CAS Simplify(log10) always changes to LN - Printable Version
+--- Thread: CAS Simplify(log10) always changes to LN (/thread-10950.html)
CAS Simplify(log10) always changes to LN - scropsey - 06-21-2018 06:50 PM
Is there a way to have the CAS simplify result in the base that is used?
Every expression I have tried changes the base to LN.
Example: simplify ( log10(2) + log10(6) ) results in (LN(2) + LN(6))/(LN(2) + LN(5))
I am looking to use it as a way to introduce/reinforce the properties of logs.
RE: CAS Simplify(log10) always changes to LN - DrD - 06-22-2018 11:15 AM
(06-21-2018 06:50 PM)scropsey Wrote:  Is there a way to have the CAS simplify result in the base that is used?
Using the approx() command:
Number format: FIXED 2
approx(LOG(2)+LOG(6)); // ==> 1.08
approx(((2*ln(2)+ln(3))/(ln(2)+ln(5)))); // ==> 1.08
alog10(1.08); // ==> 12 (Using Ans1 as argument)
[CAS]
approx(log10(2)+log10(6)); // ==> 1.08
-Dale-
RE: CAS Simplify(log10) always changes to LN - Marcel - 06-22-2018 12:02 PM
Hi scropsey!
The Ti-Nspire CX CAS give the answser in base 10.
Marcel
RE: CAS Simplify(log10) always changes to LN - Carsen - 06-22-2018 05:43 PM
I tackled this with using the Simplify command. Then I used LNCOLLECT to simplify it even further. The final result is LN(12)/LN(10). And since LOG(A)/LOG(B) or LN(A)/LN(B) = LOG of A with a base of B, you can easily read that the answer is the LOG of 12 with a base of 10. See the screenshot below.
As for why it goes to LN, I do not know why. And I am not knowledgeable enough to help you on how to get the answer in LOG form. Good luck and Happy Priming!
RE: CAS Simplify(log10) always changes to LN - Stevetuc - 06-25-2018 06:19 AM
It does seem to be deficient if not a bug that it simplifies by converting log10 to ln.
Until this is fixed, you can show the log properties more directly if you work in natural logs
Ie simplify(ln(2)+ln(6)) results in ln(12)
It really should be able to do the same for log10 though!
RE: CAS Simplify(log10) always changes to LN - Tim Wessman - 06-25-2018 11:35 AM
Nearly all more advanced CAS systems do not have implemented a base 10 and use a natural log for everything. In fact, they all just call it "log". The Prime CAS follows that convention and we had to do work to get "log" renamed to "ln" for the cas and "log10" lowercase as a base 10.
"log10" is implemented as a purely numeric command on the CAS side as the concept doesn't have the concept of log in anything BUT e (which is the standard as I mentioned). It doesn't have a symbolic equivalent.
Personally, I'd love it were it to be handled better but that depends on someone encouraging the CAS author to do it! Smile
