HP97 The journey begins - Printable Version
+--- Thread: HP97 The journey begins (/thread-12156.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
RE: HP97 The journey begins - teenix - 02-22-2022 12:03 AM
I just tracked down the reason.
The day of week calculation in the PIC code is the one used in HP-65 Standard Pac 1, then 1 is added to the result. This is because the clock chip uses 1=Sunday.
On the next release, I will make sure when displaying the day, that 1 is subtracted.
cheers
Tony
RE: HP97 The journey begins - BMH - 02-25-2022 05:42 PM
Wow Tony. This whole journey is a fascinating read, and like many others I am very impressed.
With all you have done here, I wonder if you might consider designing and releasing a Bluetooth / USB I/O module for the 41C? it would mimic the card reader and / or printer? Seems like it would be a very easy project for you. I'd certainly buy. Please pardon me if it has already been done, and I just haven’t found it in the forums. Thanks.
RE: HP97 The journey begins - teenix - 02-25-2022 10:43 PM
(02-25-2022 05:42 PM)BMH Wrote:  Wow Tony. This whole journey is a fascinating read, and like many others I am very impressed.
It sounds interesting but I don't have a 41 and I'm not sure how complicated designing a module both electronics and hardware like case, connections, would be.
RE: HP97 The journey begins - tangdfx - 02-26-2022 03:29 AM
The HP41 already has the HP41CL FPGA cpu board replacement.
It will be more interesting to build a red LED version of HP41 .
The screen candidate will be HPDL1414 which is a alphanumeric LED module.
And Tony is very busy on the other project.
Here is another project in my wishlist which is the HP 01.
Below link is the video which shows project to use the HPDL1414 to make and LED watch.
https://b23.tv/nSaXMLw
https://b23.tv/rGWbZjB
Scott
RE: HP97 The journey begins - Paul Dale - 02-26-2022 06:48 AM
A donation 41 is entirely possible. At least once mine come out of storage....
Pauli
RE: HP97 The journey begins - teenix - 02-26-2022 08:46 AM
(02-26-2022 06:48 AM)Paul Dale Wrote:  A donation 41 is entirely possible. At least once mine come out of storage....
Pauli
I just worked through some minor bugs which appeared with some new additions I made for 67 and 97. I just spent the day chasing these down, mostly just a flag not set properly, and have uploaded again. I am going to stop new stuff for awhile until everything settles down.
cheers
Tony
RE: HP97 The journey begins - tangdfx - 02-26-2022 12:44 PM
Great job Tony.
I just flash the v13 for 97 and v27 for 67.
As the 67 and 97 are a matched set.
Is it possbile that 67 and 97 could transfer program and data through bluetooth directly?
I know this could be done by the card reader.
But through bluetooth will be a great feature.
RE: HP97 The journey begins - teenix - 02-26-2022 02:41 PM
(02-26-2022 12:44 PM)tangdfx Wrote:  Great job Tony.
The Bluetooth modules in the CPU boards are slaves, a transfer like that would have to be initiated from a master.
cheers
Tony
RE: HP97 The journey begins - teenix - 03-04-2022 12:37 AM
Hi all,
I got my new tactile Spice keyboard inserts today. I haven't tried them because the CPU board is not ready yet, I'm just finalizing the design.
cheers
Tony
RE: HP97 The journey begins - tangdfx - 03-04-2022 06:04 AM
This like a modern design like sharp and casio calculator.
RE: HP97 The journey begins - teenix - 03-04-2022 06:10 AM
(03-04-2022 06:04 AM)tangdfx Wrote:  This like a modern design like sharp and casio calculator.
Like the original membrane switches.
RE: HP97 The journey begins - Harald - 03-06-2022 08:48 AM
(03-04-2022 12:37 AM)teenix Wrote:  Hi all,
cheers
Tony
Looks good!
My parts still haven't arrived, have they? I have not seen any progress in the tracking for weeks. I have inquired and they told me average time for a parcel to Australia is 40 days now.
o:-)
RE: HP97 The journey begins - teenix - 03-06-2022 06:40 PM
(03-06-2022 08:48 AM)Harald Wrote:  Looks good!
o:-)
I haven't seen anything. Airmail seems up in the air these days (excuse the pun) Sometimes you cannot even post at all.
I'm looking into a battery charger at the moment. USB LiPo chargers a plentiful and cheap, so I might just have to provide a matching socket.
cheers
Tony
RE: HP97 The journey begins - Dreato - 03-08-2022 05:31 PM
I'm the proud owner of both the HP67C and 97C boards, and one of my goals was to be able to share programs, or blocks of programs between calculators via my PC, since my My HP97C has no card reader. I've read Tony's thorough documentation about both these boards, and his software packages (CCE = emulator and CalCom = Bluetooth PC communication). I've summarized what I've learned in the attached 'Teenix Cheatsheet'. Please feel free to look at this and to comment as needed. I'm sure it contains some mistakes.
BTW, now I CAN save, edit and share programs between these 2 machines.
A long-term goal would be for all of US to share programs with each other directly, not just the program listings that need to be typed in by hand.
Best Regards,
Dave
RE: HP97 The journey begins - tangdfx - 03-10-2022 12:45 PM
As the HP67C and HP97C user ,I totally agree with you.
And I also wish to add an function that the HP41 program can transfer from PC to HP67C or HP97C then read by HP41 card reader.
This is an indirectly way to transfer HP41 program from PC to a real HP41.
RE: HP97 The journey begins - Dreato - 03-29-2022 04:30 PM
Couple comments on the HP41 and using HP 67 programs on a 41. This is probably a repetition of other posts on this site, but it's my personal experience.
1) I've repaired and sold a few HP 41s and the 41 card reader. The HP41 series continued the HP trend that started with the spice series to "cheap out" on manufacture and assembly. The assembly required no soldering or gold plated pins. Just flexible circuit boards with bare spots pressed against each other for contact. Sometimes just cleaning these contacts will restore a 41, sometimes not. Not surprisingly, NiCd battery corrosion was also a problem. If it was bad, the flexible PCB could be beyond rescue. This PCB connected the 4 module ports and the battery contacts. There are folks who sell replacement flexible PCBs for the 41.
2) The card reader was designed to save and load programs for the 41, and added circuitry to read and translate HP67/97 programs to execute in the 41. The translation ROMs are built into the card reader. There's not a 1:1 equivalency for all the 67/97 functions, so new 41 instruction are added to make the 41 operate 'like' a 67/97. The 41 display will tell you when the translation is taking place, and when it's complete. This is a 'one way street'. You can't edit the program on the 41 and save it to a card to run on a 67/97. Won't work. I assume that HP built the compatibility for 67/97 programs to ease the transition to the new platform, so users wouldn't have to re-enter their favorite programs.
Dave
RE: HP97 The journey begins - teenix - 05-29-2022 01:11 AM
Hi all,
I just got to the stage of getting the Spice circuit boards fabricated and the semiconductor shortage has taken its toll.
I will only have sufficient parts to build a prototype and that's about it.
I have just announced on the Teenix web page that the 55, 65, 67 and 97 CPU boards are no longer available until the suppliers have restocked, and sadly this may not be until some time next year.
Crazy days.
cheers
Tony
RE: HP97 The journey begins - tangdfx - 05-29-2022 04:55 AM
Hi, Tony
Bad news.
But is it possible let us to have a look at the prototype of the Spice new CPU board?
RE: HP97 The journey begins - Massimo Gnerucci - 05-29-2022 07:47 AM
Sad...
Waiting in queue! ;)
RE: HP97 The journey begins - teenix - 05-29-2022 01:39 PM
(05-29-2022 04:55 AM)tangdfx Wrote:  Hi, Tony
Bad news.
Except for the power supply, the circuit design is similar to the other boards.
The main problem is the processor chips. As far as I can tell Microchip cannot manufacture them at the moment and even when they can, design companies snap them up. I cannot see any stock of any of the processors I need available anywhere, even from Microchip's own store. Even if a few are available, stockists know the rarity and the price is crazy. Some other chips are not available either. I can probably find substitutes but they may not be compatible with the board design or software.
cheers
Tony
