HP Prime Beta Firmware Version 2.2 Revision 15008 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP Prime Beta Firmware Version 2.2 Revision 15008 (/thread-22020.html) |
RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - Insoft - 09-02-2024 06:41 PM (09-02-2024 06:31 PM)ftneek Wrote:(09-02-2024 06:25 PM)Insoft Wrote: All I get is "Could not connect to the update server" what's your config.xml file look as this is mine. Code: <config> RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - ftneek - 09-02-2024 06:53 PM (09-02-2024 06:41 PM)Insoft Wrote: what's your config.xml file look as this is mine. Ah, when I posted the url for the host, it automatically became a hyperlink. I updated that post to remove the hyperlink. The host tag should not contain http:// , so it should be this: Code: <host>www.moravia-parts.com</host> Here's my config file, in case anyone just wants to replace theirs. RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - Insoft - 09-02-2024 07:09 PM (09-02-2024 06:53 PM)ftneek Wrote:(09-02-2024 06:41 PM)Insoft Wrote: what's your config.xml file look as this is mine. Thanks, I was wondering about that part since it was stated in the <protocal> RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - amindanial - 09-02-2024 08:31 PM When is it expected to get the official update? RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - nbenm - 09-02-2024 08:37 PM (09-02-2024 08:31 PM)amindanial Wrote: When is it expected to get the official update? that should already be the case. But with Moravia, you shouldn't be surprised by anything. RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - Insoft - 09-02-2024 10:20 PM I’m still getting the help for TEXTOUT for TEXTSIZE. Perhaps the next update can address some of the mistakes in the help section as well as a few typos Not super important but would be nice to see. RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - komame - 09-02-2024 10:48 PM (09-02-2024 10:20 PM)Insoft Wrote: I’m still getting the help for TEXTOUT for TEXTSIZE. The revised documentation has not been included in this firmware release; work on it is still ongoing... RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - dbrothers - 09-03-2024 01:13 AM (09-02-2024 05:58 PM)ftneek Wrote:https://www.moravia-parts.com/hp-prime/beta.html Wrote:At the moment, there are no public beta downloads. I’ve done exactly that, using TextEdit to edit the XML file. When I check for updates, I get an “Expected character data” error message, referring to the config.xml file. Should I be using something other than TextEdit on it? RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - ftneek - 09-03-2024 01:49 AM (09-03-2024 01:13 AM)dbrothers Wrote: Should I be using something other than TextEdit on it? I happened to use Xcode to save the updated file. You can also try replacing the config file with the one in this reply. RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - dbrothers - 09-03-2024 02:21 AM (09-03-2024 01:49 AM)ftneek Wrote:(09-03-2024 01:13 AM)dbrothers Wrote: Should I be using something other than TextEdit on it? For whatever reason, your file worked. I have Xcode installed (I’m a Mac/IOS developer), but it wasn’t one of the options under “Open With” when I right-clicked the config file. RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - ftneek - 09-03-2024 04:50 AM (09-03-2024 02:21 AM)dbrothers Wrote: For whatever reason, your file worked. The issue was probably TextEdit, I think by default it saves files in the Rich Text Format. I ran into a similar issue recently when I was writing a script that expected a txt file, I used TextEdit but didn't change the file format. RE: HP Prime Beta Firmware Version 2.2 Revision 15008 - granitepenguin - 09-04-2024 06:22 AM (09-03-2024 01:13 AM)dbrothers Wrote: I’ve done exactly that, using TextEdit to edit the XML file. When I check for updates, I get an “Expected character data” error message, referring to the config.xml file. Should I be using something other than TextEdit on it? textedit worked fine for me. it should save in whatever format the file was originally in. It does RTF only if you are creating a new file. |
