A quick precision test - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: A quick precision test (/thread-1521.html) |
RE: A quick precision test - pito - 06-07-2014 11:56 AM (06-06-2014 10:55 PM)Paul Dale Wrote: Alpha padded the result with semi-random digits just like I asked for. In Wolfram Alpha: Code: With 120 digits of "precision" (use "xxx`ndigits"): And the quick test from the top of this thread: Code:
RE: A quick precision test - Paul Dale - 06-07-2014 12:20 PM (06-07-2014 11:56 AM)pito Wrote: In Wolfram Alpha: Ahh, the problem seems to be the decimal point limiting the number of significant digits. Adding zeros would increase the number of digits used and hence the correct result. Expressing the decimal number as a rational yields the result we're looking for: Code: cos(157079632679489661923132169163975144/1e35) - Pauli RE: A quick precision test - pito - 06-07-2014 04:44 PM (06-07-2014 12:20 PM)Paul Dale Wrote: .. We make Mr. Wolfram unhappy when not utilizing his recommendations.. We have to explicitly request an N digits precision with any number/constant and calculus (in Mathematica as well in Alfa), otherwise "machine precision" will be used instead. So for example we want calculate with 666 digits precision: Code: 2.989 * sin ( 22.12 / 7.1 - 0.0023 ) It has to be entered into Alfa as: Code: 2.989`666 * sin ( 22.12`666 / 7.1`666 - 0.0023`666 ) In Mathematica (works in Alfa too]: Code: N[2.989`666 * Sin ( 22.12`666 / 7.1`666 - 0.0023`666), 666 ] RE: A quick precision test - Gerson W. Barbosa - 06-08-2014 02:10 AM (06-03-2014 10:06 PM)Massimo Gnerucci Wrote:(06-03-2014 09:39 PM)Gerson W. Barbosa Wrote: Our university library had a subscription to Scientific American and lots of issues then. That's one of the few articles I still have a copy of. I hope they still have them. It might be cheaper to go there and scan the articles I am interested in than paying SciAm $7,99 each :-) I know. That's why I've suggested "DECIMAL-POINT IS COMMA" :-) https://www.google.com.br/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=%22674494%2C0561%22 RE: A quick precision test - pito - 06-08-2014 12:44 PM (06-02-2014 10:37 PM)pito Wrote: A friend of mine has advised me today there is following quick precision test when testing better calculators in the shop:I've updated the list with calculators we've tested in situ (thanks Martin!) and found from available sources (web). RE: A quick precision test - walter b - 06-08-2014 01:57 PM (06-08-2014 12:44 PM)pito Wrote: Take 1.0000001 and do x^2 27times.. WP 34S and WP 31S share the same SW in that matter so it's no wonder they both return the same single precision result. After DBLON, however, the WP 34S displays 674530.470741 with a fractional part (FP) of 0.470741084559 And looking at its full precision via < and >, we see it is 0.4707410845593826891847277722). Anybody selling more, FWIW? d:-) P.S.: Wolfram alpha returns 674 530.470 741 084 559 382 689 178... at it's machine precision. If I counted correctly, that's a deviation of 10[super]-26[/super], FWIW. RE: A quick precision test - pito - 06-08-2014 02:07 PM (06-08-2014 01:57 PM)walter b Wrote: Anybody selling more, FWIW?I've updated the table (a continuous update).. PS: maybe you have to rethink your marketing approach when "selling" your calculator.. I would set the Double as the default setting and sell it as the "standard precision".. RE: A quick precision test - walter b - 06-08-2014 03:00 PM (06-08-2014 02:07 PM)pito Wrote: ... maybe you have to rethink your marketing approach when "selling" your calculator.. First of all you should quote Wolfram's result correctly. And second: Your suggestions faintly reminds me on frequency meter ads in US-American electronic magazines I saw in the Eighties of last century, where some devices were shamelessly advertized as ppm or ppb meters just because they displayed the appropriate number of digits. No, what we're "selling" are real world calculators for real world problems - and IMHO even our single precision implemented covers most of them. Just compare the precision of physical constants (published e.g. by NIST) and you will know where the real world ends so far. d:-/ RE: A quick precision test - walter b - 06-08-2014 05:28 PM (06-07-2014 04:44 PM)pito Wrote: We have to explicitly request an N digits precision with any number/constant and calculus (in Mathematica as well in Alfa), otherwise "machine precision" will be used instead. Hmmh, I went through all that and entered (...((1.0000001`34)^2`34) ... )^2`34 into Alfa but it returned >34 digits nevertheless. What did I miss? d:-? RE: A quick precision test - Paul Dale - 06-08-2014 10:46 PM (06-08-2014 02:07 PM)pito Wrote: I would set the Double as the default setting and sell it as the "standard precision".. This is not going to happen, single precision is solid and reliable and for the most part correctly rounded -- I don't currently know of any cases where it isn't but there will be some situations where the rounding goes the wrong way. In double precision, this simply isn't true. The results of some functions aren't even accurate to all returned digits. A calculator must be trustworthy first and foremost. Returning a wrong answer simply isn't acceptable. Double precision doesn't meet this. Double precision was exposed to users primarily so that they could implement accurate keystroke programs for single precision. - Pauli |
