Little explorations with HP calculators (no Prime) - Printable Version
+--- Thread: Little explorations with HP calculators (no Prime) (/thread-7955.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
RE: Little explorations with the HP calculators - SlideRule - 04-06-2017 12:47 AM
... I share one solution ...
Here's my solution to post #67, page 4, Triangle Problem.
∠EDC = 180° - (∠D + 48°) ≊ 81°
where
∠D = acos[(ED² + BD² - BE²)/(2·ED·BD)] ≊ 51° S-S-S equation
BE = sin(84°)/sin(18°) - sin(63°)/sin(39°) ≊ 1.802517077
ED = BE² + BD² - (2·BE·BD·cos18°) ≊ 0.7167358991 S-A-S equation
BD = sin(78°)/sin(18°) - AD ≊ 2.165352128
AD = 1
BEST!
SlideRule
ps: hopefully, NO typos!
RE: Little explorations with the HP calculators - pier4r - 04-06-2017 10:43 PM
The following should be a bit easier than the last one, still I'm not finished. I do not have the 50g at the moment that is busy computing the tournament simulations.
[Image: vuvJwSP.png]
So, if I am not mistaken, I realized that the angle ABC is bisected in E, that CB and AB are equal, that I can apply the Heron's formula, but then it was too late and I started to do rubbish. I am not sure if I can check the problem again until Monday though. Also, the little math handbook that I use to refresh known relationships is not helping, not even the Heron's formula is there.
RE: Little explorations with the HP calculators - SlideRule - 04-06-2017 11:24 PM
(04-06-2017 10:43 PM)pier4r Wrote:  ... The following should be a bit easier than the last one ...
Please clarify the following: ??= AE, from the illustration. What is AE equal to?
BEST!
SlideRule
RE: Little explorations with the HP calculators - rprosperi - 04-06-2017 11:37 PM
(04-06-2017 11:24 PM)SlideRule Wrote:  Please clarify the following: ??= AE, from the illustration. What is AE equal to?
CE = AE, look at the image, both are labeled with length 'x'.
RE: Little explorations with the HP calculators - Gerson W. Barbosa - 04-07-2017 02:29 AM
Area = 7
Spoiler
The shape of the outer triangle is irrelevant.
At first I had made the sides of the outer triangle = 2x, 3x and 4x. Then I used the law of cosines on each side of outer triangles (sides proportional to 3, 4 and 5) in order to determine the angles. By applying the law of the cosines again on these angles and the sides of the inner triangle opposed to them, these sides could be expressed in terms of x. The Heron's formula was then used to compute the areas of both triangles. Finally, the ratio between these two areas is used to find the answer to the problem.
But, since the shape of the triangle is irrelevant, why not choosing a right-triangle (now I can do it :-), one with angles 90, 60 and 30 degrees and sides 2x, 4x and 2x*sqrt(3)? This makes the solution even more simple: there's no need to use the Heron's formula to calculate the area of the outer triangle; also, the sides of the inner triangle are more easily obtained.
Done by hand, except the evaluation and simplification of the area of the inner triangle using the Heron's formula (HP 50g CAS).
RE: Little explorations with the HP calculators - pier4r - 04-07-2017 09:46 AM
(04-07-2017 02:29 AM)Gerson W. Barbosa Wrote:  Area = 7
While I appreciate the contribution, I do believe that the problem can be solved without trigonometry.
RE: Little explorations with the HP calculators - pier4r - 04-07-2017 10:30 AM
(03-31-2017 07:35 AM)pier4r Wrote:  ...
http://i.imgur.com/hyiTDIg.png - written solution.
http://i.imgur.com/METbYu2.png - construction.
The written solution has a typo, but it works http://i.imgur.com/vIdr9Y7.jpg
RE: Little explorations with the HP calculators - SlideRule - 04-07-2017 12:57 PM
(04-07-2017 02:29 AM)Gerson W. Barbosa Wrote:  ...The shape of the outer triangle is irrelevant ...
IF the base and the height remain constant, the AREA of the triangle is also constant, irrespective of an alteration of the "shape" of the original triangle
(04-07-2017 02:29 AM)Gerson W. Barbosa Wrote:  ... the sides of the outer triangle = 2x, 3x and 4x...
Then why not give the original dimensions entirely in terms of x? The substitution is plausable; is it implied in the original set of givens?
I approached my attempted solution in a similar manner by asserting the irrelevancy of the SHAPE for the AREA of a triangle but got caught up on the x=y=z substitution.
BRILL!
SlideRule
RE: Little explorations with the HP calculators - Gerson W. Barbosa - 04-07-2017 02:37 PM
So do I. My only solace is that at least a calculator is not needed for this one.
[Image: IMG_3058_zpsmjwgvk35.jpg?t=1491488095]
RE: Little explorations with the HP calculators - Han - 04-07-2017 02:38 PM
Spoiler
I also got 7 for a solution but my solution required merely the insertion of two parallel lines
RE: Little explorations with the HP calculators - Gerson W. Barbosa - 04-07-2017 02:52 PM
Exactly! As long as the base and the height are kept constant, the area won't change.
Although apparently misleading, that might have excluded the right-triangle possibility, which is perhaps the most adequate way to solve the problem (at least using trigonometry). An interesting variation of the problem might be the case CF = BF. The solution is also an integer number.
Gerson.
RE: Little explorations with the HP calculators - Gerson W. Barbosa - 04-07-2017 02:57 PM
Spoiler
Euclides, the one with a moustache in the photo, was my math teacher in high school. I think I was sleeping when he was explaining the Elements. I paid more attention to his trigonometry classes, though :-)
RE: Little explorations with the HP calculators - Han - 04-07-2017 04:11 PM
It would be nice if there was a feature to hide parts of a post until a user explicitly clicks a spoiler button. Anyway draw a line through E and parallel to AB. Let G be the point of intersection of this line with BC and note G is the midpoint of BC. EGC has area 1/4*24=6. Note that EG has length 1.5y. Hence ADE has area 4. BDF has half the height as ADE (a second line through F parallel to AB helps to see this) but twice the base length. Therefore its area is also 4. Lastly EFG (compared vs BDF) has area 3 using a ratio of their bases.
RE: Little explorations with the HP calculators - Gerson W. Barbosa - 04-07-2017 05:01 PM
(04-07-2017 04:11 PM)Han Wrote:  It would be nice if there was a feature to hide parts of a post until a user explicitly clicks a spoiler button. Anyway draw a line through E and parallel to AB. Let G be the point of intersection of this line with BC and note G is the midpoint of BC. EGC has area 1/4*24=6. Note that EG has length 1.5y. Hence ADE has area 4. BDF has half the height as ADE (a second line through F parallel to AB helps to see this) but twice the base length. Therefore its area is also 4. Lastly EFG (compared vs BDF) has area 3 using a ratio of their bases.
Very nice!
Hidden text (sort of)
RE: Little explorations with the HP calculators - Han - 04-07-2017 05:12 PM
(04-06-2017 10:43 PM)pier4r Wrote:  The following should be a bit easier than the last one, still I'm not finished. I do not have the 50g at the moment that is busy computing the tournament simulations.
img: http://i.imgur.com/vuvJwSP.png
Can you explain the deduction process that leads to the conclusion that CB and AB are equal? I suspect that these are not necessarily equal.
RE: Little explorations with the HP calculators - Han - 04-07-2017 05:19 PM
BRILL!
SlideRule
I don't think we can assume that x=y=z (which is the implication in assuming the sides are 2x, 3x, 4x).
EDIT (Additional comments):
The \( n \)-dimensional volume of an object in \( \mathbb{R}^n \) (Euclidean space) is invariant under unimodular transformations (i.e. transformations of the form \(\mathbf{x} \to \mathbf{A} \cdot \mathbf{x} \) with \( |\mathbf{A}| =1 \)). So volume (in this case, 2-dimensional "volume" is really area) remains the same; but lengths are not preserved. On the other hand, relative positions are preserved. For example, since F is 1/4 the distance of BC from the point B, it will remain 1/4 the distance from B under any unimodular transformation, and B, F and C will remain collinear. The assumption that the outermost sides are 2x, 3x, and 4x, while in my opinion incorrect, do not affect the final result because (in the end) we are looking at ratios of lengths (i.e. relative positions of points on a line segment).
RE: Little explorations with the HP calculators - Dieter - 04-07-2017 05:40 PM
You could use a code box and place the hidden text after 11 or 12 blank lines:
Spoiler alert:
Scroll down to view the hidden text
--------hidden text starts here-------
This is your secret message ;-)
--------hidden text ends here-------
However, I am not sure if the code box gets a scroll bar if it contains more than exactly 11 lines under all circumstances.
Dieter
RE: Little explorations with the HP calculators - Gerson W. Barbosa - 04-07-2017 05:41 PM
(04-07-2017 05:19 PM)Han Wrote:
(04-07-2017 12:57 PM)SlideRule Wrote:  IF the base and the height remain constant, the AREA of the triangle is also constant, irrespective of an alteration of the "shape" of the original triangle
AB and AC must not be colinear being the only restriction, I think.
BRILL!
SlideRule
Yes, we can! In fact that was my first approach. I've found cos  = -1/4, cos B = 7/8 and cos Č = 11/16, the sides of the inner triangle being 2sqrt(5/8)x, sqrt(3/2)x and sqrt(47/8)x. Incidentally the area of the inner triangle = 7.
AB and AC must not be collinear. That's the only restriction I am aware of.
RE: Little explorations with the HP calculators - Han - 04-07-2017 06:00 PM
(04-07-2017 05:41 PM)Gerson W. Barbosa Wrote:  Yes, we can! In fact that was my first approach. I've found cos  = -1/4, cos B = 7/8 and cos Č = 11/16, the sides of the inner triangle being 2sqrt(5/8)x, sqrt(3/2)x and sqrt(47/8)x. Incidentally the area of the inner triangle = 7.
My point was that we cannot assume they are equal based on the problem statement. A solution that involves the lengths of the segments must include some explanation why a change in the lengths of the segments does not alter the final outcome. I am referring to the comment about how the "shape" of the triangle does not matter (I edited a previous comment to add some discussion on how volume is invariant under transformations whereas length is not.)
Additional comments:
Your solution suggests that the inner triangle is isosceles -- this is not true in the general case.
RE: Little explorations with the HP calculators - SlideRule - 04-07-2017 06:58 PM
Yes, the assumption x=y=z appears problematic.
IF x=y=z is true, then the original depiction of the inscribed triangle to the circumscribed triangle is curious (see my depiction).
I'm soooooooooo confused!
[attachment=4657]
BEST!
SlideRule
