Summation based benchmark for calculators - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Summation based benchmark for calculators (/thread-9750.html) |
RE: Summation based test for calculators - pier4r - 12-24-2017 09:09 AM (12-24-2017 02:32 AM)AlexFekken Wrote: Simpson's rule is for student's only. ... But perhaps it explains your obsession (in this thread) with summations. I do perceive the above sentences as confrontational and belittling. If this would be the case, I don't understand why and I think it is not needed. I mean, whatever the topic is, if it bugs you, you can just ignore it. Said that, some answers. First, thanks for your input about what you think should be a benchmark. Anyway I disagree with it. Not technically though. Technically you may be also right, but because what you suggest is quite time consuming since a benchmark like the one in this thread is based on voluntary participation. If you design a task that is time consuming, likely no one (I myself!) will participate. With no data, there is no benchmark. You yourself said "Lots of words, encouraging you to do lots of work, by someone who isn't going to do that work. ". That confirms my point above. Second. A benchmark is limited in scope. I can benchmark whatever, if someone uses the calculator for a well defined tasks that is not included, even partially, in the benchmark, the benchmark is useless. I think everyone knows this. In this thread I wanted to collect the time needed to repeat some functions from the set of trig , ln/exp, power functions. That's it. And I thank everyone for it! This also leads to the third point. Third: my apparent obsession with summation (thanks for jumping to conclusion!). I see the summation as an easy way to have a loop that tests the given instructions. A loop that can be found also in scientific calculators that are not programmable . If you find another way to let non programmable scientific calculators do a loop without summation or integration, I am interested, seriously. With a summation, a user can quickly press (if the function is available): Sum function, the function as argument of the sum, the variable, extremes. Execute it. Report the time. End of the task. 4th. In connection to the third point. "Simpson's rule is for student's only.". This sounds like "if you are using a decimal approximation of pi with less than 109 digits, your are doing it wrong". If that sounds good to you, good to know. Aside from that, I used the Simpson's rule because the only loop available in a sharp 506w is the numeric integration, and it uses the Simpson's rule (the image posted previously is taken from the 506w manual). Then I tried to adapt the formula in the numeric integration so to have the closes possible similarity between the summation formula and the numeric integration on the 506w. I hope my answers helps to clarify why I did this or that. Going back to the benchmark topic. Is there anyone willing to do the test with a: - a 41 version - 41 CL - dm41 --> covered by grbanks - hp 42s - 35s --> covered by grbanks - 12C (recent) - 15C (LE got covered by Gilles) - 71B - 67 - 34S Thanks for your help! The rest got mostly covered (although having confirmations of the timings, by independent tests, is always good). Well aside from 50g hpgcc and nspire lua, but in those cases the benchmark becomes time consuming, since it is not immediate to program with lua/hpgcc in the calculator. edit: thanks for the additional results Gilles! edit2: thanks for the additional results, Grsbanks! RE: Summation based test for calculators - klesl - 12-24-2017 01:31 PM According to the pier4r 's recommendation I set the settings to approximate and display digits - float 6 Ti-Nspire CX CAS - approx. 2.5s, 1395.35 n=10000 Ti-Nspire CX CAS - approx. 24.5s, 13955.9 RE: Summation based test for calculators - grsbanks - 12-24-2017 10:09 PM (12-24-2017 01:31 PM)klesl Wrote: According to the pier4r 's recommendation I set the settings to approximate and display digits - float 6 I can corroborate these timings, although I get 22.5s for n=10^4 n=10^5 => 222s RE: Summation based test for calculators - pier4r - 12-24-2017 10:19 PM added and fixed some entries thanks to the results of grsbanks! (in some cases timings were confirmed, but information was added) Interesting observations from him Quote:I can confirm that the DM41 is much slower than the DM15/DM11 (I used my DM11L this time around). The DM41 really is a slow machine. Plenty of features, sure, but dog slow. In fact it's the slowest of them all and really not something you want to use for intensive number crunching. Given the results so far I would say. - Impressive the 991ex, pretty quick for its price. In general the flagship casio products are all quite competitive. - the prime is on par with the nspire when using the internal sum function but the limit of 10000 entries sounds bad (although few would use more than 10000 entries). - the prime hp ppl is impressive. 10 times faster than any other calculator reported. (I guess lua with the nspire would reach a similar speed, but it is unusable from the calculator) - the hp 50g summation is more advanced than a userRPL for loop. Well done. Plus it still holds its ground after years. For example in comparison versus the new primz. - newRPL pushes the 50g greatly, well done. - the dm42 is fricking fast. Especially compared to other swissmicro products. - the first nspire (from 2006) is still competitive. Therefore the main systems did not change much in the nspire. - I learned that the ti 89 has quintillions of apps (really, quintillions), but in terms of speed the real competitor was the 48 series. The 50g has almost the double of the speed. - hp 35s . Suprisingly slow! I was expecting the speed of the 15 LE. Still missing: - a 41 version - 41 CL - 12C (recent) - 15C - 71B - 67 - 34S - Casio classpad (if possible 300 . We got the 400) - Some sharpr PC - other interesting calculators (the casio fx5008p for example) RE: Summation based test for calculators - lrdheat - 12-24-2017 11:15 PM WP 34S double on, fix 2: ~185 seconds Double off, fix 2: ~168 seconds RE: Summation based test for calculators - lrdheat - 12-24-2017 11:17 PM CASIO Prizm fox-CG10: ~24.5 seconds (looks like CG50 is about twice as fast with this task) RE: Summation based test for calculators - Paul Dale - 12-24-2017 11:20 PM (12-24-2017 11:15 PM)lrdheat Wrote: WP 34S double on, fix 2: ~185 seconds Firmware version? Version 2 firmware is a fair bit faster than version 3. Using the build in Sigma command or a programmed loop? The latter will be faster. Pauli RE: Summation based test for calculators - lrdheat - 12-24-2017 11:24 PM Version 3.3 3774 My CASIO fx-CG10 report was using it's summation function. RE: Summation based test for calculators - emece67 - 12-25-2017 12:46 AM (12-24-2017 09:09 AM)pier4r Wrote: Going back to the benchmark topic. Is there anyone willing to do the test with a: Amazed by the really small (~10 %) increase in time in the wp34s when switched from 16 to 34 digits. RE: Summation based test for calculators - Paul Dale - 12-25-2017 01:07 AM (12-25-2017 12:46 AM)emece67 Wrote: Amazed by the really small (~10 %) increase in time in the wp34s when switched from 16 to 34 digits. The 34S computes in beyond double precision internally regardless of the mode set. My feeling is that the reduction in memory accesses (copying mostly) account for the bulk of the difference between the two. However, there are a few functions where being in single precision allows some short cuts. Pauli RE: Summation based test for calculators - pier4r - 12-25-2017 08:25 AM (12-24-2017 11:15 PM)lrdheat Wrote: . (12-24-2017 11:17 PM)lrdheat Wrote: . (12-25-2017 12:46 AM)emece67 Wrote: . Thanks! (and Merry Christmas!) edit: It is also interesting to see the difference between systems in this test (that is more math heavy) compared to the 8 queen test (that is more add/sub + memory heavy). In this test newRPL is 5.5 times faster than userRPL on the 50g (6s vs 33s). A bit less when the 50g uses the sum function. In the 8 queen test newRPL is 216 times faster than userRPL (0.106s vs 22.6s). Still missing: - a 41 version - 41 CL - 12C (recent and old) - 71B - 67 - Casio classpad (if possible 300 . We got the 400) - Some sharp PC - other capable (programmable or sum function) calculators (the casio fx5008p for example) RE: Summation based test for calculators - emece67 - 12-25-2017 11:53 AM (12-25-2017 08:25 AM)pier4r Wrote: Still missing: Twice as fast as a 15C, slightly faster than expected. RE: Summation based test for calculators - klesl - 12-25-2017 02:03 PM Casio fx-9700GE - approx. 1m 16s, 1395.34628774 Casio ClassPad 330-A - approx. 18s, 1395.346288 Casio fx-5800P - approx. 2m 46s, 1395.346288 Casio fx-7400GII - approx. 20s, 1395.346288 Casio fx-9860G Slim (hacked to 9860GII OS 2.04) - approx. 23s, 1395.346288 HP-40gs - approx. 34s, 1395.3462877 Canon X Mark I Pro - between 14m a 14m 50s, 1395.346288 Notice: The ClassPad is labeled on the back side as CLASSPAD300PLS, the 330-A is written on the box RE: Summation based test for calculators - pier4r - 12-25-2017 02:25 PM Thanks for the new entries! Observation. As discussed in this thread the 35s, fx5800p and dm42 are the top3 options for a scientific calculator with ability to store many formulas. Anyway I am impressed by the difference of speed between the 35s and the fx5800p (note, it may be that for normal usage this difference will be never noticed). The dm42 is just amazing but it is also 4 time the price of 35s and fx5800p (and again, we are talking only about speed, not common operations). Question to emece67. Is your 15C much older than your 41CV ? Still missing - 41 CL - 12C (recent and old) - 71B - 67 - Some sharp PC - other capable (programmable or sum function) calculators RE: Summation based test for calculators - emece67 - 12-25-2017 02:45 PM (12-25-2017 02:25 PM)pier4r Wrote: Question to emece67. Is your 15C much older than your 41CV ? Cannot say, the 41 I used has its CPU board changed. Originally it was a 41C, now it is a 41CV. I do not know the serial number of the donor machine. Regards. RE: Summation based test for calculators - klesl - 12-25-2017 06:16 PM All my previous tests used sum function. n=1000 Casio Basic, loop "For To Next" Casio fx-50F PLUS - approx. 10m 33s, 1395.346288 Casio fx-3650PII - approx. 9m 22s, 1395.346288 ---------------------------------------- Integral calculation Sharp EL-W506X - approx. 64s, 1394.866122 Sharp EL-506X - approx. 97s, 1394.026202, n=500 RE: Summation based test for calculators - BobVA - 12-25-2017 07:24 PM HP-67. 100 terms (139.2925695) took 5m 40s. RE: Summation based test for calculators - pier4r - 12-25-2017 08:06 PM (12-25-2017 06:16 PM)klesl Wrote: - (12-25-2017 07:24 PM)BobVA Wrote: - Both included. Thanks and Merry Christmas /happy holidays. Still missing - 41 CL - 12C (recent and old) - 71B - Some sharp PC - other capable (programmable or sum function) calculators RE: Summation based test for calculators - BobVA - 12-26-2017 03:45 AM HP-41CL / x50 speed: 100 iterations (139.2926) 15s RE: Summation based test for calculators - mfleming - 12-26-2017 05:43 AM (12-26-2017 03:45 AM)BobVA Wrote: HP-41CL / x50 speed: 100 iterations (139.2926) 15s I get something different. 41CL, v5 board, TURBO 50. Using the Sigma+ function to accumulate intermediate values because it has the advantage of returning the index X each invocation. Twelve instructions from the loop header label to the bottom GTO with no instructions other than the 41C/CV/CX defaults: 10 13.711835 0.55 seconds 100 139.297187 5.13 seconds 1,000 1395.346260 48.31 seconds 10,000 13955.84859 7 minutes 48.24 seconds Oddly, this quick hack turned out to be faster than dedicated register counter and accumulator versions. I guess that's the speed advantage of MCODE over FOCAL programs, eh? Interesting problem to play with! ~Mark |
