HP-92 Simulation Attempt - Printable Version
+--- Thread: HP-92 Simulation Attempt (/thread-8349.html)
Pages: 1 2
RE: HP-92 Simulation Attempt - teenix - 06-22-2017 05:56 AM
Hi all,
Some Bond/Yield progress finally.
The attached image shows the discounted yield example from the HP92 Investor Applications and on the left is the printout from the HP92 simulator.
Hopefully the rest of the functionality will fall into place easily now.
cheers
Tony
RE: HP-92 Simulation Attempt - PANAMATIK - 07-02-2017 09:26 PM
(06-02-2017 11:49 PM)teenix Wrote:
(06-02-2017 02:52 PM)PANAMATIK Wrote:  I'm sorry, but unfortunately it was a false alarm, he told me it was an HP-91 he could offer. Anyway this will at least lead to the HP-91 ROM code. :-)
That's a shame, but the 91 is still a good score.
The HP-91 ROM code is available http://www.hpmuseum.org/forum/thread-8611.html
I got a friendly offer for the HP-92, but it is impractical far away from here and shipping is too risky. There still doesn't seem to be a 92 in germany.
Bernhard
RE: HP-92 Simulation Attempt - teenix - 07-03-2017 02:35 AM
(07-02-2017 09:26 PM)PANAMATIK Wrote:  The HP-91 ROM code is available http://www.hpmuseum.org/forum/thread-8611.html
Bernhard
10/10 for effort though :-)
I'll have a look at the 91 code when I get a chance. An emulator for it will need a new application.
cheers
Tony
RE: HP-92 Simulation Attempt - teenix - 07-06-2017 06:15 AM
I thought the HP91 and the microcode might be easy to get going but alas, not to be.
I'm sure I translated the source code properly so it works with my emulator, but even after going through all the possible key codes (0 - 255), only 0,1,5,6,9 of the digit keys work, and not all of the other key functions. Those that do work give the correct results on the display, although the display decoding appears to be a little different than I have seen before.
There also seems to be a similar hardware interface like the HP19c for the two switches, which I haven't figured out yet.
Nothing like a challenge :-)
cheers
Tony
