Odd omission on two calcs - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Odd omission on two calcs (/thread-1106.html) |
Odd omission on two calcs - Matt Agajanian - 04-16-2014 12:05 AM Hi all, Unless I'm mistaken, both the Casio fx-115es and Sharp EL-W516X are missing a Degrees<>Radians conversion pair of functions. So, I guess we need to use the old routine from SR-50 days: x [sin] (switch angular mode) [sin^-1]. Hmm. it's a peculiar conversion/function omission on Sharp and Casio's part to say the least. RE: Odd omission on two calcs - rprosperi - 04-16-2014 01:07 AM (04-16-2014 12:05 AM)Matt Agajanian Wrote: Hi all, On the EL-W516X you can do angular conversions by [2nd] [Dec point] which is "DRG>" in brown. It converts RAD>GRAD>DEG in sequence. I have by no means figured this whole thing out, but it's a pretty nice machine for about $23 (TAS). The "manual" however leaves a lot or room for improvement; a single folded sheet that opens out to 23.5" x 14.75". But it is double-sided, so maybe I'm judging harshly. This makes me smile when folks complain about the Prime and 50g "poor documentation". Sure they could be better, but 1 folded sheet of paper? Sheesh! Having a copy of Walter's Printed WP-34S manual has permanently changed my landscape of what to expect (and hope for) in a manual. And though some would argue that it cost more than the EL-W516X machine itself, it's easily worth it and I could not be happier to pay for similar high quality products. RE: Odd omission on two calcs - Matt Agajanian - 04-16-2014 02:25 AM (04-16-2014 01:07 AM)rprosperi Wrote:(04-16-2014 12:05 AM)Matt Agajanian Wrote: Hi all, Thanks. Keyboard scan oversight--many, many functions getting lost in the inspection. Now that I see where the f(x) is, I know. Thanks. RE: Odd omission on two calcs - walter b - 04-16-2014 04:36 AM (04-16-2014 01:07 AM)rprosperi Wrote: Having a copy of Walter's Printed WP-34S manual has permanently changed my landscape of what to expect (and hope for) in a manual. And though some would argue that it cost more than the EL-W516X machine itself, it's easily worth it and I could not be happier to pay for similar high quality products. Thank you very much [blush] RE: Odd omission on two calcs - Waon Shinyoe - 04-16-2014 02:21 PM On 115ES: shift+Ans to call the conversion menu. 。, r and g represents degree, radius and grad. It will convert to the current angle mode. (Set in SET UP) |
