fsolve with financial functions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: fsolve with financial functions (/thread-10803.html) |
fsolve with financial functions - roadrunner - 05-26-2018 10:50 AM In CAS: fsolve((Finance::TvmFV(48,x,0,-100,12,12,0)) = 5000,x) returns empty brackets. I believe the correct answer is about 2.0% Is fsolve not intended to work with the financial functions, or am I doing something wrong? -road RE: fsolve with financial functions - DrD - 05-26-2018 01:59 PM fsolve((Finance::TvmFV(48,x,0,-100,12,12,0)) = 5000,x) is an interesting construct, but if it was designed to work that way, I haven't seen it. Of course something like this could be used, instead: X:=5000; [CAS] Finance::TvmIPYR(48,0,-100,X,12,12,0); -or- [Home] or [CAS] Finance.TvmIPYR(48,0,-100,X,12,12,0); RE: fsolve with financial functions - roadrunner - 05-27-2018 10:06 AM Thanks for your help DrD. I was considering a more complex problem that required an iterative solution but simplified it for my question here. The same function (with an upper case X): (Finance.TvmFV(48,X,0,-100,12,12,0))=5000 worked well in the solver app, as did the more complex problem; perplexing because apparently the solver app uses fsolve to get the answer. Thanks again for your reply. -road |
