stack_element(&d, &e);
// if (d.type == SAT_DATA_TYPE_STRING) {
// name = str_unquote(d.sval, '\'');
// } else {
// sat_stack_push_string("Missing Filename");
// sat_push_real(1);
// return (0);
// sys_slowOff();
if (argc< 2) {
system("PAUSE");
exit(1);
sprintf(name,"%s%s",path,argv[1]);
clear_screen();
printf(VERSIONUBASIC);
//printf(name);
varlist = NULL;
exit(1);
prog_begin = p_buf;
prog = p_buf;
fixval = 6.2;
restore();
prog= prog_begin;
if (DataOK)
if ((datread = fopen(DATAFILENAME, "rt")) == NULL)
printf("no hay DATA disponible\n");
ftos = 0;
gtos = 0;
wtos = 0;
dtos = 0;
iftos = 0;
//var_tipo = VARIABLE;
// do {
do {
// if(keyb_isAnyKeyPressed())
// { printf("User Stop.");
// break;
retorno();
asignar();
else { /*
if ((simb > (PRINT-1)) && (simb < (END)))
XYX[simb-PRINT](); //printf("|");
else
switch(simb) {
case LET:
asignar();
break;
case PRINT:
printbasic();
break;
case GOTO:
ejecuta_goto();
break;
case IF:
ejecuta_if();
break;
case ELSE:
ejecuta_else();
break;
case FOR:
ejecuta_for();
break;
case NEXT:
siguiente();
break;
case WHILE:
ejecuta_while();
break;
case WEND:
end_while();
break;
case INPUT:
input();
break;
case GOSUB:
gosub();
break;
case RETURN:
greturn();
break;
case REM:
rem();
break;
case CLS:
clear_screen();
break;
case LOCATE:
locate();
break;
case PAUSE:
Pause();
break;
case DO:
ejecuta_doloop();
break;
case LOOP:
end_doloop();
break;
case DIM :
ejecuta_dim();
break;
case EXIT:
ejecuta_exit();
break;
case BEEP:
beep();
break;
case FIX:
fix();
break;
case RESTORE:
restore();
break;
case READ:
Read();
break;
case DATA:
data();
break;
case PUSH:
push();
break;
case CLEAR:
LiberaRamVar();
break;
case PLAY:
play();
break;
case END:
simb = FINISHED;
break;
printf("\n? ");
gets(instruccion);
prog = instruccion;
obtiene_simbolo();
retorno();
LiberaRamVar();
printf("ready!\n\n");
sys_slowOn();
beep();
printf("press << ON >>\n");
WAIT_CANCEL;
return(0);
FILE *fp;
int i = 0;
i = 0;
do {
*p = fgetc(fp);
p++; i++;
*(--p) = '\0';
fclose(fp);
return 1;
void asignar()
double valor;
Var *s;
obtiene_simbolo();
return;
obtiene_simbolo();
columnas = 1;
obtiene_simbolo();
obtiene_simbolo();
obtiene_simbolo();
return;
obtiene_simbolo();
else {
retorno();
else
s->u.val = valor;
void play()
double tono, duracion;
obtiene_exp(&tono);
obtiene_simbolo();
if (*simbolo != ',') visualiza_error("play",0);
obtiene_exp(&duracion);
//sys_setupTimers();
//sys_playTone( (unsigned int) tono, (unsigned int) duracion);
//sys_restoreTimers();
// la parte entera es el tamaÒo total del campo y
//la parte decimal es la precision de los decimales
void fix()
double result;
fixval = result;
void printbasic()
double result;
char buffer[80], ffix[4],format[20];
sprintf(ffix, "%2.1f", fixval);
strcpy(format,"%");
strcat(format,ffix);
strcat(format,"f");
do {
obtiene_simbolo();
printf(simbolo);
obtiene_simbolo();
Var *s;
printf(s->u.str);
obtiene_simbolo();
else {
retorno();
obtiene_simbolo();
sprintf(buffer,format,result);
printf(buffer);
len += espacios;
while (espacios) {
printf(" ");
espacios--;
if (!(ultimo_delim == ';' || ultimo_delim == ',')) printf ("\n");
void push()
double result;
int len = 0;
char /*buffer[80],*/ ffix[4],format[20];
strcpy(format,"%");
strcat(format,"f");
do {
obtiene_simbolo();
sat_stack_push_string(simbolo);
obtiene_simbolo();
Var *s;
sat_stack_push_string(s->u.str);
obtiene_simbolo();
else {
retorno();
obtiene_simbolo();
//sprintf(buffer,format,result);
//sat_stack_push_double(result);
//len += strlen(buffer);
if (*simbolo == ','||*simbolo == ';') ;
else if (simb != EOL && simb != FINISHED) visualiza_error("push",0);
register int loc;
char *temp;
temp = prog;
inicializa_eti();
obtiene_simbolo();
encuentra_eol();
do {
obtiene_simbolo();
prog = temp;
void restore()
FILE *datafile;
char *temp;
DataOK = 0;
datafile = fopen(DATAFILENAME, "wt");
temp = prog;
prog= prog_begin;
do {
obtiene_simbolo();
if (strcmp(simbolo, "data") == 0) {
DataOK = 1;
do {
obtiene_simbolo();
if ( (simbolo_tipo == COMILLA) || (simbolo_tipo == NUMERO) )
fprintf(datafile, "%s\n",simbolo);
} while (simb != EOL );
fclose(datafile);
prog = temp;
void data()
encuentra_eol();
void Read()
char str[81];
double valor, index;
Var *s;
do {
obtiene_simbolo();
if (fgets(str, 80, datread) == NULL)
visualiza_error("read",2);
temp = prog;
strcpy(simb,str);
prog = simb;
prog = temp;
obtiene_simbolo();
visualiza_error("read",0);
columnas = 1;
obtiene_simbolo();
obtiene_simbolo();
visualiza_error("read",1);
else
s->u.val = valor;
else {
visualiza_error("read",20);
obtiene_simbolo();
} while(*simbolo == ',' || *simbolo == ';');
retorno();
if (*prog) prog++;
register int t;
return -1;
register int t;
return '\0';
void ejecuta_goto()
char *loc;
obtiene_simbolo();
if (loc == '\0')
else prog = loc;
register int t;
void ejecuta_if()
double x;
obtiene_exp(&x);
if (x) {
obtiene_simbolo();
return;
obtiene_simbolo();
retorno();
ejecuta_goto();
return;
else retorno();
int count = 0; // ( simb != EOL && simb != ELSE)
obtiene_simbolo();
retorno();
void ejecuta_else()
void ejecuta_for()
struct pila_for i;
double valor;
int count = 1;
obtiene_simbolo();
return;
obtiene_simbolo();
return;
obtiene_simbolo();
obtiene_simbolo();
if (simb == STEP)
else {
retorno();
i.step = 1.0;
i.loc = prog;
fempuja(i);
else
do {
obtiene_simbolo();
void siguiente()
struct pila_for i;
i = fpop();
fempuja(i);
prog = i.loc;
fstack[ftos] = i;
ftos++;
ftos--;
void input()
char str[80];
Var *s;
do {
obtiene_simbolo();
printf(simbolo);
obtiene_simbolo();
if (!((*simbolo == ',') || (*simbolo == ';'))) visualiza_error("input",1);
obtiene_simbolo();
printf("? ");
/*scanf("%s", str); */ gets(str);
temp = prog;
strcpy(simb,str);
prog = simb;
prog = temp;
obtiene_simbolo();
columnas = 1;
obtiene_simbolo();
obtiene_simbolo();
else
s->u.val = valor;
else {
//putchar('\n');
obtiene_simbolo();
retorno();
void gosub()
char *loc;
obtiene_simbolo();
if (loc == '\0')
else {
gempuja(prog);
prog = loc;
void greturn()
prog = gpop();
gtos ++;
return;
gpila[gtos]= s;
char *gpop()
if (gtos == 0) {
return 0;
wtos++;
return;
wpila[wtos]= s;
char *wpop()
if (wtos == 0) {
return 0;
double valor;
int count = 1;
do {
obtiene_simbolo();
wtos--;
void end_while()
prog = wpop();
dtos++;
return;
dpila[dtos]= s;
char *dpop()
if (dtos == 0) {
return 0;
return dpila[dtos];
dempuja(prog);
void end_doloop()
double valor;
obtiene_simbolo();
switch (simb) {
case WHILE:
else dtos--;
break;
case UNTIL:
else dtos --;
break;
prog= dpop();
break;
void rem()
encuentra_eol();
void locate()
double valor;
int x, y;
x= trunc(valor);
obtiene_simbolo();
y= trunc(valor);
gotoxy(x,y);
void ejecuta_exit()
LiberaRamVar();
beep();
sys_slowOn();
WAIT_CANCEL;
exit(1);
void ejecuta_dim()
Var *s;
short tipo;
double valor;
do {
obtiene_simbolo();
tipo = MATRIX;
else
tipo = MSTRING;
else
obtiene_simbolo();
obtiene_simbolo();
obtiene_simbolo();
if ((s->u.matrix = (double *) malloc((filas)*(columnas)*sizeof(double))) == 0)
else {
obtiene_simbolo();
some examples in the next post
RE: BASIC Programs on HP 50G - churichuro - 03-11-2014 03:29 PM
examp #1: area of circle, here use the stack!
D=POP
A=D*D*PI/4
PRINT "AREA=";A
PUSH A
END
examp #2: from C bible the program Celsius
lower=0
upper=300
step1=20
fahr=lower
while fahr<=upper
celsius=(5.0/9.0)*(fahr-32.0)
print fahr,celsius
fahr=fahr+step1
Wend
end
examp #3: Int. SIMPSON ver 1.
print "Integral por el metodo SIMPSON"
input "lim. inf=",a
input "lim. sup=",b
input "# intervalos=",c
h=(b-a)/c
x=a
gosub 1000
i=f
for m=1 to c/2
x=x+h
gosub 1000
i=i+f*4
x=x+h
gosub 1000
i=i+f*2
next
x=b
gosub 1000
i=i-f
print "i=";i*h/3
end
1000 f=x^3+x^2-x-1
return
end
examp #4: use DATA and READ instructions
print "Ejemplo de datas"
read x,y,z$
print "X=";x
print "Y=";y
print "Z=";z$
data 10, 25.4, "hola!!!"
end
examp #5: here the user can write an equation for X and is evaluate
INPUT "X = ",X
INPUT "EQ=",E$
PRINT VAL(E$)
END
examp #6: int. SIMPSON ver 2.
print "Ecuacion en funcion de x"
input "ejemplo: x^3+x^2-x-1 :",e$
input "limite inf=",a
input "limite sup=",b
print "resolviendo para : f=";e$
h=(b-a)/c
x=a
f=val(e$)
i=f
for m=1 to c/2
x=x+h
f=val(e$)
i=i+f*4
x=x+h
f=val(e$)
i=i+f*2
next
x=b
f=val(e$)
i=i-f
print "i=";i*h/3
end
RE: BASIC Programs on HP 50G - churichuro - 03-11-2014 03:46 PM
instructions for use UBASIC in HP50
I have the program in a directory called BASIC, BAS with the name, and I also have the S2FL program by that name in the same directory.
write the program as a string
and then I write another string that is the name you want to give to the program.
with the program at level 2 of the stack
and the name on the level 1 of the stack
S2FL use the program and this program writes the file to the SD memory
(I did not S2FL program this as an example HPGCC files)
then write the string with the name of the program
and I run the BAS program, which starts the execution of the program.
UBASIC is not a complete interpetre that only runs programs stored in
the SD memory, you can not have a truly interactive environment as in the real BASIC
RE: BASIC Programs on HP 50G - Alvaro - 03-12-2014 10:00 PM
(03-11-2014 03:46 PM)churichuro Wrote: instructions for use UBASIC in HP50
I did start to re-write one of my BAISC programms in ALgebraic Mode , but I was forced to give up because I absolutly need to use Arrays in the programms and the PUT command in ALgebraic Mode is not changing the content of the respective variable, so for me that is FULL STOP with the HP 50g.
That also means that I will not use at all the programing.
It is a shame, such a nice calculator, so powerfull with so many functions , difficult to find in any other calculator, not to have a High Level language like BASIC implemented.
Well, I will have to look for another solution.
RE: BASIC Programs on HP 50G - churichuro - 03-13-2014 08:07 PM
after playing around with this BASIC on the HP50 and the version for Mac OSX
I think I will continue on with the development of this project in my spare time.
the first step will be to handle IF-THEN-ELSE-ENDIF for several lines
the program has the necessary structure to include in future versions handling integer variables, although not one of my priorities.
A major challenge is that the code is not interpreted line by line directly, but rather generate an intermediate code (microcode) as does java, so to have 2 programs one parcer and another to run the semi-compiled code.
RE: BASIC Programs on HP 50G - Manolo Sobrino - 03-13-2014 09:21 PM
(03-13-2014 08:07 PM)churichuro Wrote: after playing around with this BASIC on the HP50 and the version for Mac OSX
I just want to thank churichuro for sharing his/her (?) code. I'll switch to Spanish to do it properly.
Hola churichuro,
Muchas gracias por compartir tu código aquí. No estoy en posición de analizar si es bueno o malo, pero no deja de ser tu trabajo personal y a fin de cuentas son 2000 líneas en las que entre otras cosas implementas un parser. Me extraña que nadie te agradezca al menos el gesto de hacerlo público, pero lo cierto es que a veces esta (llamémosle) comunidad es bastante peculiar. (Eso sí, a bote pronto luciría mucho más si corrigieras el valor de PI, el que has puesto daña gravemente la vista ).
Un saludo,
Manolo
RE: BASIC Programs on HP 50G - Alvaro - 03-14-2014 12:08 PM
Hi churichuro,
Thank you you answer and of course for code.
I have no knowledge of C or even LINUX .
So far I could understand from your UBASIC Project, it is a BASIC to C converter.
I feel that it is a very challenging project, and it involves surely at lot of Knowledge and huge effort from yourself, and also have the fealing that it would be very difficult to get it run for everybody. I think there will be always problems, then it depends very much on how the people are writting there BASIC Programs.
I am wondering if it would not be much more easyier to write a BASIC Interpreter that would run as a Program in the HP.
Somehow your doing, more or less, something like a BASIC Interpreter.
It would be very nice and very usefull if there was a BASIC Interpreter for the HP, at least for, so that the User could write on-the-fly , a BASIC Program.
It would be interesting to know the opinion and of the need of a sBASIC (=short) for the HP Calculators from other HP users.
Once again, thank you.
Regards.
RE: BASIC Programs on HP 50G - dizzy - 03-14-2014 01:44 PM
(03-14-2014 12:08 PM)Alvaro Wrote: (03-13-2014 08:07 PM)churichuro Wrote: after playing around with this BASIC on the HP50 and the version for Mac OSX
Hi churichuro,
Regards.
There are several lightweight open-source BASIC interpreters around that could potentially be compiled under HPGCC.
RE: BASIC Programs on HP 50G - churichuro - 03-14-2014 02:28 PM
(03-13-2014 09:21 PM)Manolo Sobrino Wrote: I just want to thank churichuro for sharing his/her (?) code. I'll switch to Spanish to do it properly.
Hola churichuro,
Un saludo,
Manolo
Manolo Many thanks for your kind words, thank you for your words lifted my spirits, I thought my comments were invisible.
and above all thank you very much for taking the time to do it in Spanish.
Gracias Manolo!, sobre PI, siendo hoy el día donde se festeja este fenómeno matemático, ya lo corregí en la nueva versión que estoy trabajando.
el nuevo valor de PI sera 3.14159265358979323846, no exacto pero al menos mas correcto
RE: BASIC Programs on HP 50G - churichuro - 03-14-2014 02:46 PM
(03-14-2014 12:08 PM)Alvaro Wrote: Hi churichuro,
Regards.
Hello Alvaro
no, my UBasic is not a BASIC to C converter.
my basic is an interpreter, and does exactly what you're asking for.
just that it's still very easy to get the calculator to crash, because my program lacks better error handling.
UBasic works great for me because I know better, now I have several ideas to make it better and safer to use.
right now, you can write your basic program directly into the calculator and run in it, but is more comfortable typing on a regular keyboard and then move this program to the calculator with an SD memory.
and the best part is that compiling the source code UBASIC can have the same program running on your computer, either with Linux, Windows and Mac OSX, and even in a Ti-89, TI-92 and TI-Voyager calculator
RE: BASIC Programs on HP 50G - Alvaro - 03-15-2014 07:23 PM
(03-14-2014 01:44 PM)dizzy Wrote: [quote='Alvaro' pid='6875' dateline='1394798926']
Yes, I found there is the "FreeBASIC". There is also available the SOURCE code. That sounds good.
I have not enough knowledge to go on "FreeBASIC for HP."
RE: BASIC Programs on HP 50G - Alvaro - 03-16-2014 02:45 PM
(03-15-2014 07:23 PM)Alvaro Wrote: (03-14-2014 01:44 PM)dizzy Wrote: [quote='Alvaro' pid='6875' dateline='1394798926']
and there is also the "X11-Basic" that runs in almost every platform, including Android (it runs very well on my ARM-Cortex-´Droid), even it runs on a TomTom Car Navigator System! (But not on a Hp 50g )
http://x11-basic.sourceforge.net/
RE: BASIC Programs on HP 50G - dfnr2 - 03-19-2014 03:55 PM
Very nice, Churichuro. Thanks for sharing. I like your notion of integrating the BASIC with the existing stack mechanism and other calculator functions. I imagine this could turn into a must-have tool for the HP-50G, possibly attracting new users.
RE: BASIC Programs on HP 50G - Howard Owen - 03-19-2014 06:16 PM
Wow! Thanks for the gift of your time and trouble!
In the U.S., and I think internationally now, you have an implied copyright to your code the moment you publish it, as you have done here. That means it is illegal for anyone to copy your code without your permission. If you want your code to be used freely, there are a variety of ways to say that, in a legal way. The list of options is very broad, and understanding them all takes a significant amount of study, but you might be interested in looking over your options. These range from very simple (placing the code in the public domain, for example,) or very elaborate, like the various flavors of the GPL.
For a fairly complete description, see this Wikipedia page.
Here's an off-topic thread regarding using Wikipedia. TINSTAAFL indeed.
