HP-41CX - Time Module? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-41CX - Time Module? (/thread-1030.html) |
HP-41CX - Time Module? - anetzer - 04-03-2014 07:21 AM Hi there, So I bought a HP-41CX (Srl 2514S40570) with two broken posts. I had the vague notion, I would find a time module somewhere in the machine. Possibly, because a hack from the eighties still lurked in some dusty attic of my skull: Installing modules inside HP-41 When I opened it I found out that clearly the Time Module is integrated into the logic board. There's a quartz crystal soldered directly to the main logic board. Diego, on his Clonix page, refers to the motherboard which I found: ![]() I was not sure what to expect when I bought the CX, but I have seen at least one reference to a separate timer board in another thread here: [HP-41CL] Time Module Implant Should I be able to salvage another CX, is there any way to know beforehand, whether I'll find a separate timer board or is it necessary to open the calculator? Thanks, a.n.. RE: HP-41CX - Time Module? - Raymond Del Tondo - 04-03-2014 08:33 AM (04-03-2014 07:21 AM)anetzer Wrote: Should I be able to salvage another CX, is there any way to know beforehand, whether I'll find a separate timer board or is it necessary to open the calculator?Only halfnut CX units have a separate timer board (brigde board). A halfnut is indicated by rounded display corners. RE: HP-41CX - Time Module? - anetzer - 04-03-2014 10:13 AM (04-03-2014 08:33 AM)Raymond Del Tondo Wrote: Only halfnut CX units have a separate timer board (brigde board). Thanks a lot! a.n. |
