CASIO fx-CG50 - Printable Version
+--- Thread: CASIO fx-CG50 (/thread-10269.html)
CASIO fx-CG50 - lrdheat - 03-02-2018 10:08 PM
Calling Eddie Shore...I got the CASIO fx-CG50. Nice unit. I noticed that in your blog, you were happy to see that it could deal with complex numbers, even with trigonometric functions. I am not having success with that...how do I get this to work?
RE: CASIO fx-CG50 - lrdheat - 03-02-2018 10:15 PM
An example...sin (1+1i) produces a non real error, even if I, in setup, choose a+bi mode.
If I use sin 1+1i , it thinks I am adding sin 1 and i.
RE: CASIO fx-CG50 - sacredcow - 03-03-2018 02:31 AM
Have a look at chapter 2-35 in the FX-CG-50 software users guide. It describes what functions can be used with complex numbers.
Jon
RE: CASIO fx-CG50 - lrdheat - 03-03-2018 06:16 AM
Based on the blog I saw, I held out hope that the 50 had trig capabilities with complex numbers. After all, manuals sometimes do not get updated (or ignore capabilities...classwiz 991 U.S. Model manual gives no hint that d/dx and integrals are allowable in solve, for example). It is faster than the CG10.
Do you have any idea what OS 3.10 updated over the 3.0x variants?
RE: CASIO fx-CG50 - sacredcow - 03-03-2018 09:25 AM
You make a fair point about manuals not being updated. Casio seems to be particularly opaque when it comes to revealing OS update information.
Source: Cemetech.net
https://www.cemetech.net/forum/viewtopic.php?t=14075
OS 3.10 features:
- fx-CG10 restrictions on g3p/g3b file import removed
- fx-CG10/20 will use white fx-CG50 main menu screen
- In exam mode, fx-CG50 display brightness is set to level 1 instead of 0 (after inactivity, increased battery drain)
- [EXP] / [x10^x] key will output "x10" instead of "E" where possible
- Catalog includes QR code function to get help online for specific commands
- E-CON4 adds manual sampling function and can save sample data to CSV files
- 3D Graph add-in adds cone template and function input (Z graph, parametric graph, solid of rotation on X/Y axis)
- 3D Graph add-in adds trace function and can determine intersections and relationships among lines and planes
- 3D Graph add-in version 1.01 will work on OS 3.10 or higher (3D Graph 1.00 even works on fx-CG10 OS 1.00)
fx-CG20/50 AU restrictions:
- Only 4.5 MB of user flash memory and Picture Plot add-in not preinstalled
- No intersections and relationships among lines and planes in 3D Graph add-in
RE: CASIO fx-CG50 - Eddie W. Shore - 03-03-2018 03:54 PM
(03-02-2018 10:08 PM)lrdheat Wrote:  Calling Eddie Shore...I got the CASIO fx-CG50. Nice unit. I noticed that in your blog, you were happy to see that it could deal with complex numbers, even with trigonometric functions. I am not having success with that...how do I get this to work?
Unfortunately, trig functions of complex numbers no longer work. This probably a side result of the new OS (3.10.0212). I must have written my review before I upgraded the OS. I will note this in my review, thank you for catching this!
Why Casio why?
Trig functions with complex numbers will now have to use the work around (there are others):
sin (a+bi) = sin a cosh b + i cos a sinh b
cos (a +bi) = cos a cosh b - i sin a sinh b
Thankfully the ln and e^x functions still can work with complex numbers.
RE: CASIO fx-CG50 - lrdheat - 03-03-2018 04:29 PM
That sure is odd...indeed, why...
My "50" came with OS 3.02, and the trig complex number operations were not available.
Is the OS ROM at it's limit roomwise?
RE: CASIO fx-CG50 - Eddie W. Shore - 03-03-2018 05:06 PM
I don't know. Maybe it's to match with the other Casio calculators, the fx-115 ES Plus, fx-9860GII, and the fx-991 Classwiz?
RE: CASIO fx-CG50 - ijabbott - 03-04-2018 09:14 PM
(03-03-2018 04:29 PM)lrdheat Wrote:  My "50" came with OS 3.02, and the trig complex number operations were not available.
Mine came with either OS 3.00 or 3.02 - I don't remember which, and as far as I remember, never supported complex trig. Perhaps it was a particular regional variant that supported complex trig functions? They are not mentioned in the English manual for OS 3.00.
RE: CASIO fx-CG50 - lrdheat - 03-04-2018 09:26 PM
I'm wondering if Eddie tried something like sin 1+2i instead of sin (1+2i). The first case would be interpreted as (sin 1) + 2i. This would produce an answer that looks like complex numbers are supported, but is really sin 1 which is ~.84 plus i. Sin (1+2i) produces a non real error. The Prime produces in home, ~3.17+~1.96i.
RE: CASIO fx-CG50 - lrdheat - 03-04-2018 09:28 PM
That is, the CASIO would produce ~.84+2i
RE: CASIO fx-CG50 - ijabbott - 03-04-2018 09:36 PM
(03-03-2018 05:06 PM)Eddie W. Shore Wrote:  I don't know. Maybe it's to match with the other Casio calculators, the fx-115 ES Plus, fx-9860GII, and the fx-991 Classwiz?
The fx-115 ES PLUS and fx-991EX ClassWiz are even more limited in their support for complex numbers - four banger plus conjugates, absolute value, integer powers, extraction of real or imaginary part. No square roots (or other non-integer powers), logs, or exponentiation. (I don't know about the fx-9860GII, but I suspect it has the same complex number support as the PRIZM series.)
