little math puzzle. Map 1 0 -1 to 1 0.5 0 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: little math puzzle. Map 1 0 -1 to 1 0.5 0 (/thread-10771.html) Pages: 1 2 |
RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Dieter - 05-21-2018 08:12 PM (05-21-2018 08:07 PM)J-F Garnier Wrote: 2 / INT That's also my final solution. Dieter RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Logan - 05-21-2018 08:15 PM How about: 7 x<>y MOD RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Gerson W. Barbosa - 05-21-2018 08:25 PM (05-21-2018 07:46 PM)Dieter Wrote:(05-21-2018 07:33 PM)Joe Horn Wrote: 1 – SQRT 2 / INT HP-42S: 2 BASE/ hp 33s: 2 INT/ Gerson. RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Arno K - 05-21-2018 08:27 PM Ok, after the fail above (always check twice) here a new attempt: R->B SR B->R so three steps Arno RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Logan - 05-21-2018 08:28 PM (05-21-2018 08:25 PM)Gerson W. Barbosa Wrote: HP-42S: Nice! I started down that path but didn't remember the BASE/ function. RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Arno K - 05-21-2018 08:50 PM On the Prime there is BITSR(), 1 step. Arno RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Werner - 05-21-2018 09:11 PM DSE X SQRT Cheers, Werner RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Gerson W. Barbosa - 05-21-2018 11:09 PM (05-21-2018 04:31 PM)Dieter Wrote: For three points it can always be done with a parabolic fit. But maybe there also is another and shorter/faster way to do it. ;-) A longer and slower way here. :-) Gerson. RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Gerson W. Barbosa - 05-21-2018 11:15 PM (05-21-2018 08:15 PM)Logan Wrote: How about: An interesting solution, regardless the number of steps. This works on the 33s as well (Rmdr == MOD). Gerson. RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Joe Horn - 05-22-2018 12:15 AM (05-21-2018 08:25 PM)Gerson W. Barbosa Wrote: hp 33s: The same idea in RPL is 2 IQUOT. RE: little math puzzle. Map 1 0 -1 to 1 0.5 0 - Dieter - 05-22-2018 05:59 AM (05-21-2018 08:15 PM)Logan Wrote: How about: (05-21-2018 09:11 PM)Werner Wrote: DSE X Nice – two very cool solutions. If you have calculators with the respective commands, that is. ;-) 2 / INT probably is the most universal one. Other solutions with more special commands: 2 INT÷ (HP35s) 2 IDIV (WP34s) LN ROUNDI (WP34s) Dieter |
