HP41 TULIP4041 update - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP41 TULIP4041 update (/thread-22215.html) |
RE: HP41 TULIP4041 update - MeindertKuipers - 10-31-2024 11:26 AM Thanks for the clarification Christoph! Learned something again. Some have been playing with the TULIP already, and I wanted to share some of the design trade-offs. FI input The FI input is used only for tracing the FI line, and does not have any real function for the TULIP. The FI output of course is critical for the operation of some modules, including HP-IL. The final module version will not have the FI input because it requires an extra level shifter and there is simply not enough space on the module PCB. There will be an FI output of course. And based on this output you will still be able to see when the FI line is driven by the TULIP, but you cannot see any FI activities from outside the TULIP (like TIME on the 41CX). If you still wish to trace FI, than simply use the TULIP DevBoard. The FI input has a jumper. This can be used to isolate FI and and expose GPIO2. This can then be used as an SPI or I2C port to connect a display, RTC or other goodies with your own TULIP firmware version IR out and PWO outputs The TULIP uses almost all available GPIOs, and the Pico2 module does not expose all RP2350 GPIO's. Therefore the IR and PWO outputs are shared, and also jumpered to expose GPIO3 to able able to offer SPI or I2C together with GPIO2. The TULIP module version will have its own independent IR and PWO outputs, with a solder jumper on PWO for just an extra spare GPIO. UART on GPIO0 and GPIO1 This is a remnant from the first development cycle, and it is still used by me to experiment in situations where a USB connection is not desired (power mode testing). I normally connect this to the UART on the Pico Probe. This UART will be available on the module version. As a possible use it is foreseen to be connected with the new PILBox to have a real HP-IL loop interface. TULIP Power On the DevBoard there is a FET to allow power switching between USB power and HP41 power. The FET is there to allow the TULIP to be powered from USB even when HP41 power (which has a higher voltage) is present to prevent draining the HP41's battery. It is not intended to power the HP41 from USB. There is a jumper on the HP41 VBAT line to prevent the TULIP to be powered from the calculator when there is no USB connection, this is your choice. On the final module this will be a solder jumper, which is bridged by default. Cut the trace if you do not want this. And I still have to do tests on the low-power modes of the RP2350. TULIP module version I have a draft schematic and layout of the module. The main differences with the DevBoard are: - maximum amount of FLASH, 16 MByte, hand solderable SOIC-8 footprint - USB-C connector, micro SD card holder - no FI input, only FI output tracing - an RTC is foreseen for TIME emulation,. This requires an external battery and adapted housing - IR led, on-board LED (considering multi-colour) and PWO driving - connections (for 2mm header) with I2C/UART/debug/BOOT/RUN/spare. I2C shared with RTC - 3D printed housing Always happy to get feedback. In a next post I will point out some of the plans I have with the firmware and functionality. RE: HP41 TULIP4041 update - GertSanders - 10-31-2024 05:13 PM Any images of an assembled TULIP ? RE: HP41 TULIP4041 update - MeindertKuipers - 11-02-2024 09:23 AM (10-31-2024 05:13 PM)GertSanders Wrote: Any images of an assembled TULIP ?Sure, here it is. And I am planning to make a new video in the next few days [attachment=14236] RE: HP41 TULIP4041 update - John Keith - 11-02-2024 12:33 PM (10-31-2024 11:26 AM)MeindertKuipers Wrote: - an RTC is foreseen for TIME emulation,. This requires an external battery and adapted housing You might want to adapt the RTC battery that RPi sells for the Pi 5 if it is compatible with the Tulip circuitry. Also, at the risk of heresy, I note that you have here a dual-core ARM CPU with an SD card connected to the HP-41. This would allow the 41 to call external programs written in C or Python if a suitable software interface could be provided. Please ignore the comment above if this is already part of the design, I am not an HP-41 person and I haven't been following Tulip development that closely. RE: HP41 TULIP4041 update - MeindertKuipers - 11-02-2024 12:58 PM (11-02-2024 12:33 PM)John Keith Wrote:Thanks for the battery tip. I was indeed considering such a solution, but did not look into anything specific yet.(10-31-2024 11:26 AM)MeindertKuipers Wrote: - an RTC is foreseen for TIME emulation,. This requires an external battery and adapted housing And calling stuff (in C) from the HP41 is indeed on my list of goodies. RE: HP41 TULIP4041 update - foldedtoad - 11-02-2024 07:04 PM Here are some images of the module encased with sacrificed module case. The module case was trimmed a bit on bottom half to allow for the PCB to fit. I used kapton tape to temporary hold the module case halves together; later will glue them together. RE: HP41 TULIP4041 update - foldedtoad - 11-03-2024 05:48 PM (11-02-2024 07:04 PM)foldedtoad Wrote: Here are some images of the module encased with sacrificed module case. I don't know why the pics didn't show up, but here are links to them. https://github.com/foldedtoad/tech_images/blob/master/IMG_7976.JPG https://github.com/foldedtoad/tech_images/blob/master/IMG_7975.JPG https://github.com/foldedtoad/tech_images/blob/master/IMG_7977.JPG https://github.com/foldedtoad/tech_images/blob/master/IMG_7980.JPG RE: HP41 TULIP4041 update - Thomas Klemm - 11-03-2024 07:13 PM (11-03-2024 05:48 PM)foldedtoad Wrote: I don't know why the pics didn't show up, but here are links to them. You have to link to the raw images: RE: HP41 TULIP4041 update - Etienne Victoria - 11-16-2024 10:32 PM A bit late to the party but another happy TULIP4041 live here !!! All checks passed. Thank you Meindert !! [attachment=14309] [Edit : succeeded in embedding a picture ; what a chore] RE: HP41 TULIP4041 update - twoweims - 11-16-2024 11:48 PM Another late to the game success here, too. My first attempt at surface mount soldering... All tests passed. [attachment=14303] [attachment=14304] RE: HP41 TULIP4041 update - MeindertKuipers - 11-17-2024 09:52 AM Good work assembling the TULIP and remember to have fun with it! Let me share some of the things I am currently working on for the TULIP. First of all, do not expect any new firmware updates anytime soon, unless there is a serious bug. I have been working on a file system in FLASH memory to handle ROM images and decided it is better to first get things organized and write down what I am going to do. Some time has now been spent on writing the documentation. After that I will go back to coding again. In the meantime I will be moving to another house and switching to a new computer, so please be a bit patient. At least I am now retired and work does not interfere anymore. The next firmware update will be a big one and has the following new functionality: - FLASH file system for ROM and MOD files (imported from the uSD card) - plug and unplug ROM and MOD based ROM images - supporting functions to manage images in FLASH, list, remove, update After that the next version will focus on FRAM functionality: - extension of FLASH file system for FRAM - HEPAX support - support for QROM (MLDL RAM) and HEPRAM In between I will possibly add functionality to the tracer: - mnemonics type choice - pass or block samples in a user specified address range - trigger, to start and end tracing at a user specified address - add the current Bank to the trace listing Furthermore some existing functionality needs to be fixed (non-critical): - RFC and CMD handling of the PILBox emulation - Enable HP-IL device mode support - Fix the HP82143A printer emulation to ensure correct operation with the Printer Service Module - Add non-graphic HP82143A printing to a terminal emulator (not a fix but something I want to have) Issues, bugs or feature requests are best reported on my GitHub page, but do not hesitate to start a discussion here on the forum. RE: HP41 TULIP4041 update - Etienne Victoria - 11-17-2024 12:26 PM Just upgraded to firmware 0.5. We'll be patient :-) Now let's go build the IR receiver and a case for the TULIP. Cheers E. (11-17-2024 09:52 AM)MeindertKuipers Wrote: Good work assembling the TULIP and remember to have fun with it! RE: HP41 TULIP4041 update - rocket.scientist - 11-17-2024 02:06 PM (11-17-2024 09:52 AM)MeindertKuipers Wrote: . . . I will be moving to another house and switching to a new computer, so please be a bit patient. At least I am now retired and work does not interfere anymore. Congratulations on both your retirement and the new house. Just know my honey-do and to-do lists both got longer at exactly the same time as my retirement. :-) RE: HP41 TULIP4041 update - born2laser - 11-17-2024 05:48 PM (11-17-2024 09:52 AM)MeindertKuipers Wrote: Good work assembling the TULIP and remember to have fun with it! Finally after some busy weeks at work and a business trip to Gottingen I was able to do my clumsy soldering last weekend, it all worked as advertised (except for a backwards connected LED that was easy to fix, duh). It of course left me hungry for more features, but I will be patient. There are some experiments I wanted to do that the adapter board is making easier for me to do and will keep me busy while you do your thing Here is a picture of mine, who lives in a salvaged Gel-Pak [attachment=14308] Juan |
