Area of Polygon and Azimuth of Line - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Area of Polygon and Azimuth of Line (/thread-10986.html) |
Area of Polygon and Azimuth of Line - Hamada-77 - 07-01-2018 01:23 PM hello 1. Can hp prime calculate the Area of Polygon using the X,y Coordantes ? I need to draw the Polygon with the given coordnates and calculate the Area. 2. Can Hp prime calculate the Azimuth of lines / points ? thanks for help RE: Area of Polygon and Azimuth of Line - cyrille de brébisson - 07-02-2018 05:46 AM Hello, Have you looked at the geometry app? Use the cmd/polygon/polygon function to create a n point polygon. Then use the cmd/measure/area function to calculate the area. You can also do it from the cas command line: area(polygon(point1, ... pointn)) where point is a complex number with the point coordinates. As for azimuth, this can also be done in the geometry app using the angle measure tool. Cyrille RE: Area of Polygon and Azimuth of Line - Leandro Alves do Amaral - 08-12-2018 10:29 PM (07-02-2018 05:46 AM)cyrille de brébisson Wrote: Hello, Boa noite Tenho uma variável de matriz "M0" com duas colunas com valores de norte e este de um perímetro e gostaria de plotar um polígono no gráfico "G0". Saudações. [Moderator Gene:] English please if possible. Google translation is below. good evening I have an array variable "M0" with two columns with values of north and east of a perimeter and would like to plot a polygon in the graph "G0". Greetings. |
