2023 RPN HHC Programming Contest - Printable Version
+--- Thread: 2023 RPN HHC Programming Contest (/thread-20599.html)
Pages: 1 2 3 4
RE: 2023 RPN HHC Programming Contest - Gerson W. Barbosa - 10-16-2023 03:37 AM
(10-16-2023 02:31 AM)Allen Wrote:  indeed.. the others are less practical as they require too many terms for a short program!
Meanwhile, by using a(n) = n² + n - 1, for n = 6, 8 instead, I was able to save one more byte:
 01 LBL "HHC"
 02 PI
 03 X^2
 04 INT
 05 XEQ 00
 06 LASTX
 07 LBL 00
 08 DSE X
 09 X^2
 10 LASTX
 11 DSE X
 12 +
 13 END
13 steps, 25 bytes.
Or, back to a(n) = n² - n - 1, for n = 7, 9 and assuming a positive number in stack register X, one more step can be saved:
 01 LBL "HHC"
 02 SIGN
 03 10^X
 04 XEQ 00
 05 LASTX
 06 LBL 00
 07 DSE X
 08 ENTER
 09 DSE X
 10 *
 11 DSE X
 12 END
12 steps, 25 bytes.
RE: 2023 RPN HHC Programming Contest - Craig Bladow - 10-21-2023 03:56 PM
Here is my 24 byte program which tied for first place with Jason's program. CC41 was quite helpful in the program development process.
@ HHC 2023 Contest Entry 41/71
LBL "HHC"
SIGN
10^X
ENTER
ENTER
LASTX
SIGN
LASTX
LASTX
LASTX
END
RE: 2023 RPN HHC Programming Contest - Allen - 10-21-2023 07:26 PM
Craig,
Thank you for the interesting CC41 program and congrats on the solution at the conference! I really love the "load and run this program on start"!! On the face that seems really handy, and I was preparing to do on the computer what I've been doing by hand the last week or so, until...
There are a few small behaviors that are somewhat different than a normal 41C would do:
> pi     x: 3.1416 y:50.0000 z:0.0000 t:32.0000 l:50.0000 a:
> cos     x: 0.9985 y:50.0000 z:0.0000 t:32.0000 l:3.1416 a:
> isg x   x: 49.9985 y:50.0000 z:0.0000 t:32.0000 l:3.1416 a:
> dec   x: 40.0000 y:50.0000 z:0.0000 t:32.0000 l:49.9985 a:
(this is correct for input of 50.0000, but 49.9985 should say "DATA ERROR" and leave x value unchanged?)
or
> pi     x: 3.1416 y:0.0000 z:41.0000 t:50.0000 l:49.0000 a:
> cos     x: 0.9985 y:0.0000 z:41.0000 t:50.0000 l:3.1416 a:
> isg x     x: 49.9985 y:0.0000 z:41.0000 t:50.0000 l:3.1416 a:
> int     x: 49.0000 y:0.0000 z:41.0000 t:50.0000 l:49.9985 a:
> dec     x: 0.0000 y:0.0000 z:41.0000 t:50.0000 l:49.0000 a:
(0.00 is not a valid oct to dec conversion for anything except input of 0.000 . should say "DATA ERROR" and leave x value unchanged?)
Neither of these x values would be allowed without error checking the OCT->DEC command for integer input not containing the '9' digit in the base10 number. the DEC->OCT command does not have the numerical restriction, but should check for integer input.
> 5.5     x: 5.5000 y:0.0000 z:0.0000 t:41.0000 l:49.0000 a:
> oct     x: 6.0000 y:0.0000 z:0.0000 t:41.0000 l:5.5000 a:
should also return error and leave x value unchanged?
I confess I've only looked at it for a few minutes, so if this is something clearly addressed in the nicely written manual (which I did search for notes on OCT and DEC behaviors) , it is my own lack of reading and I apologize in advance.
RE: 2023 RPN HHC Programming Contest - Craig Bladow - 10-21-2023 10:25 PM
Allen,
Thanks for trying CC41. I'll reply to your post in this thread regarding CC41.
Cheers,
Craig
RE: 2023 RPN HHC Programming Contest - David Hayden - 10-23-2023 06:51 PM
Here's my 3rd place entry at 25 bytes.
01 LBL "HHC"
02 ∑+
03 ENTER↑
04 10↑X
05 ENTER↑
06 ∑+
07 1/X
08 ACOS
09 LASTX
10 ASIN
11 RDN
12 +
13 +
14 ENTER↑
15 R↑
16 -
17 END
I love these contests. It's fun to do them at the conference, but the really great part is seeing how the forum always comes up with a much better solution. Many thanks to Gene for creating and judging them.
Dave
RE: 2023 RPN HHC Programming Contest - Gerson W. Barbosa - 10-26-2023 08:07 PM
(10-23-2023 06:51 PM)David Hayden Wrote:  Here's my 3rd place entry at 25 bytes.
01 LBL "HHC"
02 ∑+
03 ENTER↑
04 10↑X
05 ENTER↑
06 ∑+
07 1/X
08 ACOS
09 LASTX
10 ASIN
11 RDN
12 +
13 +
14 ENTER↑
15 R↑
16 -
17 END
Thank you for posting your code. It’s always interesting to see the various approaches to the problem. My first attempt was also 25-byte and 17-step long, based on an easy to find approximation, which was subsequently reduced to the 24-byte 16-step one I first mentioned. I remember having used both ∑+ and ∑- in a past contest, when it was already over, I think.
Trying these at home with lots of free time is quite a different thing than solving them at the conference while participating in various activities, though.
Just for the record, before I throw away my notes, I will leave below my first two attempts.
Also, I tried a small variation on Gene’s challenge. Instead of placing 71 and 41 on the stack, I thought of displaying just a single constant, 7141. I imagined it could be done using fewer steps, but I didn’t find anything shorter than 13 steps on the 41C (or 18 bytes and 12 steps on the HP-42S, by loosening the rules to allow a 42S-specific feature, but not ATOX).
Best regards,
Gerson.
 01 LBL "HHC"
 02 PI
 03 SQRT
 04 LASTX
 05 E^X
 06 *
 07 INT
 08 PI
 09 INT
 10 SQRT
 11 X<>Y
 12 *
 13 LASTX
 14 X<>Y
 15 INT
 16 X<>Y
 17 END
25 bytes
 01 LBL "HHC"
 02 PI
 03 INT
 04 SQRT
 05 PI
 06 E^X
 07 LASTX
 08 SQRT
 09 *
 10 *
 11 LASTX
 12 X<>Y
 13 INT
 14 X<>Y
 15 INT
 16 END
24 bytes
RE: 2023 RPN HHC Programming Contest - Paul Dale - 10-26-2023 08:47 PM
Gerson's challenge to get 7141 can be done in 7 steps:
PI LN ->H LOG ACOS x^2 INT
Pauli
RE: 2023 RPN HHC Programming Contest - Gerson W. Barbosa - 10-26-2023 09:11 PM
(10-26-2023 08:47 PM)Paul Dale Wrote:  Gerson's challenge to get 7141 can be done in 7 steps:
Indeed! I would need pi/2 times more steps. Perhaps I should have suggested the more appropriate 4241 which can be done in 6 steps on the 42S, excluding LBL and END :-)
(That would depend on a positive number on the stack, though)
RE: 2023 RPN HHC Programming Contest - Gerson W. Barbosa - 10-26-2023 11:41 PM
HP-41C:
 01 LBL "ABC"
 02 SIGN
 03 ST+ X
 04 1/X
 05 ACOS
 06 X^2
 07 PI
 08 INT
 09 X^2
 10 X^2
 11 +
 12 OCT
 13 END
HP-42S:
00 { 18-Byte Prgm }
01▸LBL "ABC"
02 PI
03 IP
04 X↑2
05 LASTX
06 SQRT
07 ATAN
08 COMPLEX
09 ABS
10 X↑2
11 →OCT
12 END
For some reason on Free42 (3.0.21) it stops at step 11 with an error message (Invalid Data).
P.S.: On Free42 the result at step 10 is 3680.999999999999999999999999999995 instead of 3681. →OCT requires an integer argument. That’s an example of a program that works on the HP-42S but not on Free42 because the internal results are not rounded to the number of digits of the display like on the latter.
