HP-01 available - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: HP-01 available (/thread-5824.html) |
RE: HP-01 available - PANAMATIK - 07-01-2016 09:43 PM HP-01 repair kit can be ordered! The repair kit can be ordered in two versions. A full service and a Do It Yourself version. Have a look to my website. HP-01 repair kit For more information the HP-01 repair kit manual will be released in a few days. Bernhard RE: HP-01 available - Geoff Quickfall - 07-02-2016 12:07 PM I am in awe to the 'master resurrector'! Email sent, serial number 000001 please! Geoff RE: HP-01 available - PANAMATIK - 07-02-2016 12:28 PM (07-02-2016 12:07 PM)Geoff Quickfall Wrote: I am in awe to the 'master resurrector'! I bow to the 'master restorer'! Serial numbers for HP-01 are only 4 digits, so "000001" is not possible, I'm sorry. You will get "0001" instead. I will content myself with "0002". Bernhard RE: HP-01 available - PANAMATIK - 07-02-2016 02:05 PM (07-01-2016 09:43 PM)PANAMATIK Wrote: For more information the HP-01 repair kit manual will be released in a few days. The HP-01 Manual release 1.00 is ready for download. Bernhard RE: HP-01 available - emece67 - 07-02-2016 07:57 PM (07-02-2016 02:05 PM)PANAMATIK Wrote:(07-01-2016 09:43 PM)PANAMATIK Wrote: For more information the HP-01 repair kit manual will be released in a few days. I think I'll never get a hp-01, it is simply out of my reach. But your work on it is absolutely remarkable & I have spent a nice time reading the repair manual. Regards. RE: HP-01 available - PANAMATIK - 07-02-2016 10:54 PM (07-02-2016 07:57 PM)emece67 Wrote: I think I'll never get a hp-01, it is simply out of my reach. But your work on it is absolutely remarkable & I have spent a nice time reading the repair manual. Thank you for having enjoyed reading the manual. I spent the last three days with it. I'm sure I used many wrong english expressions, and I will release a next version after having got more editorial. By the way, I found a HP-01 for 260,-Euro only some month ago. Regards Bernhard RE: HP-01 available - PANAMATIK - 07-07-2016 03:15 PM Since the new HP-01 boards arrived end of june, I had running three of them permanently, or at least some days uninterrupted, together with the original HP-01 (the right in the image below). Two of them running in an original watch case with battery cells (left and middle in the image below), one running separately without case (because I don't have another one). I found only some minor bugs, one concerning alarm beep, it didn't beep after countdown in sleep mode and another showing stopwatch hours correctly if stopwatch was running more than 12 hours, both are fixed now. The time does count correctly as you can see in the image. left HP-01 Stainless Steel repaired but missing original wrist band, middle HP-01 Gold repaired, right original HP-01 Stainless Steel. I admit, that I couldn't press three T buttons fast enough to shoot this photo, so I manipulated it to show all three watches with display on. But they do show the same time +- 1 second also in reality. I am very satisfied with the behaviour of the boards, no more tests are necessary. Bernhard RE: HP-01 available - Suntory1980 - 08-25-2016 01:35 AM Maybe off topic, anyone knows or can make those red led crystal, I dropped mine and related to a new main board the best next things is to get a nice crystal/plexiglass fit. I saw Geoff made his own refurb but I guess there is perhaps more interest from other members? RE: HP-01 available - janrissanen - 11-15-2016 07:27 PM Really nice work, Bernhard! Have to consider buying one, if I can´t fix my one broken module ( And I REALLY doubt that I could . By the way, worth to check: http://www.ebay.com/itm/191997825058?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I bought 3.... Jan RE: HP-01 available - PANAMATIK - 11-15-2016 08:01 PM (11-15-2016 07:27 PM)janrissanen Wrote: Really nice work, Bernhard! Have to consider buying one, if I can´t fix my one broken module ..... Thank you! Both my repaired HP-01s shown above are running now for about five months flawlessly. Yet one of them did stop running for one day, because I opened it for a presentation at the HP collection Allschwil meeting in october. Also today I got feedback from another HP-01 owner, who successfully repaired his watch with the repair kit by himself. There will be an improvement in the connection wires between the two PCBs by more flexible isolated wires for the next order, which will allow better handling when unfolding the two boards. Bernhard RE: HP-01 available - Alejandro Paz(Germany) - 11-16-2016 01:06 PM You seemed to be using a 1.0 mm thick PCB, weren't you ? I was wondering if a 0.6 mm board could be used to avoid on sanding the RTC. In case you are using 0.8 mm, then forget it, as it is not going to bring much, I think. I don't have a HP-01, but still find your work very remarkable. RE: HP-01 available - PANAMATIK - 11-16-2016 02:23 PM (11-16-2016 01:06 PM)Alejandro Paz(Germany) Wrote: You seemed to be using a 1.0 mm thick PCB, weren't you ? I was wondering if a 0.6 mm board could be used to avoid on sanding the RTC. In case you are using 0.8 mm, then forget it, as it is not going to bring much, I think. I use 1.0 mm thick PCB. I couldn't go thinner, because the keyboard part wouldn't be stable enough then. Even 0.6 mm would not release me from making the IC at least a little bit thinner, because I need to remove 0.5 mm on both sides. Happily the chip has enough package material around the circuit. Bernhard RE: HP-01 available - PANAMATIK - 12-05-2016 01:51 PM Special offer for december 2016 Full HP-01 repair service for the price of the HP-01 repair kit. HP-01 repair kit Do you want to get your stainless steel or gold HP-01 back to life again and you don't know how a soldering iron looks like? This is your way to go. Until end of december. Bernhard RE: HP-01 available - Mike_in_Sweden - 07-20-2018 01:57 PM Are these still available? RE: HP-01 available - PANAMATIK - 07-24-2018 09:05 PM (07-20-2018 01:57 PM)Mike_in_Sweden Wrote: Are these still available? Yes, they are. But I'm out of office during a rather long summer vacation this year. I'm on the way driving with my bicycle from Düsseldorf to Switzerland and Austria and back. Some E-mails will be answered delayed. I apologize. Bernhard RE: HP-01 available - Hans-Peter - 07-25-2018 04:47 PM Hi Bernhard If you drive up the Rhine, then you can make a stopover in Basel and make a detour with Matthias (perhaps) and me (shure). Greetings from Basel Hans-Peter RE: HP-01 available - Dave Britten - 07-25-2018 04:47 PM Pay the Swiss Micros guys a visit and see if they want to collaborate on a DM-01. RE: HP-01 available - PANAMATIK - 07-30-2018 06:31 AM (07-25-2018 04:47 PM)Hans-Peter Wrote: Hi Bernhard Thanks for the invitation. I crossed the Black Forest and missed Basel. Perhaps I can stop over on my way back from Engadin. Bernhard RE: HP-01 available - HP-Collection - 07-31-2018 11:22 PM Hehe, just came back from Engadin to Basel... You are a bit slow Best wishes and cu on the meeting RE: HP-01 available - Hans-Peter - 08-01-2018 02:25 PM Hey Matthias You took the wrong way. Here in Basel it's tooo hot. I think the Engadin had the better (cooler) wether. I'm next weekend in Engelberg at the Brunnihütte. At 1860 meters above sea level it is still pleasant. Greetings from next door Hans-Peter |
