Win 7 and WP-34S - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Win 7 and WP-34S (/thread-10860.html) |
Win 7 and WP-34S - Sanjeev Visvanatha - 06-03-2018 04:43 PM Hello, I was trying to update a WP-34S, but I only have a Win 7 machine now (no XP any longer). I used to have the setup with Samba and the HP flashing cable on my XP machine. I tried with latest MySamba from sourceforge and it says it cannot connect to the WP-34S. Is there a special procedure for Win 7 that I am unaware of, or have forgotten? Thank you for any help! RE: Win 7 and WP-34S - rprosperi - 06-03-2018 04:52 PM (06-03-2018 04:43 PM)Sanjeev Visvanatha Wrote: Hello, I've only done this on Win-7 (x64 in my case) so can't say for sure what the issue is, but I can confirm it works fine on Win-7. Are you using a real h/w COM port, or a USB/RS-232 adapter? If the latter, is the right driver installed and can you configure the COM port setting (COM1/COM2/COM3, etc.) and parameters (9600/N/8/1) in the device driver properties box? RE: Win 7 and WP-34S - Sanjeev Visvanatha - 06-03-2018 05:38 PM Thanks Bob. I am using the RS-232 adapter that I have always used with the HP cable. The port seems valid as it shows up in the device manager. Let me poke around some more. RE: Win 7 and WP-34S - Sanjeev Visvanatha - 06-03-2018 09:09 PM So it appears to be an issue with the device. I flashed another 30b successfully using the MySamba and HP cable with serial converter. The problem unit has the USB/IR board installed so I guess there may be an issue with that part of the setup. I’ll have to open it up and have a look. At the moment it looks like an expensive paperweight. RE: Win 7 and WP-34S - Sanjeev Visvanatha - 06-09-2018 01:20 AM No luck at all flashing using MySamba. I cannot find the Atmel Samba v2.09 or 2.10 on their site, and I knew this worked. Does anyone have the installation file for either these for Windows? I may be quoting Bones soon on this one: "He's dead, Jim" |
