problem: overlap long ids on memory manager - Printable Version
+--- Thread: problem: overlap long ids on memory manager (/thread-10147.html)
problem: overlap long ids on memory manager - compsystems - 02-11-2018 06:02 PM
Long ids in the memory manager with Large Font, overlap with the file size, and type name (tag)
test
Home Mode
h123456789012345678901234567890:=7
then [shift]+[tools]: user vars
CAS Mode
Library_Plane_Geometry_Triangle_Solution::AngleA:=180 - (AngleB + AngleC);
or
Library_Plane_Geometry_Triangle_Solution.AngleA:=180 - (AngleB + AngleC);
then [shift]+[tools]: CAS vars
RE: problem: overlap long ids on memory manager - compsystems - 07-20-2018 03:39 PM
Unsolved =(
"HP Prime Graphing Calculator
Software Version: 2.0.0.13865 (2018 07 06)
Hardware Version: Emu
CAS Version: 1.4.9
RE: problem: overlap long ids on memory manager - Tim Wessman - 07-21-2018 05:26 AM
Submit as bugs to calcbeta@hp.com. We don't notice or track every forum post.
