(11C) 100 virtual registers - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (11C) 100 virtual registers (/thread-10338.html) |
(11C) 100 virtual registers - Michael Zinn - 03-18-2018 12:04 AM Get 100 virtual registers instead of just 20! These are STO and RCL commands to store a number between 0 and 99 in a virtual register numbered 0 to 99. I recommend using labels D and E because they are in the same columns as STO and RCL. vRCL x Recall a number from virtual register X. Notice how this affects the stack: Before: T: ? Z: z Y: y X: Register number (0-99) After: T: z Z: z Y: y X: Register content y vSTO x Stores Y in virtual register X. Unlike regular STO, this removes the value from the stack so if you need it again you'll have to vRCL it. This also destroys T: Before: T: ? Z: z Y: Data (0-99) X: Register (0-99) After: T: Garbage Z: z Y: z X: z Only tested on the Android 11i simulator, but it should work on real devices (please comment if it doesn't): Code: LBL D RE: (11C) 100 virtual registers - Michael Zinn - 03-18-2018 04:23 PM If you take into account that the program itself takes about 9 registers worth of storage away it is still worth it if numbers in the range 0-99 are enough for your program because you effectively gained 35 more registers (100 - 9*5 - 20). The method would also work for differenty sized virtual register: Code:
RE: (11C) 100 virtual registers - Dieter - 03-18-2018 06:29 PM (03-18-2018 12:04 AM)michaelzinn Wrote: Get 100 virtual registers instead of just 20! I see you are rediscovering techniques from the Seventies. ;-) Storing multiple integers in a single data register soon became popular with the advent of the HP67/97 in 1976, as these were – as far as I know – the first HPs that offered indirect addressing. There are even HP programs where you can see this method at work. Take a look at this moon phase program for the HP41. The initialization routine prestores numerous two-digit integers where each register holds three or five at a time. By the way: instead of 2 [10^x] you better use [EEX] 2. That's faster and it's also safe on early HPs where 10^x is prone to roundoff errors (HP25: 8 [10^x] => 99999999,60). That's exactly why HP soon switched to 13-digit internal precision. Dieter |
