unwanted appearence of input screen mask - Printable Version
+--- Thread: unwanted appearence of input screen mask (/thread-10954.html)
unwanted appearence of input screen mask - ThomasA - 06-22-2018 05:46 PM
I observe some strange behavior of my prime (hardware model C)
Working in CAS and pressing the Apps/Info button leads to the input screen one usually sees when saving an app
Select new app name
Base App: ........
enter new app name).
The input fields (here symbolically written with dots) are not editable,
in my case they are constantly showing "Linear solver", the name of the app I used before the problem occured which is annoying.
In the past I could always switch between the apps only pressing the Apps-key and then choosing the appropriate icon.
Of course Sad I can't exactly reproduce the steps leading to this status of the machine. I remember, that I sorted the apps for the first time just before the strange things began. Sorry for this vague description!
What can I do to get rid of the unwanted input screen?
Maybe the following observation helps to clear clear the problem:
When the input screen is active I can press the help button. The displayed help text refers to the function app (and not to the actual screen content).
Software version:2018 02 12 (13441)
Thanks in advance
RE: unwanted appearence of input screen mask (solved) - ThomasA - 06-23-2018 09:54 AM
the paper-clip reset solved the problem.
RE: unwanted appearence of input screen mask - Tim Wessman - 06-23-2018 10:08 AM
ON-SYMB together will do a reboot as well if the calculator is still responsive to things...
Your unit up to date? Not sure what might have been going on
